02-22-2019, 01:14 AM | #1 |
Rep 379
So my tires are almost out of tread so I'm planning to buy new wheels for this summer. My car is a 2014 msport 19 inch brakes. It came with 225/40/19 and 255/35/19. I want to buy wheels which are a squared setup, 19x8.5 and tire size are 245/40/19. They should fit no problem right? Also will this affect my speedometer with speed accuracy?
edit; car isn't xDrive. |
02-22-2019, 06:09 AM | #2 |
Rep 5,140
Offset (ET) is needed for a more correct answer.
Since 245/40-19 is slightly taller than OEM size it's more important with correct offset. 32-35 would be a good starting point. The speedo will be more accurate with the new tires, since it reads high from factory! |
02-22-2019, 08:58 AM | #3 |
Rep 379
Offset is 35. So running a squared setup is not a problem?
02-22-2019, 06:14 PM | #6 |
Rep 25,989
A 19x8.5 ET35 with 245/40/19 should be fine. We have a handful of customers who run those exact specs without making mention of any rubbing. I've also seen 255/35/19 on the same wheel specs.
VMR|Wheels | 714.442.7916 |
sales@velocitymotoring.com | www.velocitymotoring.com | facebook | flickr | Instagram |
bloodline12996.50 |
02-23-2019, 01:27 PM | #7 |
Rep 379
Since my car came with high performance summer tires will there be any differences with going performance all seasons and would I need hub centric rings?
