10-08-2017, 07:46 PM | #1 |
Rep 49
Er catless+awe midpipe+awe exhaust way to loud?
Hi guys, I just had my friend installed the AWE midpipe and exhaust into my 2017 440ix gc.
Before my friend install the AWEs for me, my car had:
After the install, the crackle, pop sound is amazing, but the cold start is way too loud. I feel like my neighbors are going to kill me someday lol , and I would like to lower the volume down a bit, but still keep the crackle/pop sound. Any recommendations to lower the volume? I don't know if a catted downpipe is going to help lowering it? Or I just change the downpipe to stock (kinda dont want to loss those powers)? It's a leased car, so I want to keep the OEM exhaust in one piece. Thanks guys. |
10-08-2017, 10:00 PM | #2 |
Rep 1,454
Install resonators.
I just got my first noise complaint today, and it was at fucking 1PM in the afternoon. I might have to go this route to quiet it down as well.
2022 CT4-V Blackwing 6-speed
10-09-2017, 04:36 AM | #3 |
Rep 462
Install a dynomax bullet resonator from summit I’ve tried many different setups since I installed my catless Downpipe, you deff need a resonator in place unless you want to sound like a Honda
10-09-2017, 06:20 AM | #4 |
Rep 579
Our cold starts are very brutal... but doing anything to quiet it down will also have an effect on the back fires.
I used to run AWE axelback/ER catless DP/stock midpipe and it sounded really good. Compared to the setup I have now which is Meisterschaft (essentially straight pipe when open valve) the full-throttle-let-off explosions were quite similar. The main difference is the lower rpms crackles in Sport mode. I still got the lower rpm gargles with my AWE setup they just werent quite as snappy as my open Meisterschaft if that makes sense. That set up was just over all less brutal, but still sounded amazing imo. So to quiet it down id either throw the stock midpipe back on, or weld on a resonator to keep that wide diameter throughout. I can get you a video of my AWE set up if youd like. EDIT... I just realized you said AWE midpipe not catback... lol. hope this still helps
Current: 2021 M340i
Previous: 2020 X3M Comp BM3 E30 & 2016 340i 8AT DME Stage 2 | FBO/Catless Meisterschaft Catback | Ohlins R&T Last edited by jalkster; 10-09-2017 at 06:57 AM.. |
10-09-2017, 12:25 PM | #6 |
Rep 49
At the moment, my car does sound like a Honda lol. Is the resonator you installed lower the volume of backfire sound as well?
10-09-2017, 12:29 PM | #7 | |
Rep 49
10-09-2017, 12:33 PM | #8 |
Rep 579
A catted DP will lower volume a little but over all the tone will be more refined. I have it on my instagram @f30canon
Current: 2021 M340i
Previous: 2020 X3M Comp BM3 E30 & 2016 340i 8AT DME Stage 2 | FBO/Catless Meisterschaft Catback | Ohlins R&T |
miked07132.50 |
10-09-2017, 12:37 PM | #9 |
Rep 49
Ah, I’ll check it once I got home. Do you think with my setup switch to a catted DP, the volume will be lower into acceptable range? I’m thinking an ER catted. Thanks
10-09-2017, 12:50 PM | #10 |
Rep 579
From the people ive talked to the DS1 catted is the way to go. It sounds great and guarantees no CEL unlike the ER, even though that doesnt seem to be a concern since youre catless now. and I dont want to give you invalid information, Im really not sure how much quieter the high flow cat would make it, all cars and exhaust setups are different. It would be noticeable though, for your neighbors im not too sure haha
Current: 2021 M340i
10-09-2017, 12:57 PM | #11 | |
Rep 49
10-09-2017, 06:04 PM | #12 |
Rep 1,454
I can chime in on the CG DS-1. It's loud AF. My cold starts, as Jalkster mentioned, are really brutal. Once I reach 3k RPM, it gets kinda raspy, but I don't think it sounds like a Honda. Has a slightly deep tone, nice gargles, LOUD/fast pops and bangs. My non-car friend said it sounds like a race car. My car friends all think it sounds good, just too loud.
Side note: I also have AWE full catback. The midpipe made a big difference, and the muffler is so small I think the only thing it does is cancel out drone. It pretty much sounds straight-piped. Odd that you didn't get proper o2 fitment, I think you're the first person on here that has had that issue. My muffler shop/tech didn't even need the $20 gasket some people have needed.
SOLD: 2016 340i xDrive 6-speed DAW v2.5 turbo E40 | Dorch S2 | VRSF DP | MST intake | AWE catback | 335is clutch | CSF heat exchanger | RK Autowerks intake manifold | Orange M Perf Brake Kit | KW Street Comfort coilovers | GTS taillights V2 Last edited by G.Newt; 10-09-2017 at 06:10 PM.. |
10-09-2017, 06:08 PM | #13 |
Rep 462
A aftermarket bullet style resonator will get rid of the higher pitched noises(rasp) while keeping most of the pops and cracks the oem one on the Car gets rid of most of pops I’m guessing there is more sound deadening material then the dynomax resonator I currently have
10-09-2017, 06:17 PM | #14 | |
Rep 49
10-09-2017, 06:19 PM | #15 | |
Rep 49
10-10-2017, 10:11 PM | #16 |
Rep 462
No I do not but any aftermarket resonator/bullet muffler will sound close to the same and make the car sound good and get rid of rasp which is the main problem
10-11-2017, 06:48 AM | #17 |
Rep 49
10-11-2017, 09:43 AM | #18 |
Rep 115,980
10-12-2017, 12:46 AM | #20 | |
Rep 216
03-22-2019, 07:12 PM | #21 | |
Rep 8
03-26-2019, 10:41 AM | #22 |
Rep 579
yes... just for recap this is ER DP, stock midpipe with resonators, and AWE axelback
Current: 2021 M340i
