03-13-2020, 02:48 PM | #1 |
Rep 919
Telematics Control Unit (in roof)--battery replacement
If you have an "SOS Emergency phone not working" message and a little yellow triangle on cluster that's annoyed you and you'd rather not pay whatever the dealer wants...probably at least an hour...which probably means two...you can do it for $60. (If you have the ability to clear the code--I used Foxwell NT530) If not, you can get one, use whatever software you use, or get a shop to clear the code(s) you'll have.
You need to replace the telematics control unit battery...about $60 online. Links of relevant pages attached. If you have a 2016 340i and don't find the telematics control unit in the trunk under the floor, then it's probably in the headliner like mine. https://www.realoem.com/bmw/enUS/sho...40#84106836777 https://www.newtis.info/tisv2/a/en/f...one/1VnZ7fcS04 When you get to the TCU, I used a short pry to hold the roof down...you don't need to do more than remove the two c-pillars and brake light panel to get to it. There is a small tab on the battery door...use a flathead bit to pry it up...you don't need to unscrew the tiny screws nearby. Battery slips in as it came out...very easy. https://www.newtis.info/tisv2/a/en/f...ights/HnEF3G0G I cracked the single clip...have an extra...but my e46 door card clip worked...exactly the same except I have to file down the diameter a little with a fine file. There are also two T-25 screws that need to come out...don't unscrew the brake light. Disconnect it...obviously. https://www.newtis.info/tisv2/a/en/f...rests/HtPALt6p It does come off...it'll take a firm wedge against something flat...and remember to yank up in direction of arrow (in TIS) after you get the top two clips off. Again, an extra plastic clip would come in handy. ...and hiding behind the panels, for the record if anyone needs to know what's back there...some pics, hopefully right side up.
04-21-2021, 03:17 PM | #4 |
Rep 919
I'm not sure I tested it but I know at some point I pressed the sos button by mistake and got bmw. After driving a while, I believe the accumulator/battery builds up enough power to be okay for a little bit. My light went on and off for a little bit before it failed 100%
11-05-2021, 04:57 PM | #5 |
Rep 262
Am also having the same problem with my 2018 340. I took out battery and got 8.1 voltage on my tester. Do you guys still think I should just change the battery anyway? Also not easy to find online?!?
11-05-2021, 09:34 PM | #6 |
Rep 16,089
It's an 8 volt battery. If it tests at 8.1 volts there's no reason to replace it. Chances are if you opened up the case you'd find generic lithium battery cells anyway.
11-06-2021, 09:30 AM | #7 | |
Rep 919
The batteries go bad...so maybe his 8.1V is after a long drive? Not sure how to test amperage...but I got my 'emulator' for $50-60 somewhere online. I suspect FCP euro would have them available now. They didn't when I found mine almost 2 years ago.
pjkbrit128.00 |
11-06-2021, 10:40 AM | #8 | ||
Rep 262
11-06-2021, 10:46 AM | #9 |
Rep 16,089
It's a rechargeable battery, so it could be running low on charge between drives. Mine was occasionally flashing on start up last winter, which I attributed to the cold temperatures and my only driving once a week. It didn't do it often enough for me to bother opening it up to change the cells, which I will do if it gets worse this winter.
11-08-2021, 04:39 PM | #10 | |
Rep 262
Anyway… I installed it but noticed it only registered 6 volts on my gauge and my ok'd one was at 8.16….(max voltage should be 8.2). Corrected the fault code and the idiot lights have remained off the past 5 drive cycles so I think it's good for now. Weird that old battery was still clearly functioning at over 8 volts and suspicious that it failed literally days out of warranty. |
dmaxdmax417.00 |
11-09-2021, 04:25 AM | #11 | |
Rep 625
dmaxdmax417.00 |
07-21-2022, 08:21 AM | #13 |
Rep 64
Hello Guys,
I have the same issue but on a 335i F30 (manufactured on June 2023). Do you think that the battery is located on the same location than a 340i F30 LCI ? (It seems to be the case following what I found on ETK website) Does someone will have the possibility to check if the right P/N for the battery is 84109361678 ? The dealer asked me 440€ for its replacement, I prefer do it by myself. Thank you very much for your feedback. |
07-22-2022, 01:42 PM | #14 | |
Rep 180
07-24-2022, 12:58 AM | #15 | |
Rep 1,117
The part number you have is wrong. Should be 84109297787 https://www.realoem.com/bmw/enUS/sho...38#84109297787 |
07-25-2022, 08:57 AM | #16 | |
Rep 64
I'm going to check its location in the coming and I will let you know. |
07-25-2022, 09:39 AM | #17 | |
Rep 64
I will check in the coming days the excal location of this battery for my car and I will let you know. |
07-29-2022, 03:00 AM | #18 |
Rep 64
To keep you informed; I have checked below the trunk floor and I found a battery.
And its part number is 84109297787. (=related to telematic) On top of this, I have also remove the plastic cover of the 3rd brake light and I have found a battery as well. (=related to SOS function) Thank you again for your help guys |
10-24-2022, 06:58 AM | #19 |
Rep 1,241
Drives: 2016 BMW 340i
Does anyone know the battery part number for a US model, 2016 BMW 340i with Navigation? I searched for "84102447710" on my local dealer's website and based on my VIN, I get a message that "84102447710" does not fit my car.
My car is a July 2015 build, Type Code 8B33.
2016 BMW 340i 688 | LCL5 | 4FT | ZMT | ZTP | ZDA | ZLP | 494 Formula One Pinnacle 30 Tint | Brushed Aluminum Pedals |
10-30-2022, 06:13 PM | #20 | |
Rep 1,241
Yes, the "malfunction message" was intermittent, on sometimes disabling BC button functionality and gone at other times, with BC working as normal. It was annoying and frequent enough for me to replace the battery. I did not perform a reset but message was gone after the battery replacement and has stayed off for 2 days and 200+ miles.
2016 BMW 340i 688 | LCL5 | 4FT | ZMT | ZTP | ZDA | ZLP | 494 Formula One Pinnacle 30 Tint | Brushed Aluminum Pedals Last edited by rambalu80; 10-30-2022 at 06:21 PM.. |
12-11-2022, 01:00 PM | #21 | |
Rep 49
01-17-2023, 09:51 AM | #22 |
Rep 1
Hi Everyone, New here, Can anyone tell me where the TCU location is on the F46 2 series Gran tourer 2018 Xdrive? My display is hogged by the error message since 6 months and no mileage or driving data available. BMW is asking for £600 for the battery change. Thanks in advance
