BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > Replacement tire tread depth difference
      08-10-2018, 01:27 PM   #1
rphz
Drives: 2014 F32 435xi
I recently had to get a rear tire replaced due to damage and so now have 3 partially worn tires and 1 new one (replacement is same model and size as the damaged one). The tread depth of the new rear is 9/32 while the other rear tire is about 6.25/32. Fronts are both at 8/32. Car has 19" factory staggered wheels with Michelin Pilot Sport 4S tires (225/40-19 front and 255/35-19 rear). Car is also xDrive.
Do I risk damaging the drive train due to the slightly larger diameter difference of this 1 new rear tire that is roughly 3/32 larger? If not, does it make sense to have 3-4 psi more in the new rear for a short amount of time to try to wear it down a bit faster?
      08-10-2018, 01:30 PM   #2
obert
obert's Avatar
Drives: 2013 328i
You will be fine it’s not enough to damage anything.
rphz70.00
      08-11-2018, 09:30 AM   #3
rphz
Thanks for the response
      08-11-2018, 10:43 AM   #4
obert
obert's Avatar
Drives: 2013 328i
      08-14-2018, 12:34 PM   #5
kern417
Cheapskate
4447
I still don't like running tires like that. I either
1. Buy a pair of tires and sell the one good tire, or
2. Buy a good used tire
That way even if it doesn't affect the drivetrain, you know you'll have even and predictable grip in the dry/wet.
