BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Attempting 6WA retrofit. Is this guide still relevant?
proTUNING Freaks
      04-14-2021, 09:35 AM   #1
Sigge
Sigge's Avatar
156
Drives: BMW 420d xDrive 2016
Hello!
Got hold of a virginiszed 6WA cluster and will try to code it in to the car myself. The car is a 2016 420d.
I have not done any coding with esys until now, but I have read up a lot on it and feel comfortable with stuff like this as long as there is guides to follow
So, I am wondering wether this guide mentioned in this thread still is relevant? It's from 2013 and a lot might have happened since then. Thinking mostly of software versions etc
https://f30.bimmerpost.com/forums/sh....php?t=1115403
Cheers
      04-14-2021, 10:48 AM   #2
atzebmw
Drives: Tesla Model 3
No good idea to use this guide.
The guy is flashing the Kombi what you don’t need to do.
You have to install it and code it.
      04-14-2021, 11:33 AM   #3
Sigge
Sigge's Avatar
156
So flashing is not part of the standard procedure? Why does he do it in the guide?
      04-14-2021, 01:49 PM   #4
atzebmw
I really don‘t know why he is flashing the kombi.
As with most retrofits, this is not necessary at all.
You can / should maybe do that if the software of the Kombi is too different from the rest of the car. But usually simple coding is enough.
      04-14-2021, 02:05 PM   #5
Sigge
Sigge's Avatar
156
Thanks for letting me know! That means it hopefully won't be as advanced as I first thought. But it also means I need to do some more research.
