BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > N26 Forged internals Engine build
      10-15-2020, 04:36 PM   #23
Kel918
Drives: 2013 bmw 328ix
I really need help with this answer. Is there a diffrence between a rwd and awd N20/26 engine block ???
      Today, 12:22 PM   #24
Kel918
Just dropped off my block,rods, and pistons to the machine shop. Going to go with melling liners, King bearings, Arp studs etc..
      Today, 12:48 PM   #25
snipagang
Drives: 2017 320i xdrive
Originally Posted by Kel918 View Post
The reason why I have to rebuild the engine with stronger forged connecting rods and pistons is because the engine will basically self destruct from what I've read with anything around 325-350 whp. I'm going for around 5-600 whp with my set up.
How are you hitting that 5-600whp mark? Is it just a turbocharger and fueling that will make this hit that mark? Are you worried about turbo lag?
      Today, 01:15 PM   #26
Kel918
I plan on adding a centrifugal supercharger to add 300-350+ whp. For fueling I'm going to use port injection with fuel pressure regulator , high flow fuel pump, and a return line.
      Today, 01:25 PM   #27
snipagang
I plan on adding a centrifugal supercharger to add 300-350+ whp. For fueling going to go with port injection with fuel pressure regulator , high flow fuel pump, and a return line.
Sorry, these questions might sound stupid but are you going to be running ethanol mixture with that fueling upgrade? Whats the point of the fueling upgrade? I am trying to figure out whether or not you need upgrades to run ethanol mixture with stg1 and cp upgrade only.
      Today, 01:28 PM   #28
Kel918
it's cool with questions we all learn. The reason for fueling upgrades is because the stock fuel system won't support the horsepower I'm aiming for. I live in north NJ and I can't find anywhere close to get e85, so my plan is only to use 93.
      Today, 01:33 PM   #29
snipagang
I am also in NJ and yeah its all 93 around here... but you can just mix it yourself, although I guess that comes with some challenges.
