02-17-2025, 12:40 PM | #1 |
Rep 33
N20 Valve Cover Replacement Nightmare
Hey guys just did my valve cover and all the gaskets yesterday. Everything came off and went on smoothly no problems. Gaskets were pre installed and lubed. After everything was said and done, I cranked it up and it started rough idling and popping from a misfire.
I feel fucking defeated. What’s my next steps? Do I get a smoke tester and compression tester and start down the list of where it’s leaking. Or is it as simple of a connector. |
02-17-2025, 04:08 PM | #3 | |
Rep 33
I’ve included a photo of the codes I am getting. I’m assuming I’m just gonna have to redo the job to properly seal the gaskets |
02-17-2025, 09:51 PM | #4 |
![]() ![]() 674
Rep 1,281
reinstall the hpfp. make sure the cam lobe is all the way at the bottom. also replace the hpfp mounting bolts as those things snap if you reuse them more than 2x. make sure your fuel lines from the hpfp to the fuel rail and those which connect to the fuel injectors are tight.
MY13: IM500 n20 g25-660 Hybrid Turbo. Estimated 500whp on hybrid turbo
e80 tune + Port Injection by Navardi Tuned. 100% forged and hero build N20 Build Thread: https://f30.bimmerpost.com/forums/sh....php?t=1742413 IG + YT: Sqwin_n20 |
02-17-2025, 10:01 PM | #5 | |
Rep 33
02-17-2025, 10:25 PM | #6 |
![]() ![]() 674
Rep 1,281
Yes.
02-18-2025, 10:20 AM | #8 |
![]() ![]() 674
Rep 1,281
Take it out and see. that’s the only way instead of asking questions on the internet.
02-18-2025, 10:28 AM | #9 |
Rep 33
02-18-2025, 11:55 PM | #10 | |
Rep 6
It can only be a loose connection on the fuel lines that you undid or the HPFP is f‘ed. I did the Valve cover a couple of months ago and just blindly fitted the hpfp, guess I was lucky. Good luck and don’t overreact. |
02-19-2025, 03:46 PM | #11 |
![]() ![]() 674
Rep 1,281
They may have other issues as they posted it on Facebook as well.
https://www.facebook.com/share/p/1HVt2BV5Rx/?
02-19-2025, 04:00 PM | #12 | |
Rep 33
02-21-2025, 11:04 PM | #14 | |
Rep 33
As far as I’m aware, there is a small cam roller with a tappet underneath the hpfp, as the cam rotates, the tappet moves up and down, you must lower the tappet into its lowest position by manually cranking the engine from the crank pulley nut to properly seat the hpfp before threading the bolts in, then evenly install the bolts to 12nm, don’t overtorque fuel lines. Last edited by Lr_zzz; 02-21-2025 at 11:06 PM.. |
02-22-2025, 10:12 AM | #15 | |
Rep 5
