09-11-2021, 04:52 PM | #1 |
Stage 2
Rep 25
f80,f82 M4/M3 Brakes installed on a 440i
Hello just wanted to share something I recently put together. Also the last thread I saw discussing this had a lot of people doubting it would fit.
The calipers are custom painted Protonic Blue metallic and they bolt right on! Rotors are from StopTech and they are made for this exact purpose. The front rotor is a 370mm and the rear is a 345mm. Note* Apparently m3 and m4 rotors will not fit because they use a different wheel hub. Front and real calipers are from an M4. Rotors are made for the 340i and 440i but are 370mm which fits the M4 caliper. |
09-12-2021, 02:06 PM | #4 | |
Rep 895
Belong560.00 |
09-12-2021, 03:08 PM | #5 | ||
Rep 1,325
09-23-2021, 02:23 PM | #7 | |
Rep 125
The only problem I have is that the Hawk 5.0 pads squeak/squeal when they get warm and nothing I've done stops it. I'm looking for a quieter ceramic pad. I put together a thread on it: https://f30.bimmerpost.com/forums/sh....php?t=1747129 |
09-30-2021, 05:06 AM | #9 | |
Rep 246
Who told you that bullshit that m3/m4 rotors wont fit... they fit without work to them.. to any F3* platform car, just the rears youll need the larger diameter handbrake for.. which 90% of the F3* have! Here ya go! front and rear full m3/m4 setup with oem discs rear! |
MTTH232.50 |
10-01-2021, 04:02 PM | #10 | |
Rep 125
The difference in the front is the location of the bolt holes on the steering knuckle. On the M3/M4, they're offset 5MM farther away from the center. I don't know if there's a difference in the rear, other than the mentioned parking brake. Last edited by SD Convert; 10-01-2021 at 04:13 PM.. |
10-02-2021, 06:59 PM | #11 | |
Rep 246
M3/M4 rotors will fit any f3* plug play on the front , rear only if you have the bigger diameter handbrake. That a 340mm or 370mm msport or mperformance caliper will not fit straight away icw the m3/m4 discs is another story |
10-03-2021, 08:46 PM | #12 | ||
Rep 1,934
Belong did that with an adapter. BMW did that by altering the knuckle for the m3. Two solutions to the same problem. I bet that option was cheapest for BMW than buying two separate castings from Brembo.
10-04-2021, 12:27 PM | #13 | ||
Rep 246
There is no 380 caliper... there is a 340mm caliper and a 370mm one.. the 370 is mperformance and at the same time the M3/M4 one, the knuckle is what makes the 10 mm difference on the m3/m4 not the caliper. With adapters you can fit both the 340 or 370 ( both need different adapters ) calipers to the F3* knuckle and a 380mm M3/M4 disc. O.P was stating the M3/M4 discs dont fit..here Quote:
Im selling my two front calipers along with the adapters for the M3/M4 discs next month as im upgrading to some bigger boys... Last edited by Belong; 10-04-2021 at 12:33 PM.. |
10-04-2021, 12:30 PM | #14 | ||
Rep 1,934
Belong560.00 |
10-04-2021, 12:38 PM | #15 |
Rep 246
10-04-2021, 04:51 PM | #16 |
Rep 1,934
Yes 40mm to 44mm pistons. I went through a caliper rebuild/powdercoated and found this put the hard way
Belong560.00 |
10-14-2021, 05:27 AM | #17 |
Rep 246
10-25-2021, 05:17 PM | #18 |
Stage 2
Rep 25
10-25-2021, 05:18 PM | #19 |
Stage 2
Rep 25
10-25-2021, 05:19 PM | #20 |
Stage 2
Rep 25
10-25-2021, 05:20 PM | #21 |
Stage 2
Rep 25
10-25-2021, 05:21 PM | #22 | |
Stage 2
Rep 25
