10-15-2020, 02:32 PM | #4 |
Rep 3,185
Jesus, does anyone search anything anymore. As said before, fuel lines are E85 compatible. You can run up to E25-30 on the stock fuel pump.
10-15-2020, 02:35 PM | #5 |
Rep 102
10-15-2020, 03:18 PM | #6 |
Rep 1,452
Been running the Stage 2 E30 map just fine on stock HPFP.
2022 CT4-V Blackwing 6-speed
10-15-2020, 03:26 PM | #7 |
Rep 82
10-15-2020, 04:08 PM | #8 |
Rep 69
Yeah I don't really like the idea of running e30 map on the stock pump. If the rail pressure goes down the cylinder might get dry lol then you are f*****d
BMW M3 Touring Competition xDrive '23
Maserati GranCabrio MC '19 Maserati Levante S '17 Alfa Romeo Giulia Quadriofoglio (sold), Ferrari 488 spider (sold), BMW 340i xDrive F31 (sold) |
10-15-2020, 06:43 PM | #9 |
Rep 1,452
Ah, gotcha. The importance of logging and "every car is different" is understated. I did an E32ish mix, and mine drops to 2400psi for 400rpm (2700 - 3100). Before and after that range, rail pressure is good. I can live with the 400psi dip.
eksigned139.00 |
10-16-2020, 01:40 AM | #10 |
Rep 467
Really? Alex from Mission Performance saw dips in rail pressure with just 1 gallon of E on car on the stock pump. Was noticeable in driving too...felt like timing being pulled 🤷
10-16-2020, 05:45 AM | #11 |
Rep 1,010
Not questioning your findings mate but where did you read running E85 with stock fuel lines are compatible for the long term ?
On my official BMW fuel cap label it says maximum E10. As far as I read engines built for running high Ethanol content are using different materials on the whole fuel system as Ethanol is very a corrosive fuel. I think at this point nobody knows what long term damage could Ethanol cause.
2018 340i 8AT RWD - M Sport - Catless MPPSK - Stock Turbo - Stock HPFP
-------- Tunes: Self Made Tunes - MHD ------ Fuel: 92RON/87OCT -------- |
10-16-2020, 09:57 AM | #12 | |
Rep 3,185
10-16-2020, 12:06 PM | #13 | |
Rep 1,010
If you drove 150K miles on your N55 then yeah It should be ok.
Thanks mate for sharing this information. Quote:
10-16-2020, 05:28 PM | #14 | |
Rep 102
So no idea, I'm getting around 92.7-93 octane with 2.5 gallons of E It 100% running better than my stock 91 octane But I want to clear a tank of the 2.5 gallon before I Log it |
10-17-2020, 03:40 AM | #15 | |
Rep 1,452
https://en.wikipedia.org/wiki/Octane_rating#Examples
10-17-2020, 08:29 AM | #16 |
Rep 281
Running e it’s a good idea to test the base fuel. There seems to be massive swings between stations so this could impact on the likelihood of the HPFP crashing.
Have you run any logs since putting it in. Generally e seems to clean up timing at the right amounts. |
10-17-2020, 01:18 PM | #17 |
Rep 1,452
This x10000. I ALWAYS test the "E85" every time I fill up (then do matrix reduced row echelon form to tell me how much ethanol and 91 to put in). It's an extra 3-5 minute hassle to ensure I'm getting as close to a perfect mixture as possible. And my logs look decent because of it.
10-19-2020, 12:50 AM | #18 |
Rep 884
I ran 40% E85 with meth. Your fuel lines will be fine. Yes indeed the car runs way better with even a small splash of ethanol.
2013 335is - sold
2011 335d |
