02-16-2019, 09:54 PM | #221 |
Rep 1,523
Wow, where did you find the damptronics B8?
02-16-2019, 09:56 PM | #222 | |
Rep 5,457
Drives: F30
Had to go to two different retailers. One for fronts, one for rears. |
02-17-2019, 12:54 AM | #223 |
Rep 1,523
this thread is discussion for damptronic.
02-17-2019, 06:29 AM | #224 | |
Rep 79
Differences are, B8 are not adaptive (Damptronic) and firmer than B6 correct ? Edit : saw last two posts later... |
02-20-2019, 04:47 PM | #225 |
Car Hypochondriac
335
Rep 901
So has anyone got the B6 damptronic installed yet? I still can't find any good reviews.
03-04-2019, 11:13 AM | #227 |
Rep 11
Bilstein B6 Damptronic write-up
Hello,
I’ve been following this thread for some years, because I wanted to install something better than the OEM adaptive dampers. The OEM adaptive dampers were at their end at about 100000Km/62000Miles. I hadn’t found decent user experiences anywhere, but got fed up with the wait, and went ahead and installed the B6 Damptronic dampers from Bilstein. They were fitted February 22nd 2018, and I’ve driven with these dampers some 20000Km/12500miles till today. The springs are the OEM springs, so the car’s height has not changed. I don’t usually post, am more of a reader, but I've learnt so much here that it seems only fair that I share my evaluation. So, as a first post, here’s my write-up. For you to be able to compare your set-up with mine, I’ve written some preliminary remarks. 1. My F30 335i (RWD) was built in May 2013. During production BMW changed (perhaps improved) software and hardware of the Adaptive Dampers. Therefore, your experience with or evaluation of the OEM dampers can differ from mine. My tyres (summer and winter) are NON-runflat, size 225/45 R18. Riding with runflat tyres will worsen your comfort experience, and so will riding on 19 inch wheels/tyres. Adjust my story accordingly. For better comprehension I prefer speaking of dampers in 1st position and 2nd position (the 2nd being the harder position). This to avoid confusion between comfort as an evaluation and comfort as position of dampers. 2. On OEM adaptive dampers, in the 1st position, I found that the rear axle was underdamped. After passing an undulation in the road, I could always notice that the front had stopped moving vertically while the rear would continue to do so. While very comfortable at city speeds, this was quite annoying at higher speeds : the car would “wallow” from front to rear, to the point where 2 passengers became sick because of cabin movements (on different occasions, at constant speed, on a straight stretch of highway). On OEM adaptive dampers, in the 2nd position, the suspension was too harsh for my liking. The car would start “bouncing”, as if the spring travel had become shorter. I found this totally unsuited for highway driving. I only used this position for diminishing the lean in speedy curves. Basically, I found the OEM Adaptive dampers useless at highway speeds (edit : i.e. over 160Km/h, over 100mph) 3. With Bilstein B6 Damptronic dampers in the 1st position the car’s character is totally different from OEM’s. It’s as if the car comes alive : it listens to steering inputs much better, the car becomes “chuckable”, easier to make slaloms with, handling is so much better. It makes the ride dynamic. The rear becomes “light” (= oversteers) on demand (as can be seen in Joe Achilles’ video). I can’t stress this enough : it really is a fun experience. But suspensionwise, this is as hard as I want to go. Feeling the road can be an advantage for dynamic driving, but you always feel every hump or bump in the road. It is not harsh, but the cabin never stops moving vertically. This is the position I use on the highway : the car rides on rails, but it's not a comfortable ride. With Bilstein B6 Damptronic dampers in the 2nd position, the spring travel feels much shorter. The dampers are stiffer, so the ride becomes harsh/bouncy on anything that isn’t absolutely flat asphalt. This may be perfect for track riding, but that’s something I never do. I only ride with the dampers in this 2nd position to avoid lean in fast curves. It’s close to what BMW adaptive dampers did in the 2nd position (in my 2013 F30). I would describe the B6 Damptronics’ 1st position as “sport”, and the 2nd position as “sport plus”. I am convinced that these characteristics will suit those who want a sporty ride all the time, and an even sportier suspension for track days. 4. As a conclusion : for a dynamic ride I am totally happy with the B6 Damptronic in the 1st position. Then, my F30 really is a super fun car to drive. But for long highway stretches, or simply commuting, it’s not comfortable enough. In the 2nd position the ride is simply too harsh for me. So, what I miss with the B6 Damptronic dampers, is a “comfortable” setting. I am actually comtemplating installing Bilstein B4 Damptronic, hoping that the B4’s 2nd position will be as sporty as the B6’s 1st position, and that B4’s 1st position will give a comfortable ride, without the “wallowing” I mentioned under (2). I hope this write-up helps. Cheers ! GSband Last edited by GSband; 03-04-2019 at 11:32 AM.. Reason: clarification |
FaRKle!4016.00 Eschmacher334.50 Dog Face Pony Soldier9719.50 Sweeney92198.00 larrylam646370.50 Lancelot567.50 M2Rush82.50 saxotenor0.00 Phyrexia502.50 jimmyfloyd42.50 |
03-04-2019, 12:47 PM | #228 |
Rep 3,539
Excellent writeup! Thank you for your impressions!
I wonder if the "feeling the road" you experience is due to Bilstein's typical unnecessarily high nitrogen pressure, which makes it boost the spring rate somewhat and delay when the damper can start acting. In both positions, does the car seem to "launch" off of large bumps/crests or "fall down" over them? |
03-04-2019, 12:51 PM | #229 |
Car Hypochondriac
335
Rep 901
Thank you so much for your feedback.
What's interesting is, your analysis sounds very similar to what many other describe how the dinan shockware feels on oem adaptive dampers. Though I would expect the bilsteins to be a higher quality ride over shockware. Judging by your explanation, I would wager that "position 2" is what i'm looking for compared to the oem "position 2". I find myself running my oem dampers in position 2 constantly. I hardly use position 1 because it is too soft and floaty.
Handling mods: Koni yellow - Eibach prokit - Millway street - M Performance LSD - M3 brakes - EBC bluestuff Exterior: Euro LCI tail lights - Shitty ECS CF spoiler - Chinese M performance diffuser Interior: Bavsound stage 1 and subs - custom trunk sub by Mike1327 |
03-04-2019, 01:07 PM | #230 | |
Rep 11
I agree completely that OEM's pos 1 was way too floaty. But where I live we have cobblestones on some local roads, and that's where OEM pos 1 comes in handy. In my opinion the OEM's 2nd position is somewhat "bouncier" than the B6's 2nd position. In this way B6 is better than OEM. B6 DT excells in the 1st position (IMHO). Cheers, GSband |
03-04-2019, 01:10 PM | #231 |
Rep 11
03-04-2019, 01:15 PM | #232 | |
Car Hypochondriac
335
Rep 901
03-18-2019, 08:06 AM | #233 | |
Rep 1,291
Thanks a lot!
This sounds a lot like what I experience with KW DDC, nice for track duty and spirited driving on roads, not so nice for the reality of our roads on a daily basis. Difficult to find a compromise I suppose :-/ Quote:
2017 M550i | Sophistograu
Previous cars: 2014 F30 ActiveHybrid 3 | 2012 f20 M135i |
04-10-2019, 02:29 PM | #234 |
Rep 10,256
I just received received a message from Tirerack:
"The Bilstein B16 PSS10 kit for your EDC suspension looks to have an ETA from Bilstein for late June, but it is just an estimate. It should plug into your existing harness". Hopefully, late Summer 2019 delivery will hold. |
04-11-2019, 02:45 PM | #235 | |
Car Hypochondriac
335
Rep 901
04-11-2019, 03:05 PM | #236 |
Rep 348
Great write up!
I don't think B4's are available with Damptronics or at least not for my car. Also, did you install just the front struts or a complete set including the rear? On a side note - Does anybody know if I can just change the fronts? How does this effect the drive and has anybody done it? |
04-13-2019, 12:52 PM | #237 | |
Rep 509
Drives: 2016 435i
2016 435i MSport ZHP #85
04-18-2019, 06:21 PM | #238 |
Rep 1,457
I didn't even know that had this option. I just looked it up... pretty interesting and it seems like a full coilover setup except you use a app to control the setting of the stiffness?
2024 X3 M40i
2014 BMW M5 |
04-18-2019, 09:45 PM | #239 |
Car Hypochondriac
335
Rep 901
There are two kits. One that includes an ecu that you control through an app, and one that connects directly to the car's system, and is controlled like OEM.
B58557.50 |
04-28-2019, 10:16 AM | #240 |
Car Hypochondriac
335
Rep 901
Was your kw ddc kit the plug and play or ecu version?
04-28-2019, 10:59 AM | #241 |
Rep 1,291
Plug and play, I had EDC from factory
Eschmacher334.50 |
04-28-2019, 11:15 AM | #242 | |
Rep 132
