10-01-2020, 11:44 AM | #23 |
Rep 4,322
good thread on what burbles may potentially do. ER and CG Precision DS-1(different platform)
https://f30.bimmerpost.com/forums/sh...ght=cat+melted |
PeterWT252.50 |
10-02-2020, 06:37 AM | #24 | |
Rep 519
2017 340i M Sport Alpine White / Coral
Dorch Stg2, CTS catless, xHP, Custom E50 Tuned by Shoup |
PeterWT252.50 |
10-02-2020, 08:26 AM | #25 |
Rep 558
If there's a burble setting between 'stock' and 'off', I'll start with that.
My 2017 M240i: MHD, xHP, Modded OE Intake, AA GESi 400 CPSI Cat DP, Dinan Mid-pipe, M Performance LSD & Rear Diffuser, BMS Exhaust Tips, Apex EC-7 Wheels, M-Tech Front Lip, iND Painted Mirror Caps, Smoked Reflectors
10-02-2020, 07:36 PM | #26 |
Rep 558
Received mine today and I'm very impressed with the build quality. It's gorgeous!
Unfortunately I won't be installing it until December when my factory warranty expires. Thanks @mike@x-ph.com for the competitive price and fast shipping!
10-03-2020, 10:59 AM | #27 |
Rep 190,725
My pleasure, congrats!
10-19-2020, 08:55 PM | #28 |
Rep 201
So I finally got mine installed today and got about 50 miles with no CEL. I am tuned but have not enabled the cel suppression and will see how long I can go before the dme throws a code.
Like I read in several places, cruising around town even with the exhaust flaps open doesn't change much but when you get on it the car screams and creates a visceral feeling worth its weight in gold. Also as stated, I really debated long and hard over catless vs catted and am relieved I went catted. There is a bit of a smell from outside the car, but not bad at all. However, if it were much more noticeable it could become an issue for some. If you know you want catless then of course got for it, but if you are on the fence don't do it! Also, slightly off-topic, but damn I was not expecting the jump to stage 2 being as significant as it is. Between the added torque and sounds the car is a completely different animal! |
10-20-2020, 09:08 AM | #29 |
Rep 190,725
Im glad you like it
10-23-2020, 12:44 PM | #31 |
Rep 180
I have had mine for over 5,000 miles now and still nothing. I doubt that you will get the CEL light at this point.
AFE Filter | BMS Intake Pipe
CTS DP | CTS CP | CTS Heat Exchanger PTP Turbo Blanket | AEM WMI Kit | Custom Exhaust PJ ACN91 + Meth tune| XHP Stage 3 |
10-26-2020, 10:05 AM | #32 |
Rep 190,725
Nice
10-27-2020, 02:09 PM | #33 |
Rep 314
I didnt get a CEL in the first week, but i have BM3 so i just deactivated it anyway. That way i wouldnt have to deal with it if one popped up
'16 340i M-Sport F30 Estoril blue, Oyster, Bootmod3, CTS high flow cat, CTS intake
Sold:'07 335i E90 Montego Blue on black leather, Navi, premium, sirius, sport pkg, CA, logic7 Sold: '07 328i E92, SG, Saddle Brown, Gray Poplar, ZSP, CA, Heated Seats, BMW Performance Exhaust, BMW performance SSK, Valentine1, european delivery - Military Sales |
10-27-2020, 02:12 PM | #34 | ||
Rep 1,934
10-27-2020, 05:29 PM | #35 |
Rep 1,452
??? Lots of reasons. This is a catted DP. Some folks expect to use the downpipe without suppressing the catalyst ready monitor (local states/counties/countries have different emissions laws).
2022 CT4-V Blackwing 6-speed
10-27-2020, 05:38 PM | #36 | |
Rep 1,934
10-28-2020, 12:05 AM | #37 | ||
Rep 314
10-28-2020, 01:43 AM | #38 |
Rep 1,452
I understood correctly. The tunes prevent the CEL by having the catalyst monitor set to not ready, unless that has changed. Depending on your local emissions, this can be a problem. Hence, catted DP's come into play. You can enable/disable this feature as @orangepeelforest has said.
10-31-2020, 10:11 PM | #39 |
Rep 201
Yeah me too. Purposely seeing if it will throw a cel, if it does I will flip the switch in the tune to disable monitoring. Really just trying to provide some data points for people interested in this pipe that may not be
tuned and are worried about the cel. About 700 miles now with no cel! Also for those curious, had to dial back the burbles a bit as ots on bm3 veered into obnoxious territory with this thing fitted. With the stock dp this setting was fine for me. I customed to start burbles at 3k rpm, turned up rpm to nearly 7k, and agg to 5.5. Also lowered to 1 sec duration. I don't like burbling around town at 2k rpm, but I do like a fierce crack on liftoff above 5k and these setting work. |
PeterWT252.50 |
11-01-2020, 05:42 AM | #40 |
Rep 3,864
Slightly OT: I believe I remember seeing some comparison between catted (300 cell, 200 cell) and catless, in terms of power regain compared to stock cat.... I can't find it anymore!?
I am aware of the Wagner DP massflow diagram below and it is indicative, but it is impossible to correlate to power drop/regain from it....
11-01-2020, 07:55 AM | #41 |
Rep 201
My understanding is that unless you are going after huge power that there is no meaningful difference between 200cel and catless. 300cel you start reading about people questioning if it is worth it.
11-01-2020, 08:53 AM | #42 | |
Rep 3,864
Which is why I personally see 0 point in a 200 cell over 300 / catless. It simply combines the worst of both worlds.
11-01-2020, 10:27 AM | #43 | ||
Rep 201
Also, if 200cel is not throwing a cel and passes a sniff test (which they seem to in most cases) than it could be argued there is very little reason to pay for 300cel. |
