01-28-2019, 09:15 AM | #1 |
Rep 526
Very faint white smoke coming from passenger side of engine bay.
Yesterday i went for a nice drive and got the oil temp up for about 15-30miles. Came home and popped the hood to see very very faint white smoke coming from the right(passenger side) of the engine bay. The smoke was completely gone after about 1 minute. Oil level is still at max and no CEL's or errors. The smoke is so subtle and faint that I cant even capture a video of it and only noticed it when i popped the hood.
Any idea what this is? |
01-28-2019, 09:35 AM | #2 |
Rep 60
If you're driving a turbo N55, there's the possibility it's an o-ring on the turbo. Mine had the same symptoms. Talk to your service advisor, they seem to be aware of the problem.
01-28-2019, 09:38 AM | #3 |
Rep 526
01-28-2019, 10:40 AM | #4 |
Rep 5,369
Likely your valve cover is leaking and the oil is dripping onto the downpipe and smoking.
The forest was shrinking, but the Trees kept voting for the Axe, for the Axe was clever and convinced the Trees that because his handle was made of wood, he was one of them.
01-28-2019, 10:47 AM | #5 | |
Rep 937
Turbo is more expensive If you can, get under the car carefully look behind the engine for oil. I saw a fresh spot through a little gap (i didnt take off the under tray) and took it in. Warranty VCG.
Hi
01-28-2019, 11:07 AM | #6 |
Rep 1,499
This!! Look for leaks around the valve cover where it mates to the head and look for oily residue on the turbo side of the block.
01-28-2019, 12:05 PM | #7 |
Rep 526
Is there anything you guys can see? I think it might be VCG too but I don't see any leaks? The light smoke was coming from this side. I'll take some better pictures when I'm home but I just drove to work and school and there was no smoke
01-28-2019, 01:38 PM | #8 |
Rep 937
Yeah those drops on the cat are what my car had...
I got mine replaced under CPO (the gasket not the cat). Just take it to your dealer and tell them "fix plz"
Hi
02-15-2019, 03:03 PM | #9 |
Rep 41
Smoke from engine (AH3)
Hello, my 2013 BMW ActiveHybrid 3 has some smoke coming from the engine bay recently. It has around 65k miles. I took it to BMW service and they can't detect/can't find what is wrong. Help please.:
Lex G
02-16-2019, 11:41 PM | #10 | |
Rep 260
If you've got the tools and skill, you might want to pull out the spark plugs, particularly the two closest to the firewall. A leaking VCG can sometimes leak oil into the spark plug opening, soaking the insulator in oil. You'd be able to tell pretty easily if oil's leaked inside there, maybe just from pulling the ignition coil off the plug. |
02-17-2019, 11:58 AM | #12 |
Rep 526
02-17-2019, 12:01 PM | #13 | |
Rep 526
02-19-2019, 12:43 PM | #14 | |
Rep 439
Drives: 2016 M235i Xdrive 8A
I had it replaced and the mechanic said it would keep smoking for a while because its impossible to clean all the oil molecules off the metal surfaces. It still smokes when I drive the car really hard and I am not sure if he actually fixed it or if something is still leaking again?
SOLD 23K Black 2013 F30 335XI 8A Msport | BMS Intake | BMS Front Mount | VRSF Charge Pipe | BM3 Tune
2016 F22 M235 8A HK NBTevo | CTS HEX Intake | CTS Chargepipe | Gplus Intercooler | VRSF DP | BM3 Stage 2+ | 18" CSL Replicas | XHP X-Delete |
02-19-2019, 01:39 PM | #15 | ||
Rep 526
02-25-2019, 12:18 PM | #16 |
Rep 526
UPDATE:
Took it to dealership and it was indeed VCG leak, they are replacing it under warranty! This was at 47k miles. So you guys in the 40k range be on the look out. He said they use some kind of cleaner to remove any remaining oil and that after the test drive they are gonna check for oil leaks once more |
