10-12-2021, 09:29 AM | #1 |
Rep 2,047
High flow downpipe bad on standard engine map?
Recently the CEL light came on and bmw told me it relates to emissions.
Took my car to the garage which installed my 200-cell Wagner downpipe and they say there is nothing wrong with it mechanically. A guy from the company where I bought it told me that the issue is due to not running a stage 2 engine map. He argues that a high flow downpipe requires an engine map like BM2 stage 2 in order to avoid damage caused by backpressure. I never heard of this, as I though a less restrictive cat was an advantage regardless what engine map you are on. Decat is another story. What do you think? EDIT: oops, this should have been in the B58 section - any idea how to move?
440i GC with MPPSK, AP intake, 20" 624 M wheels, Wagner downpipe, Xhp stg 3, BM3 stg 2
instagram: f36_garage Last edited by winther1; 10-12-2021 at 04:33 PM.. |
10-12-2021, 09:44 AM | #2 |
Rep 2,354
I'd say no, but it is correct that the turbo (in theory) will overboost with reduced back pressure. However, I think the DME is smart enough to adjust for this on our cars.
Cool if you could share a log with OEM and Wagner DP
(A Dane in China) |
10-12-2021, 11:27 AM | #3 | |
Rep 7,591
The guy from wagner fed you some BS. The tune is only going to make the CEL appear sooner (unless you turn it off - the CEL is usually triggered sooner the harder the car is ran) and it is in no way going to affect the emissions compliance. The whole backpressure comment doesnt hold up, either. The only thing a tune can do is prevent the CEL from appearing but it will not affect emissions compliance. The stock tune is a load-based tune so the car will not overboost due to a DP install. Although its fairly uncommon, some people do run DPs (catted or catless) without a tune. Also, these cars run closed loop fueling, so any small change in airflow due to the DP will be handled by the DME. Bottom line - nothing is wrong with the DP, it just throws a CEL and wont pass emissions. |
rjd_F301999.50 Randy Johnson391.50 |
10-12-2021, 12:04 PM | #4 |
Rep 2,047
Damn, this is bad news... Might as well have spent a fraction of the price on a decat then.
So to pass emissions I guess I have to spend a fortune on a full cat on top of this £750 Wagner pipe.
instagram: f36_garage |
10-12-2021, 12:27 PM | #5 | |
Rep 7,591
Check your local emissions requirements. If you are allowed to have one monitor not ready for example, you may still be able to pass overall, even if the catalyst monitor fails. You can also scan for yourself and confirm it is not ready, but if you have a CEL for cat efficiency, it definitely is not. It can be not ready even if you DONT get a CEL. |
10-12-2021, 12:37 PM | #6 |
1296
Rep 3,529
complete bs about back pressure fyi.. any shop or mechanic that tells you that shouldn't get your business
10-12-2021, 04:30 PM | #7 | |
Rep 2,047
10-12-2021, 05:03 PM | #8 | |
Rep 3,940
10-12-2021, 06:09 PM | #9 | |
Rep 7,591
But as i said, check your local requirements regarding emissions monitors. If one can be not ready, you may still be able to pass. You may also be able to pass a sniffer test with the catted DP even if the car throws a CEL. |
10-13-2021, 04:38 AM | #10 |
Rep 2,047
Got another lengthy response arguing why I am at fault for putting on the downpipe without a tune:
You've bought and fitted a Racing catalyst with a much lower CPSi than the OEM catalyst. I understand the appeal as it is so much cheaper than OEM and you can gain power at the same time, but your stock car is still running a closed-loop management system with stock software. Therefore your ECU will be expecting to see the stock readings before and after the catalyst, from a catalyst with more flow and fewer cells inside, unless you alter the other parts of the car such as software to suit, you will always run the risk of the car's sensors reading higher/lower and the Engine management system being pushed past the threshold it is happy with and illuminating an error light. It is also important to remember that as said before there are numerous other factors on the engine that can account for it not running right and that light being illuminated. That is even more likely since you have already said the stock cat was damaged.... what caused the damage to the original catalyst on such a new car? Clearly something was not happy beforehand, so has that fault been found and rectified? This is the same on pretty much any vehicle platform in the world, not something specific to your make model, if you uprate a downpipe for a higher flowing lower cell racing downpipe setup then you should update the software to suit. I suspect when you alter the software this will resolve your issue as long as you don't have a pre-existing problem still in existence.
10-13-2021, 06:50 AM | #11 | |
1296
Rep 3,529
those people are just stupid. setting a check engine light because of catalytic efficiency is completely different and doesn't change how the car runs
10-13-2021, 07:27 AM | #12 | |
Rep 383
The CEL is a known side effect of running an aftermarket CAT (outside a few which are designed to make the car happy - and cost much more). Like other's have said, it shouldn't cause any problem with operation - so if you are having a problem besides just the CEL, it's likely not related to the CAT. My understanding is all the tunes do is force cancel the CEL, they don't actually fix the reading being outside the range the car is looking for to not trigger one. |
10-13-2021, 09:51 AM | #13 |
Rep 190,586
I feel things got a little mixed up with this thread.
From OP's original post, he is asking if there is any harm to running a downpipe on a stock map, as that's what he's been told. The answer is no; there is no harm to running the catted downpipe; the person that told you so, unfortunately, does not know what they are talking about. On stage 2, you do not get a CEL because the tune is hiding it. It's got nothing to do with the ECU or the car running better. If you want a downpipe that guarantees no CEL without any tune, get the Active Autowerke.
10-13-2021, 10:50 AM | #14 | |
Rep 7,591
The bottom line is that wagner DP is not good enough to prevent a CEL, and for some reason wagner won't simply say that. The disclaimer is on their website so i am not sure why they are skirting around the issue. It's not the first time wagner has responded poorly, as several people had fitment issues with N55 DPs due to O2 bung placement and they said things like "stretch the wire" or extend the harness to make it fit.... Having a CEL for catalyst efficiency isnt going to have any negative effect on performance, but OP should confirm that is the only code and that the emission monitor is not ready. |
10-14-2021, 07:46 AM | #15 |
Rep 1,597
I would be very surprised if a 200 cell DP could avoid a CEL without spacers so getting a CEL witht he Wagner 200 is normal. I would not say there is no danger in running catless on BM3 even on stage 2 since it is boost based. If you are worried, I suggest having an experienced custom tuner adjust your tune. I would feel better running catless on stock than on BM3 but I wouldn't say there is no danger there either.
10-14-2021, 09:41 AM | #16 |
Rep 2,047
Thanks a lot for all the answers - this gives me peace of mind!
I think I will try the spacer option but also finally get BM3 stage 2. Just have to point out that all this misinformation comes from the seller of the Wagner downpipe, not from Wagner directly.
10-14-2021, 11:02 AM | #17 | ||
Rep 7,591
Who sold you the wagner? |
10-14-2021, 11:20 AM | #18 | |
Rep 3,940
I ran an O2 spacer on my factory cat just to pass inspection. The factory cat has some issues already but a spacer was able to get it over the hump. After inspection, I swapped back to my catless downpipe. I noticed that the O2 spacer causes the idle to sometimes get a bit wonky on start up. |
10-14-2021, 11:28 AM | #19 |
Rep 1,597
Hey man, a post like this makes me not want to explain. Also, there is no definitive information from BMW that the secondary O2 is used in fuel trim control.
10-14-2021, 11:40 AM | #20 | |
Rep 7,591
I know you keep arguing in other threads as well that the secondary O2 isnt used for fuel trim control, despite the fact that MHD specifically said so (for our platform/engine) in response to a an email question about using a spacer on the secondary O2 (its buried in the MHD thread), and that it is well documented for the N54 and numerous other car platforms. I never said i am 100% sure based on XYZ from BMW for the F3x N55 that the secondary O2 is used for fuel trims (see my post - "all the information indicates"). I was very careful with my word choice so as to not imply a level of certainty above what i have. Nonetheless, it makes no sense at all to run one long term and take an unnecessary risk based on all the information we have when you can just code out the CEL. I am providing OP with information and he can make his own decision. |
10-14-2021, 12:13 PM | #21 |
1296
Rep 3,529
it's not. it would be impossible. plus lol, changing the dp in anyway would change fuel trims which we know doesn't happen.
10-14-2021, 12:19 PM | #22 |
Rep 7,591
Impossible for the secondary O2? It doesn't directly control fuel trims (that's the job of the wideband, primary O2), but it supposedly is used to prevent drift of primary O2 since secondary O2 is a narrowband and is much more accurate within that small AFR window.
