BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > Should I go ahead and upgrade to LSD to my xDrive?
      03-13-2024, 04:53 PM   #1
lixiang7349
lixiang7349's Avatar
Drives: customE50Tune
Took my 2019 M240i xDrive (pushing close to 650 wheel) in for routine engine oil and got the below short video report. (see link)
https://app.mykaarma.com/service-car...eg5HIs_0YdQfGk
Looks like there's a (dried-up) leak on the differential.
1) how bad is it?
2) should I do a reseal or use this opportunity to upgrade to LSD? (linked below)
https://www.getbmwparts.com/oem-part...on-33108659989
For the vent hose disconnect: what does it mean when it's not even connected?
is the DME missing sensor input like that?
Is my car safe to drive right now? I haven't gotten any CEL or any weird feelings behind the wheel.
      03-13-2024, 07:36 PM   #2
G.Newt
Drives: CT4-V Blackwing 6MT
There is no M Perf LSD for xDrive cars unless you change out axles, etc. Best bet is diffsonline. And I would just pay to get both sides of the seals done. If one side is leaking, the other side isn't far behind. $800 repair vs thousands for a new LSD. Your choice.
2022 CT4-V Blackwing 6-speed
SOLD: 2016 340i xDrive 6-speed
DAW v2.5 turbo E40 | Dorch S2 | VRSF DP | MST intake | AWE catback | 335is clutch | CSF heat exchanger | RK Autowerks intake manifold | Orange M Perf Brake Kit | KW Street Comfort coilovers | GTS taillights V2
WolfGTI716.00
      03-14-2024, 01:51 PM   #3
lixiang7349
Thank you for your response. Two things: the first is I’ve been told by many people that even for all wheel drive, M performance LSD is plug and play. Second it suggested by a lot of people that for my power level I should get an LSD.
      03-14-2024, 03:48 PM   #4
mobbinthesteez
Drives: 2020 BMW 440i Xdrive 6 speed
I can tell you first hand the M Perf LSD will not work on the xdrive without lots of modifications. The dealer was even able to order the diff for my car with my VIN but it will not work.
