03-22-2019, 01:18 AM | #1 |
Rep 368
Light white smoke coming from lower downpipe joint after install?
Just installed VRSF catted downpipe and noticed that white smoke was lightly coming out from the lower joint after a min or so after startup. It doesn't get worse with rev.
Is this exhaust leak? Or is it normal for new downpipe to burn off excess oil/residue from manufacturing? Would exhaust leak smoke be black? I spray a shit ton of PBBlaster on the oil joint to get the bolts off. Any thoughts would be appreciated.
2016 340i XDrive: Bootmod3. And stuff.
03-22-2019, 07:47 AM | #2 | |
Rep 2,654
teapain146.50 |
03-22-2019, 09:32 AM | #3 |
Rep 368
Thanks! That's very assuring.
03-22-2019, 10:20 AM | #4 |
Rep 5,372
If you see exhaust coming out of the gasket/joint, then you have an exhaust leak and need to address it. The lower exhaust gasket/v-clamp must be replaced when doing a downpipe swap or else you run a high risk of a leak.
The forest was shrinking, but the Trees kept voting for the Axe, for the Axe was clever and convinced the Trees that because his handle was made of wood, he was one of them.
03-22-2019, 11:49 AM | #5 | |
Rep 368
Thanks
03-22-2019, 12:20 PM | #6 | |
Rep 5,372
When you install new exhaust components, they typically smoke as they are often coated in machining oil to prevent rusting. That oil burns off within the first hour or so of running. It's quite possible that's all that you saw.
03-22-2019, 12:28 PM | #7 | |
Rep 368
Cool! Will do. Thanks
03-23-2019, 10:14 AM | #8 | ||
Rep 258
