BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > 340i Differential Leak
Studio RSR
      01-19-2022, 05:59 PM   #1
Slow330
Slow330's Avatar
Drives: Bmw 330i
so i recently got my car back from bmw service for a leak that i noticed on my differential, can anyone explain in simpler terms what they did? Is this a common thing?
      01-19-2022, 06:02 PM   #2
PeterWT
PeterWT's Avatar
Drives: '17 M240i, AT, BSM
The pinion seal was leaking, so they replaced it. Everything else on the list is just things they needed to do in order to do that.
My 2017 M240i: MHD, xHP, Modded OE Intake, AA GESi 400 CPSI Cat DP, Dinan Mid-pipe, M Performance LSD & Rear Diffuser, BMS Exhaust Tips, Apex EC-7 Wheels, M-Tech Front Lip, iND Painted Mirror Caps, Smoked Reflectors
      01-19-2022, 06:03 PM   #3
Slow330
Slow330's Avatar
Drives: Bmw 330i
Thanks for clarifying
      01-19-2022, 07:05 PM   #4
ishowerinjager
ishowerinjager's Avatar
Drives: 2017 340i M Performance Editio
I recently had them tell me the same thing. Quoted me 1300 CAN for the job.
Is that reasonable?
2017 340i M Performance Edition: Fashion Grey, MPPSK, M performance front splitter, rear diffuser, side sills, black grille, CF spoiler, 405M 20s, 8AT, full Marino interior and dash, adaptive suspension
      01-19-2022, 07:08 PM   #5
Slow330
Slow330's Avatar
Drives: Bmw 330i
Is that reasonable?
Honestly im not sure since everything was done under warranty for me
      01-20-2022, 12:20 AM   #6
cfm56d7b
How many miles does your car have?
      01-20-2022, 12:21 AM   #7
Slow330
Slow330's Avatar
Drives: Bmw 330i
44k was never tuned or abused
      01-20-2022, 06:58 PM   #8
G.Newt
Drives: CT4-V Blackwing 6MT
My passenger side rear diff was leaking under warranty. About 5-10k miles later, the driver side leaks but I was out of warranty. I ordered the new seal and collar nut for about $50 and had a shop do the repair. I paid about $400 for them to replace the seal and drain/fill with diff fluid.
2022 CT4-V Blackwing 6-speed
SOLD: 2016 340i xDrive 6-speed
DAW v2.5 turbo E40 | Dorch S2 | VRSF DP | MST intake | AWE catback | 335is clutch | CSF heat exchanger | RK Autowerks intake manifold | Orange M Perf Brake Kit | KW Street Comfort coilovers | GTS taillights V2
      01-22-2022, 09:41 PM   #9
ishowerinjager
Thanks for the details.
I currently have about 100,000km on the car so I'm no longer under warranty.
I will likely try and find a smaller shop to do the repair for a better price
      03-28-2024, 12:04 PM   #10
co_440i
Drives: 440i
Did you get a solution for this? I was notified last Friday that my front diff pinion seal was leaking and quoted me over $700 for the fix, including a fluid drain and replace. The parts are not expensive and I'd much prefer to do it myself.
      03-28-2024, 01:38 PM   #11
G.Newt
Paddock did mine. They're in Denver. Autosport Werks in Broomfield also do good work and they're relatively affordable. But yeah, you just need the seal and the fluid.
