BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > 10.25" Android 10 HU discussion
      01-15-2021, 01:23 PM   #2509
naiqus
Drives: BMW 320i
Originally Posted by gauchodan View Post
It worked in letting me assign Autokit as a Navigation app (and redirecting on-screen Nav buttons to Autokit), but the Voice Command button on the wheel doesn't work. I've tried reassigning to short press or long press - no luck.
Thanks for taking the time to put the APK together - greatly appreciated.
You are welcome! Maybe you can take a look at the factory settings. There is an option to configure the voice button functionality. For me, long press on the voice button will start the navigation app by default.
      01-15-2021, 01:25 PM   #2510
naiqus
Drives: BMW 320i
Originally Posted by MLHH1234 View Post
My voice button wont trigger voice command no matter what setting i choose in the menu but a long press will start my Nav app but i already have a shortcut for that adjacent to the idrive wheel. I would love to be able to use the voice button for android voice commands, is it possible to write an app that can do that in the same way you are starting Zlink here?
Many thanks
If you can find the android voice command app id, "com.google.xxx" for example, I can also do it for you.
      01-15-2021, 02:13 PM   #2511
alvarowito
Spain
Drives: BMW X6 e71
Hi guys,
Can anyone help me with the configuration of my headunit?
I have a snapdragon 625 with android 10, and i wish to autostart some apps when my head units starts, but kws software manage all headunit.
thank you for reading.
      01-16-2021, 12:20 AM   #2512
F20_M135i
France
101
Drives: BMW F20 M140i Xdrive
Originally Posted by alvarowito View Post
Hi guys,
Tasker / Automate / MacroDroid are APPS that will allow you to launch programs or settings tasks right after you start your Android unit
      01-16-2021, 01:23 AM   #2513
alvarowito
Spain
Drives: BMW X6 e71
Thank you for answer so quickly,
i already tried macrodroid, automate but seems like kws app dont let macrodroid or automate work when i need.
can you let me if i need a special configuracion of these apps or if i need special configuration in the headunit?
i usually use these apps on my phone and in others headunit without problems.
Thank you.
      01-16-2021, 03:19 AM   #2514
F20_M135i
France
101
Maybe you need to ROOT your unit for it to work, at least with TASKER (which I use) it does. In the first age of this thread, you have the method to ROOT your unit, then try to grant privileges for your chosen application, and restart the task.
      01-16-2021, 03:56 AM   #2515
F20_M135i
France
101
Originally Posted by jm115 View Post
done all of this and even put the old screen back in. Still parking sensors arent working. Anyone know what fuse the PDC is. i changed ones i though it was but need to double check
Also look that way if you can
      01-16-2021, 05:41 AM   #2516
EliasBAM
Spain
Drives: BMW F30 '12
Has anyone with a cic unit on bmw f30 managed to get the steering wheel voice command key to work with google assistant or with siri on zlink?
      01-17-2021, 05:07 AM   #2517
Carlos Rocha
Drives: BMW 320d F31 2013
Originally Posted by Kri View Post
I checked the update in comparison to 2.3.6 (and 2.5.4) , this version 2.5.8 is from 27th November 2020.
As update 2.5.4 interim update to the new gui, i didn`t do a seperate changelog
The update can be found here:
https://mega.nz/file/9QYx1QJQ#fGCpdA...FjHTvDEHh2pwKA
Code:
ro.build.display.id=Ksw-Q-Userdebug_OS_v2.5.8
ro.build.version.incremental=eng.zlx.20201211.173029
ro.system.build.date=Fri Dec 11 17:30:12 CST 2020
ro.system.build.fingerprint=qti/msm8953_64/msm8953_64:10/QKQ1.191008.001/zlx12111730:userdebug/test-keys
Code:
ro.build.display.id=Ksw-Q-Userdebug_OS_v2.5.4
ro.build.version.incremental=eng.zlx.20201203.161435
ro.system.build.date=Thu Dec  3 16:14:18 CST 2020
ro.system.build.fingerprint=qti/msm8953_64/msm8953_64:10/QKQ1.191008.001/zlx12031614:userdebug/test-keys
I found no changes regarding memorykiller, so if you have no issue with your actual 2.3.6 is see no reason to update so far.
  • Feature: New GUI ID7_ALS, inluding Music/Video player and Settings page all in a blue design
  • Feature: Speedplay now setup able via Factory config file , but unknown which license is requires.
  • Update: Centerservice updates to target Hicar and Speedplay
  • Update: EasyConnected update targeting better Scaling
  • Change: "Phonelink" tile hard coded to ZLINK now, so not able to replace by KswRedirect anymore for now !
Attachment 2485211
Attachment 2485212
Attachment 2485213
Attachment 2485207
Speedplay apk:
Attachment 2485220
Attachment 2485221
Attachment 2485222
Factory Config file 2.5.8:
  • Added: Gui ID7_ALS
  • Added: GUI ALFA Romeo
  • added maps support list for Igo map Israel & luna, T map (south korea)
  • added: ZLink /Speedlink app switch
Download:
Attachment 2485215
Attachment 2485216
Kri
i have the same problem with the app speedplay I don't now very much about this
can you help with an activation cod rod something ?
      01-17-2021, 06:15 AM   #2518
Kri
Austria
1084
Drives: E87
nothing exact is known for speedplay at the moment, at least the license have to be bought with buying the headunit, it can`t be bought afterwards.
Kri
      01-17-2021, 09:19 AM   #2519
onblue
Indonesia
Drives: BMW F30
Hi again guys, I return with some more question
Anyone here using spotify in the HU too? Is there any way to make it run as a phone?
In my old ford fiesta, the android HU is registered as a phone, that way the spotify can work in phone mode, with the visual short video clip played, and it can even integrate in the Google Maps and Waze interface (showing the title and next prev button in the maps interface)
But in this F30 HU I guess the HU is registered as a tablet, that way the spotify interface is very basic, just showing the playlist and small "currently playing song" in the bottom left. And in the Gmaps and waze there is also nothing shown
      01-17-2021, 12:55 PM   #2520
halson
Drives: BMW X5 F15 M50d
I upgrade latest Firmware version 2.6.3 but I cannot locate any "ID7_ALS" or "PEMP_ID7_UI" GUI. Any advice please?
      01-17-2021, 11:44 PM   #2521
EvntHrzn
Drives: BMW F10
Did you also make sure to update to Kri's revised factory_config.xml?
At a minimum, 2.6.1 and that factory file are needed for the UI you want to show up in the factory settings list, afaik.
      01-18-2021, 10:31 AM   #2522
Besty78
Besty78's Avatar
Drives: Bmw f30 330d
hi guys
i know the sound quality isn't the best through these units especially if you have harm/kard so i was looking through bimmercode for aux coding and found these , has anyone tried switching some of them off apart from the AUX_HU of course ?
      01-18-2021, 11:47 AM   #2523
pinopatty
Drives: BMW e90 2005
Alexa Amazon in to Android 10 HU SD625
Hi guys, congratulations for the excellent, interesting and useful post for managing android in our BMW. As the title suggests, I wanted to install the Alexa App on my Android 10 updated to the latest version by following your guides, Alexa installs itself but when you start it it blocks saying that it is impossible to continue with the installation. This was also done in the original configuration upon purchase.
Anyone can give me some explanation I need to make some changes to the factory file?
Thanks Pino
      01-18-2021, 03:20 PM   #2524
Carlos Rocha
Kri
hi again thanks for the answer.
i have also the app Zlink is the same like the speedpay but also doesn't work
      01-19-2021, 05:09 AM   #2525
franbass
Drives: F30 330d
I've the same problem but in my case, only with spotify. It insn't problem wiht phone version or not, the problem is the landscape. All apps works fine less spotify, I can't change from horizontal to vertical
      01-19-2021, 08:34 AM   #2526
Kri
Austria
1084
Drives: E87
new Hardware coming
It seems new Headunit Hardware did appear faster than thought.
For serval Mercedes and BMW cars there are now new Headunits available, spec so far known are:
  • 4/8 core 2.0 Ghz MTK Processor (2/4 core unknown MTK, 8 Core seem to be Helio P60 CPU )
  • 2/8 GB RAM
  • 32 /64GB / 128 GB Flash Memory.
  • Android 10 ?
  • Available configurations Core / Memory / flash :
    4C / 2GB / 32GB
    8C / 8GB / 64GB
    8C / 8GB / 128GB
In Terms of raw performance the new CPU seems to be around +30 ~ +100% faster than the Snapdragon 625 CPU.
However as the SD625 CPU with 4GB ram does have not real performance issue at the moment its not sure yet what benefit that new hardware will have at all.
On this upgrade the more important factor is the Software.
The shops are still using images from Snapdragon 625 Headunits, so its also not known which Android Image is installed.
As MTK processors are in general not used that much it likely may be that lots of the modification tools wont work.
As of now there is also no BMW/MB MTK headunit known tha has been rooted successfully .
So if someone already got such a new Hardware it would be cool if we could do some remote analyzing (Laptop+ Internet required) to see what that headunits are performing and what software is installed.
I`ll update this post when new information is available.
Kri
F20_M135i100.50
tezzy0.00
      01-19-2021, 08:35 AM   #2527
MLHH1234
Drives: x3 '14 2.0D
Thanks Pino
I had the same problem until I read somewhere that Language has
to be set to US English
      01-19-2021, 09:02 AM   #2528
mumblyjoe
Drives: 2011 BMW E82 135i DCT
Finally got around to finishing my Avin install in my E82, however seems few steps forward, one step back. This what I have connected:
- Android Auto Dongle (working fine)
- DAB+ (got it to work)
- Rear parking camera (working when in reverse and at the moment without additional power)
- Front DVR
I have one USB dedicated to the Android Auto and the other using an aftermarket hub to connect the DAB+, its antennae and the front DVR. However with both DVR and DAB plugged in, neither will work. I've tried a different USB hub to no effect.
Any ideas of how to get these all working harmoniously together or is this simply the limitation of this device i.e. can only have two full powered dongles attached at a time
      01-19-2021, 10:24 AM   #2529
pinopatty
Ok I'll try to change the language to the whole unit. I hope that after installing Alexa I can return to the Italian language.
      01-19-2021, 10:25 AM   #2530
pinopatty
