BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F34 3-Series GT (Gran Turismo) Forum > Space saver wheel
      09-19-2020, 02:03 PM   #1
TonyCardiff
Drives: 2015 320D GT MSport
Space saver wheel
I think I am going to swap out my run flats when they need changing.
Can somebody help me with what space saver wheel and tyre I would need to carry.
My car is 2015 Series 3 GT MSport. The existing tyres are 255/45 R18 W on the rear and 225/50 R18 W on the front.
By the way this car is beautiful to drive.
      09-19-2020, 03:16 PM   #2
johnung
If you have grey brakes you can get away with 17" space saver. But if you have blue brakes you'll need an 18".
I researched space savers and decided that it had little value. I have a Slime 8-Minute compressor kit if I have a flat locally. If I have a flat on a trip then the spacer only gives me 50 miles. Then my trip is disrupted trying to find a tire center to fix or replace the flat.
A space saver takes up the exact same floor space in the trunk as a full size spare. You save about 3"-4" on top of the space saver, that's all.
Instead I bought a matching used BMW 400M wheel for about $100 and installed an old runflat as a spare. I bought a zippered tire bag online which makes it easy to move or place on the back seat if we want to keep our luggage hidden in the trunk on a trip.
The compartment under the trunk floor easily fits a small jack, breaker bar and the Slime compressor. See photos
      09-19-2020, 03:34 PM   #3
celsdogg
E4 Mafia
Drives: E30, E36/5, F22, F30
thanks for the info ont he scissor jack, been meaning to look into that!
Squad - E30 325i MT | E36/5 318ti MT | F22 M235i MT | F30 335i MT
KIA - E30 325i AT | E46 325i MT
      09-19-2020, 04:24 PM   #4
obert
obert's Avatar
Drives: 2013 328i
I have that jack and the crank part sucks. Super hard to go up with it. Bent the part that the tool goes through.
      09-19-2020, 05:28 PM   #5
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
Agreed, scissor jacks suck. I carry a 1.5 ton hydraulic that looks something like this, which fits in the compartment under the trunk, along with everything I need to plug a puncture, including the required BMW hockey puck.
https://thumbs.dreamstime.com/b/hydr...e-35163302.jpg
I do so even though I have RFTs, because if you drive on them more than a few hundred feet with no air you'll destroy them. Fix them right off and it's no biggy. I've had to do so twice within the first 15,000 miles.
      09-19-2020, 06:50 PM   #6
johnung
It's a cheap jack made in Asia and the threads are too tight and lock up if they aren't greased.
      09-19-2020, 06:52 PM   #7
johnung
Wow that's small enough to fit under the trunk floor?
      09-19-2020, 10:10 PM   #8
Billfitz
Billfitz's Avatar
Mine does, along with an air pump that plugs into the lighter outlet.
