09-29-2020, 12:37 AM | #23 | |
Rep 3,622
We accept the fact that heavily tuning our engines may in fact have catastrophic consequences even if we all hope it never happens.
BMW CCA Member #516012
09-29-2020, 07:30 AM | #25 | |
Cheapskate
4455
Rep 4,995
I remember reading a lot of threads of stuck/failed injectors on here when I was doing initial research. I feel like we haven't heard much recently but it does seem to be somewhat of an issue. |
10-02-2020, 01:35 AM | #29 |
2JZ-GTE
3066
Rep 4,013
Yeah bm3 runs at the edge of timing for your octane.
les anderson147.00 |
10-02-2020, 05:22 PM | #31 | |
Rep 22
Well I hit the cyl with a “bottle brush” hone and they have a nice cross hatch, got a ton of goodies coming for the build now. FYI - Finding main bearings for this is a effing NiGhTmArE!!! Got the crank decoded and have the color codes but none of the dealers know how to look them up or they are showing discontinued already... |
10-02-2020, 05:52 PM | #32 |
Rep 1,456
This isn't the first report. Has happened on stock motors as well.
2022 CT4-V Blackwing 6-speed
10-02-2020, 09:54 PM | #33 |
Rep 22
☝️ He ain’t wrong...
I’ll also add that there were 0 physical signs of pre detonation in my case so it’s hard to believe it was tune related Cyl 5 was definitely being over fueled to say the least... |
10-03-2020, 06:50 PM | #35 |
Rep 274
Any early warning signs we can look out for? How did that plug look?
10-03-2020, 07:23 PM | #36 |
Rep 1,597
It looks like just a manufacture defect or weakness combined with running high boost on a cast piston. The two factors converged. There is no scoring of the cylinder or anything showing foreign matter and no detonation. I can't see cylinder 5 closest to hpfp having been a factor either since fuel is nearly in-compressible.
10-04-2020, 12:05 AM | #37 | |
Rep 22
Like the other guy said probably a number of factors converging to create “perfect storm” |
eluded3065.50 |
10-04-2020, 09:11 PM | #38 | |
Rep 3,622
Seems like a pretty low failure rate but maybe you have more information from another source that I'm not aware of.
10-05-2020, 02:44 AM | #39 |
2JZ-GTE
3066
Rep 4,013
She has one too ?
"Its gonna blow up if you touch it" - my wife |
Pussiwillow522.00 |
10-05-2020, 11:18 PM | #41 |
Rep 22
Yes I was going to have them all tested. There’sa shop in town (kinda) that’s I’ll take them to. Will post the results when I get them.
10-12-2020, 07:39 PM | #42 |
Rep 22
Got the first round of goodies today
Time to get the rebuild on the way |
10-13-2020, 10:58 AM | #43 |
Rep 180
Nice man. Are those the 82mm or 82.5mm pistons? And what rod bearings did you get? Do they come with the coating that the original ones come from the factory?
AFE Filter | BMS Intake Pipe
CTS DP | CTS CP | CTS Heat Exchanger PTP Turbo Blanket | AEM WMI Kit | Custom Exhaust PJ ACN91 + Meth tune| XHP Stage 3 |
