02-19-2019, 12:42 PM | #1 |
Rep 585
Stronger clutch for 340xi?
All, I feel like the clutch is kind of weak on my 340xi, and as I consider tunes like mission performance, I would like to know - Is there a popular aftermarket clutch with a little bit more bite and more positive engagement? Would an m3 clutch work?
Am I going to have problems with my x-drive drivetrain if I install a stronger clutch and a tune? Thanks |
02-19-2019, 07:52 PM | #2 |
Rep 1,452
We're nowhere near the power numbers where an aftermarket clutch should be considered with just the tunes. If you're running upgraded turbos + meth + etc, then yeah. Probably a 550i/335is clutch.
2022 CT4-V Blackwing 6-speed
02-21-2019, 01:18 AM | #4 | |
Rep 1,452
I'm not sure on the F80 M3 clutch upgrade. Looks like it's not possible, and while stumbling on this thread, it confirmed that the 335is/550i clutch upgrade is indeed a direct replacement for the F30 335i (which our 340i uses the same transmission): https://f30.bimmerpost.com/forums/sh....php?t=1479217
kern4174446.50 |
02-25-2019, 12:58 PM | #6 | |
Rep 115,980
The OEM IS/550 clutch is better then original but won't reliably hold that kind of power. Mike |
