BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > Codemybimmer's First COMPLETE 100% iDrive 5.0 Retrofit with ConnectedDrive+CarPlay
      03-09-2017, 08:55 AM   #1
steve@codemybimmer
steve@codemybimmer's Avatar
Hong Kong
665
Drives: 2020 G20 320i M Sport
We are proud to be very first in North America to have a fully working iDrive 5.0 retrofit on a 2016 M235i xDrive Convertible (Canadian spec) with all OEM parts.
Last week, we were able to obtain a full fledged iDrive 5.0 unit along with a screen and iDrive controller from a US 440i donor vehicle, flashed it to my vehicle's spec and loaded a custom set of FSC codes and to my surprise, we are able to retain all of the ConnectedDrive functionality that originally came with the vehicle! RTTI, Concierge, Internet and BMW Online are all working.
We have experimented with this in the past and tried with various iDrive 4.0 NBT EVO equipment but due to many difference in the hardware, we were never able to retain the vehicle's ConnectedDrive functionality.
We plan to make this retrofit available later this year to those who own a 2016 F2x and F3x vehicle that originally came equipped with navigation. If your vehicle was equipped with ConnectedDrive, you can keep using your existing subscription with our retrofit.
jeffc83725.00
Soul_Glo13347.00
david51537.50
      03-09-2017, 10:52 AM   #2
BMW DIY Guy
BMW DIY Guy's Avatar
Drives: 2019 M2 Competition
2024 BMW M2  [9.80]
2017 BMW X1  [10.00]
2001 BMW X5  [10.00]
Fascinating.. wonder if this would work for my 14 F32!
      03-09-2017, 10:55 AM   #3
steve@codemybimmer
Hong Kong
665
This would only apply to those who own a '16 unfortunately. '14s use different Telematics equipment that's not compatible with iDrive 5.0 hardware.
We do have converted ID5 units that will work on your vehicle but you will lose ConnectedDrive.
Vehicle Diagnostics | CarPlay Solutions | Retrofit & Repair Consulting/Programming
steve.ma@cmbsolutionsltd.com | www.codemybimmer.ca
Online Store | Remote Coding Package| ID6 Retrofit for almost all F Chassis BMWs
      03-09-2017, 10:56 AM   #4
BMW DIY Guy
2024 BMW M2  [9.80]
2017 BMW X1  [10.00]
2001 BMW X5  [10.00]
Thanks for the update. 8)
      03-09-2017, 12:52 PM   #5
petau
Does that mean the retrofit wouldn't work on a '15 either?
      03-09-2017, 01:52 PM   #6
steve@codemybimmer
Hong Kong
665
The only '15s this will work on are the F23 built from November 2014 and F22 built from March 2015.
      03-09-2017, 03:14 PM   #7
steve@codemybimmer
Hong Kong
665
CarPlay is now working as well.
      03-10-2017, 01:41 AM   #8
carlr
carlr's Avatar
99
Drives: 2022 G22 M440i
Very interesting indeed. When do you think you will have a retrofit available for this? Will it run on a euro spec '16 F36?
      03-10-2017, 10:28 AM   #9
Arthurrs
Drives: 2017 430i xdrive Gran Coupe
The bigger question is whether you figured out a way to order a cup of Timmies with Carplay.....
2017 430ix Gran Coupe
      03-10-2017, 12:37 PM   #10
steve@codemybimmer
Hong Kong
665
Likely around May. There are still some small issues that we need to sort out before making this fully available. Yes, we can source European equipment as well.
If your 2016 F36 has Navigation and ConnectedDrive then this is absolutely possible.
      03-10-2017, 12:38 PM   #11
steve@codemybimmer
Hong Kong
665
Only in a perfect world lol
      03-10-2017, 06:56 PM   #12
Sergeant Skinner
Sergeant Skinner's Avatar
166
Drives: 2020 BMW M340i XDrive
What are we talking in terms of cost?
Also, assuming it's doable on an Australian spec 2016 340i with ConnectedDrive?
      03-11-2017, 05:42 AM   #13
carlr
carlr's Avatar
99
Yes, it is fully speced and has both Prof. Nav and ConnectedDrive.
      03-11-2017, 07:17 PM   #14
steve@codemybimmer
Hong Kong
665
We're still not absolutely sure on whether or not this will work in markets outside of ECE and US but stay tuned.
      03-12-2017, 09:36 AM   #15
opfreak
Drives: Rabbit
I have an m235 built in 2015. How can I check if I can do this upgrade?
Edit- I don't have navigation. So I don't know if this would be possible at all.
      03-12-2017, 12:42 PM   #16
steve@codemybimmer
Hong Kong
665
This specific ID5 retrofit would only apply to those who own a 2016 F2x and F3x that is already equipped with the On Board Navigation system and has an active ConnectedDrive subscription.
In your case, we can provide you with a different ID5 retrofit that has CarPlay, Navigation, Voice Control and BMW Apps enabled but without ConnectedDrive. If you are interested, please PM.
      03-12-2017, 05:23 PM   #17
sheldon95
Drives: F36 gran coupe M
Does it work with a f3xx built in 2015 with NBT evo?
Thanks.
      03-13-2017, 09:36 AM   #18
steve@codemybimmer
Hong Kong
665
Thanks.
Yes it will.
      03-13-2017, 11:31 AM   #19
jeffc83
Drives: 2015 328i XDrive Luxury Line
This sucks for me and my early 2015 build:/ Curses
      03-13-2017, 11:35 AM   #20
bimmer456
Drives: 340i
Can you make this for a 2016 F30?
      03-13-2017, 11:37 AM   #21
steve@codemybimmer
Hong Kong
665
Yep, as long you have the technology package and an active ConnectedDrive subscription.
Our solution is completely plug and play and takes 10 minutes to install. All that's required from you is to remove the HVAC panel, remove the head unit and move connectors over the the new head unit. All of the coding/programming takes place here before we ship the unit to you and it is coded and activated for to your VIN. You don't need to modify any wiring or cut anything.
You keep your existing head unit for lease return/warranty purpose and this will not void warranty.
Right now, we are still testing on the M235i and working out some small issues.
      03-14-2017, 04:39 AM   #22
maxdobe
maxdobe's Avatar
Any chance of iDrive 6.0 being made available for 2017 f36 that came with iDrive 5.0?
