01-11-2021, 01:07 PM | #2465 | |
Rep 10
01-11-2021, 02:44 PM | #2469 |
Rep 53
thanks dude , someone also mentioned about connecting the hu bluetooth to the bmw bluetooth for better sound and i can't even do that , not having much luck with this system
01-11-2021, 03:45 PM | #2470 |
Rep 2
Help checking what HU this is..
Hi Guys,
Bought a 10.25” HU from a UK retailer who advertised it as a android 10 device. Since installing it, it takes about 3mins+ for Waze to be useable (GPS working) and the dashboard is completely wrong. When car is moving it actually records kph speed when dashboard says it’s mph. Did a little checking on this forum and downloaded CPU-Z and found that it is a Android 9 HU. I’m wondering if maybe the retailer made a genuine mistake and sent me a Android 9HU (even though I don’t see listings of them selling Android 9 HU) or they are trying to rip me off. As this isn’t a Android 10 HU as advertised... Please see pics attached. Appreciate all help! |
01-11-2021, 05:58 PM | #2471 |
Rep 500
Same problem here. My alternative method is to point the default player app to a silence flac file. Then using automation to launch Poweramp v3 which will pause the background default player app. It'll work seamlessly as you don't hear the default player blast a song before switching to your preferred music player. Another option is before you turn off your car, press the phone call button once and it'll launch BT phone connect app. Turn off your car and the next time you boot up the screen again, it'll default to BT Phone app and not launching the KSW Media Player.
01-12-2021, 02:28 AM | #2473 | |
Rep 2,368
Drives: E63 645Ci
01-12-2021, 03:24 AM | #2474 | |
Rep 353
Hurry up to order while there are sale days on Aliexpress. As far as I remember you had the link to the product required? https://aliexpress.ru/item/100500139...9f9b8f3302683f Last edited by serge858; 01-12-2021 at 04:02 AM.. |
01-12-2021, 04:20 AM | #2475 | |
Rep 2
01-12-2021, 04:37 AM | #2476 |
Rep 2,368
Drives: E63 645Ci
RK3399 chip (PX6) was a predecessor to Snapdragon 625 units. It is still being sold but no longer supported by software developers. It is quickly becoming outdated, no features are being added nor bugs are getting fixed. If you're buying a new unit today, no point getting a PX6 anymore especially when these are sold for not much less than SD625.
01-12-2021, 07:32 AM | #2477 |
Rep 551
I confirm and approve the statements of our friend RedErik above.
I myself had a PX6 before an S625 and the difference is clearly present and in favor of the S625, faster, more modern, more efficient, more "modifiable" (for example the wheel cannot be used in your applications on px6) So you should contact your seller and tell them that the Android unit sold is not correct |
01-12-2021, 09:19 AM | #2479 |
Rep 551
Yes... with the TASKER application and much more (it is besides me who gives the first solutions on the topic Android 9 ) but all this is not in a native way, it is with research and hacks which are not needed on S625 Android 10.
In short, if you think that PX6 is well in purchase in 2021, good for you friend! |
01-12-2021, 11:15 AM | #2480 |
Rep 23
Hi guys. Is there any easy way to remove the simcard? It seems the simcard slot is not a spring type one (the one when you push it deeper it will bounce back out). I try to remove my simcard, and with the HU installed there is no space under the front glass for my head to see it clearly.
01-12-2021, 12:55 PM | #2481 | |
Rep 353
01-12-2021, 03:11 PM | #2482 | |
Rep 546
Drives: 2014 X5 35d, 2008 Lexus IS-F
Android Version installed: Android 10 2.1.0 System Memory config.: 4GB / 64GB Device tried to connect: Mini Keyboard Bluetooth Connection successful: Yes Comment: Initially, it will not let me connect my mini handheld keyboard. So I tried my iPhone and it connected. Immediately after, I tried the keyboard and it paired with no issues. I also opened up Google Play and searched with the keyboard. I am able to use the touchpad on it as well and you'll see the cursor pop up on the screen. I did not get the Bluetooth symbol at the top, but it works. It also found my neighbors Samsung Q60 TV 🤣 but I didn't try to connect. Sorry about the glare, very sunny out here today. BTW, my vehicle is a MY14 F15, I posted this here since it's where I found the help. Thanks kri for sharing. |
Kri1083.50 |
01-12-2021, 03:44 PM | #2483 |
Rep 1,048
Short Info.
Noticed that there was an additional change with 2.5.4 / 2.5.8 Update.
So if someone is using KswRedirect at "Phonelink" Tile its highly recommended to stay below 2.5.4 , still 2.3.6 is the last recommended update for now, before memorykiller kicked in. I Updated the Changlogs regarding this informations. Kri |
01-12-2021, 08:19 PM | #2484 |
Rep 23
I see. Thanks serge. My HU is installed by the seller workshop, so I don't dare to try remove it myself. Was wondering why the network never worked, maybe the seller installed it the wrong position.
01-13-2021, 12:20 AM | #2485 | |
Rep 14
Of course the SD625 is better purchase, no doubt about that but PX6 is not garbage. For somebody on a budget, PX6 is still OK. It's not slow, it doesn't have bugs, it works well and stable. I don't know what do you expect from the HU. The only "problem" is full iDrive integration but it can be solved even without root. |
01-13-2021, 03:12 AM | #2486 | ||
Rep 551
So and just say for a new purchase we should advise him: S625 - Android 10 - 1920x720 Quote:
Your best bet is to take a small pair of tweezers, put your cell phone in selfie mode and position it against your windshield so you can see what's going on, and try (gently!) to pull the end of the sim card outwards and straight. I managed to do it like this when I had the wrong direction I do stupid things sometimes |
