05-24-2020, 11:45 AM | #1 |
Rep 110
What do you do in an automatic at traffic lights
Hi
I have a new 4 series automatic and I don’t like stop/ start or keeping my foot on the brake. So what do others do at stop lights? Pete |
05-24-2020, 11:49 AM | #2 |
Rep 1,993
Drives: F30 335d
Keep my foot on the brake at lights.
In a long queue that isn't moving I might put it in Park to give my foot a rest. |
05-24-2020, 11:56 AM | #3 |
Rep 3,967
05-24-2020, 12:21 PM | #4 |
Rep 627
Knock it into sports, pull the left paddle into manual and 1st and then burn off the loser next to me at the lights.
adam.b189.00 ZedsRedBaby1762.50 Lincoln61746.50 Junebug851615.00 Silverlining_m21734.50 Eimal22.00 Russbmw680.00 |
05-24-2020, 12:52 PM | #5 |
sunjas
Rep 97
I always put the car in 'N' and foot on brake/handbrake.
This disengages the gearbox and saves the gearbox wear as in 'D' the car is always trying to move forwards. |
05-24-2020, 01:20 PM | #6 |
Rep 2,047
Is that sort of wear significant over time? Most of my journeys are through Central London so a lot staet/stop
05-24-2020, 01:27 PM | #7 |
Rep 1,993
Drives: F30 335d
With the foot on the brake the only thing happening is that the impeller part of the torque converter (the part physically attached to the flywheel) is moving in the fluid, but that's about it. Not exactly going to wear anything out at idle speed!
if I've helped - an Appreciate would be, er, very appreciated!
vtown99.00 |
05-24-2020, 01:28 PM | #8 |
Rep 496
05-24-2020, 01:29 PM | #9 |
Rep 19,982
Why don't you like it?
05-24-2020, 01:31 PM | #10 | |
Rep 19,982
I don't think automatics would be nearly as useful if they did wear doing this as this is one of the main benefits.
05-24-2020, 02:05 PM | #12 |
Rep 680
Watch the following video:
https://www.youtube.com/watch?v=6zzEtxJkC7Y if you don't want to watch all of the video: https://youtu.be/6zzEtxJkC7Y?t=435
Current: None
Previous: E92 320d, E92 LCI 330d F30 330d, F32 440i Last edited by Xplosiv166; 05-24-2020 at 02:11 PM.. |
05-24-2020, 02:06 PM | #13 |
Rep 1,158
05-24-2020, 03:07 PM | #14 | |
Rep 15,858
The fact residual torque is reduced to about 10%, also reduces fuel consumption while stationary with engine running. You will still feel some drag (or creep) as you release the brake pedal, this is normal, as NIC is automatically engaging drive, ready to move off smoothly. |
05-24-2020, 03:12 PM | #15 |
Old Fart
361
Rep 694
Does this also function if the handbrake is on? I don't like sitting at the lights holding the pads onto the hot disks so I just pull the handbrake on but leave it in D.
The doctors said it's OK to listen to the voices..... just don't do what they tell me
05-24-2020, 03:22 PM | #16 |
Rep 5,681
I don't like stop/start and had it coded to default to "off" in my F31.
In traffic what I do depends on how long I think I'm likely to be stationery; only a few seconds I leave in drive and hold on the footbrake, otherwise I put it into either park or neutral and secure with the handbrake. Could just hold in drive on the footbrake but I always think it's slightly inconsiderate to make the person sat behind have to stare at my brake lights for an extended period, especially if it's a dull day or dark! |
JD64270.50 |
05-24-2020, 04:58 PM | #18 |
Beemer Heaven
462
Rep 2,941
Drives: BMW M4 Competition
Garage List 2018 BMW F82 M4 Comp [0.00]
2017 BMW F30 330d M ... [0.00] 2014 BMW F30 330d M ... [0.00] 2009 BMW E90 330d M ... [0.00] 2006 BMW E90 330d M ... [0.00] 2002 BMW E46 325i S ... [0.00] |
Your discs would never be that hot to worry about with just normally driving even at high road speeds.
Scott
2018 BMW M4 Competition 2019 Mini Countryman Cooper S : 2008 Mini Cooper |
TiredGeek360.50 |
05-25-2020, 03:43 AM | #19 |
Rep 110
Well thanks to all who have added to my post. I’ve been at stop, in D with the handbrake on but it still did not feel the best. My other car an E Class..sorry! has an electric brake, you just push a little bit harder on the foot brake once at stop and it’s in Hold until you touch the peddle. Anyway the 4 is a lovely car to drive, when we can!
05-25-2020, 04:09 AM | #20 | |
Rep 8,780
Drives - 2020 LR Discovery HSE-L Previous - 2019 LR Discovery HSE-L // 2016 F36 440i // 2009 E90 320D SE |
05-25-2020, 04:48 AM | #21 |
Rep 620
Never put it in neutral (unless being towed). Park if it's a long wait, but I have coded the start stop off and just use the foot brake.
Current - 2018 F32 430d M Sport+
Previous - 2013 F30 320d M Sport Previous - 2008 E92 320d SE |
05-25-2020, 05:23 AM | #22 |
Rep 2,274
Does the 4 series have Auto Hold?
I've coded start stopp off and sometimes use Auto Hold. Other times its just foot on the brake.
IG: project540ix
G30 540i xDrive / Stage 3 via BM3 / xHP Stage 3 / Pure 800 Cast Turbo / 5" Catted Downpipe / MST Intake / Remus Exhaust / MSS Springs / 19" JR SL01 & Conti SC7 / 20" BBS CI-R & Michelin PS4S / F90 Sway Bars & Braces / Lots of Gloss Black |
