03-04-2019, 12:04 PM | #2597 |
Rep 6
Drives: BMW 518d
So I have been thinking about buying a screen from Avin to my X4. Basically what I would like to have is to upgrade the screen to a bigger size and occasionally use it to play video to the backrest monitors. What I dont want to have is to loose sound quality on the original BMW side and any bluetooth connectivity there as well. Is Avin upto my requirements?
03-04-2019, 02:45 PM | #2598 |
Rep 59
Anybody know a way to force update the MCU? I can't update it through the normal method. Used several USB sticks and micro SD but no luck. The system finds the file ask for conformation, then it says please wait with OK and cancel. And nothing happenes.
03-05-2019, 05:16 AM | #2599 |
Rep 59
Did your unit function properly with this connection. Your car is F31 isn't it? My CAN connectors are very different from yours and wondering if that is my problem. I have CAN1 to CANC, CANA to CANB and CAN2 is empty. |
03-05-2019, 05:58 AM | #2600 | |
Rep 59
03-05-2019, 06:08 AM | #2601 |
Rep 59
Did you solve this problem I have been told it might be the hood sensor which I do not have?
03-05-2019, 01:46 PM | #2603 |
Rep 59
Well some good news, I finally managed to update my MCU but only to a CCC one none of the others worked for me. Anybody know the main difference between them like the origin or something else. The version know has HW8 it used to be HW7 May be that has something to do with me and others having problem to update the MCU. I don't have original screen so a CCC MCU is fine at least that is my guess. It fixed one of my problems with the PDC radar not working.
I still have poor GPS fix may be I should downgrade the firmware. Any reports on GPS and new firmware? |
03-05-2019, 01:56 PM | #2604 | |
Rep 63
03-05-2019, 02:41 PM | #2605 |
Rep 59
It has a NBT connector but originally came with CIC MCU. My car E84 had no original screen just a professional radio. So far I had no problem but did not test it to much yet. I could not upgrade to any of the other MCU files. I don't know why suspecting something to do with HW7 or HW8 in the MCU version name.
03-10-2019, 04:24 PM | #2606 | |
Rep 1,048
i`m interessted in what it does now look exactly, and how it does work. there are different pictures of the pad at the internet. Kri |
03-12-2019, 07:35 AM | #2607 |
Rep 63
I just installed an 8.1 in my 2012 550i (CIC) and I also did not use the connections/wires above. Everything seems to be working but I did have to run the aux out to my center console to get sound on the Android side. So weird that some cars with CIC do not need the aux cable.
03-12-2019, 11:49 AM | #2608 | |
Rep 69
03-13-2019, 05:46 AM | #2609 | |
Rep 1,048
I have ordered one NBT version now, as CIC is not available anymore, but seems to doesn`t matter as the E Series CIC Controller does not have the PCB on top of the knob. I hop i will get it to work on the CIC controller somehow Kri |
03-13-2019, 03:32 PM | #2611 |
Rep 69
I used a voltage stepdown to 5 volt. And it has been working good sofar.
03-15-2019, 06:40 AM | #2612 | |
Rep 29
frederikdhauwers@hotmail.com Please send me pictures of the CIC version + cables + back of the screen with CIC insert. Thanks! |
03-17-2019, 11:14 AM | #2613 | |
Rep 1
03-19-2019, 10:01 AM | #2614 |
Rep 1,048
03-20-2019, 08:40 AM | #2615 | |
Rep 59
03-21-2019, 02:28 AM | #2618 |
Rep 69
You will se it on the print board, which is negative. I cant remember in my head. If you tke picture of printboard I will tell you.
