09-14-2021, 11:42 AM | #1 |
Rep 109
335d xdrive front brake judder again
I have a 66 plate drive 335d with the smaller size brake set up -
My local garage changed the pads and discs all around about a year ago and the brake judder is back. The cars re mapped so ive probably cooked the discs on the back roads where I live. can anyone offer any advice on a better disc and pads set up. |
09-14-2021, 05:17 PM | #2 |
Rep 193
My initial thought is that the brake judder is coming form uneven pad deposits from your driving (it sounds like you frequently go on spirited back road drives). What pads/rotors do you have now?
09-15-2021, 03:09 AM | #3 | |
Rep 109
if it build up of deposits can this be removed easily? |
09-15-2021, 12:25 PM | #4 | |
Rep 193
Someone else can chime in here but as far as I know, you can try to do a proper bed-in procedure for the brakes (you can find a bunch of specifics via Google but they mostly consist of a number of hard stops from 60 mph down to 10 mph). If that doesn't fix the issue, you may need to resurface the rotors. This is of course assuming the judder is due to uneven pad deposits. If it's something else neither of those options would fix the problem. |
09-15-2021, 03:15 PM | #5 |
Rep 8,503
If the judder has returned just through your normal use then it's most likely to be due to uneven pad deposits. Brake discs rarely warp.
As has been mentioned, you need to cool the brakes after hard use and before the car is stationary (at traffic lights or even parked). Re-bedding the brakes would be a good starting point - it should clean the surface of the discs (removing uneven deposits), will make sure that the pad/disc faces are completely mated, and should achieve an even transfer of pad material across the faces of the discs. Here's the bedding process that I use : Light use to warm the discs and pads. 10 x 60 to 5 mph; progressive and hard braking, almost triggering the ABS. Drive for a few minutes to cool slightly, then 5 x 90 to 10 mph, again almost triggering ABS. Then long drive to cool everything. Don't stop in traffic, and definitely no stopping with foot brake applied.
09-23-2021, 04:24 PM | #10 |
Rep 946
Mine is approaching that mileage and I get infrequent minor tremors on braking. Will get it looked at on the next service at my Indy.
Can the ball joint be changed on its own, or does it need a larger part renewed to achieve ? |
09-23-2021, 04:39 PM | #11 |
Rep 109
I'll tell you tomorrow as the garage has ordered a new one in.
Techno 9000521.00 |
09-28-2021, 11:36 AM | #12 |
Rep 109
All sorted the ball joint was causing the problem
Techno 9000521.00 |
09-28-2021, 03:54 PM | #14 |
Rep 109
Techno 9000521.00 |
