01-21-2021, 02:22 PM | #2556 | |
Rep 53
thank you |
01-21-2021, 05:28 PM | #2557 |
Rep 399
Can't we have anything without activism and politicizing? This video is full of political undertones, feminism and disrespect for traditions and the elderly. The trend is that big companies do everything they can to distance themselves from their traditional customers who made them great.
F20_M135i100.50 |
01-21-2021, 07:25 PM | #2558 | |
Rep 2,368
Drives: E63 645Ci
How many of them care about Star Trek lore for example? Yet we've been served this complete rubbish, full of gender politics and cry babies, that no one wants to watch. The list of this nonsense is endless. All I ask for is a material that respects what have been established before, is well written, acted and interesting to watch. Anyways, rant is over as I went off topic by a mile! |
01-22-2021, 12:54 AM | #2559 |
Rep 551
I don't like this advertisement: Respect is earned, it cannot be obtained by force or by propaganda ... This "good camps" and his unique thought is sufficient in itself to affirm that all that goes against him: it is evil ... it becomes so ridiculous and common that it is not seen and not even noticed anymore. And it is spreading in all countries and in all houses, in all minds. By disavowing our grandparents and their traditions which nevertheless made us what we can be today: Standing people, proud, free to think and to express themselves. SUBJECT: This interior is empty and is not warm, it is with this gigantic grille in tune with the times ... To modify this idrive or to replace, our Chinese friends will have a job! |
01-22-2021, 02:58 AM | #2560 | |
Rep 13
01-22-2021, 04:08 AM | #2561 | |
Rep 551
Tell me ? Do you think it would be possible to identify the process you call "memorykiller" and try to stop it in turn via a TASKER method? Because it seems to kill my widgets (even with Android 9) and it bothers me to no longer have the speed camera detectors... |
01-22-2021, 04:42 AM | #2562 | |
Rep 2,368
Drives: E63 645Ci
F20_M135i100.50 |
01-22-2021, 05:51 AM | #2563 |
Rep 551
YESSS
At the time under Kitkat it was in the "build.prop" line Code:
ro.config.low_ram= I will see the evolutions of this lmk (from now) tonight and I will come back to tell you here. Thank you, friend |
01-22-2021, 12:11 PM | #2564 |
Rep 56
Hi,
Snapdragon 4g/64g, on the latest version. I'm having issues with low volume when starting my car (volume level is fine only after i toggle the mode button) and short press on voice button not starting navigation app (only long press starting google voice on my phone). I've looked into factory mode (android) and everything is set up right. I've also Tried new factory config file with no change. I'm loosing it 😭😭😭. |
01-22-2021, 12:12 PM | #2565 |
Rep 17
Hello, as a new user i have a question,
does any of you know whether there is a new update for Ksw-Q-Userdebug_OS that eliminates the bug with the rear view camera and the original PDC. The PDC can be switched on using the original PDC button, but the Android camera / PDC is not displayed here, actually the Android image should adapt accordingly. When the reverse gear is engaged, the original PDC switches on and the Android image also changes to camera / PDC, that's okay too. If you switch back to forward gear, the camera / PDC display of the Android goes out, although the original PDC remains switched on until a certain speed or a certain distance has been reached. The camera / PDC display of the Android should always be adapt to the status of the original PDC. Thank you, friend |
01-22-2021, 01:01 PM | #2566 |
Rep 25
noob question, while phone is connected to Android over Bluetooth and making call, which microphone is being used?
car microphone, phone microphone, display microphone? Is it the same while using Android Auto or CarPlay? any configurations to control this? Last edited by rasel800; 01-22-2021 at 01:08 PM.. |
01-22-2021, 01:27 PM | #2567 | ||
Rep 84
01-22-2021, 02:17 PM | #2568 |
Rep 551
What a headache I had trying to understand the developments since Kitkat !! If I understood correctly LMKd now runs outside of kernels (user style) Android 10 and later support a new lmkd mode that uses kernel pressure stall information (PSI) monitors for memory pressure detection and it will be complicated to master this without touching to the nuclei, what pain!
01-22-2021, 11:54 PM | #2569 | |
Rep 551
You choose Android: HU microphone You choose OEM: car microphone You choose nothing: You scream into your phone microphone so that we can hear |
ooati6.50 |
01-23-2021, 04:17 AM | #2570 | |
Rep 17
This + 12V is also after the gear change by the HU switched off for approx. 2 seconds although the original PDC is still active. |
01-23-2021, 04:52 AM | #2571 | |
Rep 2,368
Drives: E63 645Ci
Back on topic, the issue you're describing affects some units for some vendors and has nothing to do (in theory) with how you wired your reverse camera. This is an MCU issue, PDC will be only shown when car is in reverse, completely ignoring how it should work. I reported this back to my seller on multiple occasions, for them to only reply "Friend, this is normal"... describing the issue and making multiple videos showing the difference between OEM behaviour and Android screen, nothing. However, so users report that if you replace your PDC module with the latest available version, it will solve this problem. |
01-23-2021, 05:15 AM | #2572 | |
Rep 424
01-23-2021, 05:46 AM | #2573 | |
Rep 56
What about speak button to open navigation app ? It did work before (on early versions and factory config) but now i just can't find a solution. |
