11-17-2018, 06:37 AM | #1 |
Rep 91
435d low rev issues
Hi all I have a 2016 435d and had a lack of low revs when pulling away from roundabout and dash put up drivetrain fault. Been to dealer and turned out to be a kink in a vacuum hose. Been ok for 4 days and now has intermittently returned. Just nothing when I put foot down.
Anyone experienced such issues before Thanks |
11-28-2018, 09:20 AM | #2 |
Rep 724
Have you found out what the problem is yet, have you been to the dealers again to check for faults, does sound similar to others who have mentioned egr valve, best of luck
11-30-2018, 05:19 PM | #3 |
Rep 105
Yeah sounds like possible EGR... I had the same a couple of months ago, 'drive line malfunction' etc when going to pull off.
I had a new EGR replaced under warranty at the time, with no mention of the cooler being a possible cause. ....and then just a few weeks ago I had the cooler replaced under the safety recall while in for service. |
12-06-2018, 04:29 AM | #5 |
Rep 341
A kink in the vacuum hose could only have been caused by human intervention during service / repair or you would have have this issue all the time. The symptoms you describe sound like the small turbo not being spooled at the correct time. I experienced just that when one of the vacuum pressure converters on my previous 535d failed ...no power low down then off it went as the revs rose. Sounds like you have a vaccum problem somewhere, either pump, vacuum line kinked or split [they must have been disconnected to become twisted], pressure converter [x2], or an actuator. BMW should be able to find this by simple process of elimination.
Keep us posted please. |
01-03-2019, 01:46 PM | #6 |
Rep 91
Update
Had report back from BMW and the following replaced. A new high pressure turbo, feed and drain pipes for the turbo, Bypass pressure plate, New pressure converter for the wastegate valve , oil and filter change. Picking car up tomorrow to drive 200 miles and see how it goes |
01-14-2019, 06:09 PM | #7 |
Rep 341
Wow, they seem to have replaced an awful lot, both mechanical and electrical components which would make me a little suspicious. That said I hope its fixed ......and that its a warranty job!
01-16-2019, 01:17 AM | #9 | |
David
786
Rep 2,009
Did they just put a new cooler in with the existing part#? |
01-18-2019, 05:18 PM | #10 | |
Rep 105
That is a very good question!
I was informed about the recall on the cooler when booking the car in for regular service, and to be honest didnt think much about it, presuming that the issue was being resolved via replacement with a non defective part. I'll dig out the invoice when home and see part# against it. Any idea what the pre recall part# should be ? Quote:
01-18-2019, 06:39 PM | #11 | |
David
786
Rep 2,009
02-01-2019, 05:39 PM | #12 |
Rep 341
Niicckk..... its just that they replaced almost everything around the large turbo, both mechanical and electrical [pressure converter] which would perhaps suggest that they were unsure exactly what the issue was so changed everything hoping to get lucky. Its an approach i have come across with BMW before but being old school I got them to explain their approach and by applying a simple, logical order to diagnose the problem [rather than plug in and fit all new parts to anything that had an error code!] it was simply a pressure converter failure on my previous 535d causing the boost problem rather than complete turbo failure as they suggested...... fixed for a fraction of their quoted price.
02-01-2019, 05:59 PM | #13 |
Rep 1,803
Assassin hit the nail spot on the head.
02-03-2019, 11:48 AM | #14 |
Rep 91
Thanks for the reply. Oh they definitely didnt know what they were doing. All I kept getting told was they have to follow there puma system which technicians follow and feed back test data
