04-27-2017, 08:18 AM | #23 |
Rep 80
Is this internals build needed for regular stage 1 and bellow 290hp tune?
What are basic hardware modifications for n20 to be long term reliable on track. I know in theory that stage 1 doesn't require such mods, but there where some engine failures even with stock parts. There where problems with plastic chargepipe, oil starvation and similiar stuff. What would be approximate price of engine rebuild in independent shop and why do some people have to replace whole engine instead of rebuild? What is price of used n20 engine? I'm talking about daily driver with 5-10 track days /year, but heavy tracking in those stints |
04-27-2017, 08:34 AM | #24 | |
Rep 188
Drives: 2013 328i xDrive
n20 are suppose to be a PITA to rebuild. Check out this thread has some info good info on the engine cost and rebuild: http://f30.bimmerpost.com/forums/sho....php?t=1328727 |
04-27-2017, 08:42 AM | #25 |
Rep 80
I'm talking about fairly conservative tune, something like 280-290hp and not more than 400nm (295lb/ft), but even if amount of track days is bellow 10, I still think that they are pretty hard for engine.
This rebuild cost is extremely high, used engines on ebay/car-part.com are around 4k cheapest and to insert them in car is probably not more than 2k. In case of failure, can some parts be used from old engine, or it is completely worthless? Sorry for bad English Last edited by ///CSL; 04-27-2017 at 08:53 AM.. |
04-27-2017, 10:55 AM | #26 | |
Rep 188
In case of failure, know one would know until the failure occurs. Depends on the internal damage. |
07-25-2018, 07:01 AM | #28 | |
Rep 1,074
Instagram: M2_Medusa
07-28-2018, 11:29 AM | #29 |
Rep 3,752
Building an engine is not the problem...it is the cost to performance ratio is. If anyone willing to spend money it can be done. My old day with an S14 with fully built SR20DET ( ahem cost me $7k) netted me 541hp on race gas and 451 on 91 california water.
It can be done but how much🤔 |
ceedawg467.50 |
05-26-2020, 10:56 PM | #30 |
Rep 12
Hey all. For those interested, check out 3 Aussie lads doing N20 engine rebuilds. Stay tuned for more progress updates and videos.
navardi Andypants Nomadic Tuned This is a part 1 Video of Ken's BMW N20 328i Build Part 1. 2014 N20 with 95000KMs Engine Build by Brintech Customs Parts supplies by Flashtuned Custom tune to be done in collaboration with Brintech Customs and Nomadic Tuned. Current mods: Bm3 OTS stage tune for 98Ron xhp stage 3 for 8hp-zf automatic transmission Afe 400cpsi highflow downpipe Upgraded vrsf intercooler MST Cold air intake GFB DV+ Stock OEM turbo running 22.5 PSI boost Parts to be installed: Mosselman stage 1 turbo with new upgraded oil line feed Forged pistons, Rods and Bolts (CPCarrillo, Maxpeedingrods and ARP) upgraded main and rod bearings All new OEM seals and gaskets for preventative maintenance new upgraded timing chain and assembly Catch Can upgraded charge pipes Block work to be done: Cylinders to be bored, sleeved and honed Semi closed deck design with Dowel inserts Upgraded cut ring Gasket Upgraded Head Studs Project Goals: Sleeper 328i to be used for Daily driver so reliability is key. Could have upgraded to an M3 but wanted a project to take the N20 a little further. There is not much information on the N20 and want to be able to share what these N20's are capable of. Will covert into a track car down the line but would then to to look into fabricating a new Baffled oil pan to prevent oil starvation. Targeting an extra 2 PSI of Boost to take it to 24.5 PSI. Should be looking a some really good gains once built and a custom tune applied. Budget: A little bit of background in regards to the build and choices on parts. This particular project is not meant to be a budget project but neither is it supposed to be an expensive one. What we've tried to do is through research on parts look at the benefits of putting together a solid reliable build within a particular budget. We could have got all the same parts from the same manufacturers at the top end but did not make sense for what we wanted to achieve. We put this together to appeal to a particular price point and open up possibilities. Stayed tuned 😎 Last edited by Nomadic Tuned; 05-27-2020 at 04:21 PM.. |
05-27-2020, 04:22 PM | #33 | |
Rep 12
A little bit of background in regards to the build and choices on parts. This particular project is not meant to be a budget project but neither is it supposed to be an expensive one. What we've tried to do is through research on parts look at the benefits of putting together a solid reliable build within a particular budget. We could have got all the same parts from the same manufacturers at the top end but did not make sense for what we wanted to achieve. We put this together to appeal to a particular price point and open up possibilities. |
05-28-2020, 10:04 AM | #36 |
'12 BMW 328i, '07 SKY, '06 Ion RL, '73 F250, etc.
Rep 5
Subd to the channel. Looking forward to seeing the results. I have an N26 rebuild on my plate in the near future so I look forward to seeing more info on the process others take.
05-28-2020, 11:50 PM | #37 | |
Rep 176
https://f30.bimmerpost.com/forums/sh...6#post24135816 |
06-14-2020, 03:49 PM | #39 |
Rep 3,679
Thanks for posting, nice to see it coming along.
Can't wait to see it all come together!
06-14-2020, 05:14 PM | #40 |
Rep 3,679
Question for you just popped into my head. With all that engine work, I'd imagine that the Mossleman turbo becomes a weak point right? In that the engine will be able to hold a lot more power than what that turbo can produce. Any reason you didn't go for a stage 2 or bigger turbo?
06-15-2020, 05:16 AM | #41 | |
Rep 12
It's allowing us to open up a number of build possiblities for the N20 platform. I will be looking at the next stage of this build when I decide to track the car. That will come with an upgrade to the turbine wheel, lpfp and custom oil pan to name a few key upgrades. Btw the mosselman msl 35-45 stage 1 turbo has a compressor wheel size slightly larger than MHI and Dinan stage 1 turbos so will flow slightly more air For now as a daily on 93oct (98ron in Australia) this should be a fun sleeper targeting 380-400whp. |
rjd_F301999.50 BettyFkinCrocker180.00 |
06-15-2020, 07:09 AM | #42 | |
Rep 3,679
Another question while you're here if you don't mind. Do you have any concerns about the other driveline components like the diff, transmission, axles etc.? I wouldn't personally be too worried about the transmission, especially the 8AT, but what do you know about what these stock diffs can take?
06-15-2020, 12:58 PM | #43 | |
Rep 191
Just look at the B58, folks are pushing 600+ whp/wtq with no trans issues. Driveshafts have been failing before anything with the trans fails. I think I've seen one diff explode on one of those 600+ cars. But considering the amount of B58s in the 450-500+ range I've not seen any other diff failures and no trans failures. Just a bunch of driveshafts.
IG: @derringerF10
2016 550i RWD N63TU 8AT | Catless Downpipes | BaskiSpeedworks STOCK TURBO RECORDS 1/4: 10.90@128 60-130: 7.43 |
rjd_F301999.50 |
06-15-2020, 07:02 PM | #44 | |
Rep 3,679
