BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > F30 oem 437m - 235/40 + 265/35 *lowered help*
      09-30-2020, 10:30 PM   #1
drivef30
drivef30's Avatar
Drives: 17' 340i xDrive M-Sport
Curious if anyone is running 235/40 + 265/35 or 235/35 + 275/30 LOWERED on springs? I went through all the post and see 235/35 lower or they either have f31,f32,f36.... Would also help to know if you are xdrive or rwd.
Im debating between 235/40 + 265/35 or 235/35 + 275/30... to keep xdrive happy, not lowered yet but will be going with HR sport springs.
Really tempted to go for 235/40 for the added sidewall and speedo correction, but 235/35 + 275/30 is safer bet for lowering/rubbing while turning but messes up the speedo even more and less sidewall. Heard conflicting info on rubbing with 235/40 on f30 chassis.
*PLEASE ONLY F30 to help others in the future (no coupes, grancoupes or touring as I believe they have different spacing in the wheel well) *
      10-19-2020, 06:00 PM   #2
M3EW
M3EW's Avatar
Drives: F80 M3
either way you wont rub if you're on springs. I have 235/40/19 and 265/35/19 I should've gone 265/30 front and 275/30 rear since F30s can easily fit that. I think you'd be happy with 235/35 and 275/30
@cheungkyf80
      10-20-2020, 01:04 PM   #3
j.f.leonard
j.f.leonard's Avatar
Drives: 2012 328i f30
Im a rwd f30 on eibach lowering springs and i have 245/35 front and 275/30 rear on the way with 19x8.5 and 19x9.5 which should be fine. Will post pics once they get here but ive seen other f30s run similar set ups with no issues.
bigdnno98288.00
      12-16-2020, 06:31 PM   #4
bigdnno98
Real Car Enthusiast
bigdnno98's Avatar
Drives: 340xi
Can you post pics?
      12-16-2020, 07:20 PM   #5
Rangeball_81
Drives: 340i M Sport
Someone else made this, but it helped me in my tire buying decisions.
I'm 275/30/19 by 245/35/19 RWD lowered on Dinan springs.
