01-30-2015, 10:47 AM | #1 |
Launch Control Specialist
41
Rep 222
Drives: 2018 Mineral White BMW M3 CP
Exhaust Flap Actuator Fuse
So after many issues with my exhaust it seems my actuator may not be functioning. Any idea where the fuse that handles actuator is on a 2015 F36 435i Gran Coupe?
01-30-2015, 09:45 PM | #2 | |
Rep 425
CG |
larrylarry188.50 haagm58809.50 |
02-11-2015, 11:01 AM | #3 |
Rep 2
Same thing - 435i GC
I have the same problem - it looks like the flap don't open at all: warm engine / hight rpm / sport or sport+ mode... the left exhaust outlet is clean like new..
Today I talk to my BMW service partner - they say that the exhaust flap don't have a separate fuse. Actually I can't really belive that so I will go next week to the service partner to check the car.. If you have any news, please let me/us know |
02-11-2015, 11:07 AM | #4 | |
Rep 1,961
02-11-2015, 11:31 AM | #5 |
41
Rep 222
Let me know what they say. I am almost 100% positive my flap is not functioning. I need to get a GoPro to be certain it seems. The dealer has been no help.
02-11-2015, 11:44 AM | #6 | |
Rep 2
My was after 5min. driving still inside (warm engine / sport+ mode) |
02-11-2015, 12:28 PM | #7 |
41
Rep 222
That was a hell of an idea. My flap does open. Shot the ball out the driver tube when stepped on it.
02-11-2015, 02:05 PM | #8 |
Rep 1,961
Dealer was no help. They didn't even look at it. Made me make an appointment with a loaner so they could check it more thoroughly. We'll try again in 2 weeks when that appt is.
01-25-2016, 06:31 PM | #9 |
Rep 33
11-22-2016, 11:16 AM | #10 |
Rep 1,829
Drives: Alpina G21 D3S
I have the same issue as some of you guys. My flap doesn't appear to open at all, regardless of comfort/sport/sport+ mode or revs. BMW tell me that the flap moves when they plug in diagnostics, but it doesn't work at all during normal operation. It's going back in again to try and resolve.
12-15-2017, 01:32 AM | #11 |
Rep 4
https://www.ecstuning.com/b-genuine-...r/18308632154/
Read the product details.... most likely your actuators are dead !! |
12-15-2017, 06:13 PM | #12 |
A family of bimmers
2745
Rep 7,741
the flap will open above 2k rpms and during cold start. you should hear the flap close like a minute or two after the cold start. I too have had the same issue with ice build up on the left tip and thats because i was in comfort and not over 2k to open the valve.
12-17-2017, 06:00 PM | #13 |
Rep 16
Flap has now been permanently open by the dealer! The Canadian cold winters don't leave us much choice. Unless you have a heated garage, that's the way to go!
12-18-2017, 03:17 AM | #14 | |
Rep 937
Hi
04-06-2018, 03:01 PM | #15 |
Rep 271
My flap stays open full time and since I have a full catlessturboback exhaust system, cold starts can be quite loud. I replaced the actuator with a new one, but this did not resolve the issue. Does anyone know where this darn fuse is located so I can check it? Thanks!
2021 M550i
BMS Pedal tuner JB4 |
05-22-2018, 11:07 AM | #17 |
Rep 191
flap is fuse 146 (shared with park assist)
in the trunk http://tunjul.com/wp-content/uploads...s-adorable.jpg left column, 4th fuse down i unplugged mine with the flap open, so flap is always open
2012 335 2016 435 2019 440 GC |
haagm58809.50 |
05-22-2018, 03:45 PM | #18 |
Rep 4
Mine fuse number 146 is correct. Problem is different, because flap never close. I go in eco and comfort mode and she always open. I like loud exhaust, but my baby no... I dont know why she dont close...
06-22-2018, 09:14 PM | #19 |
Rep 32
I’m actually having the same issues, so I’m trying to figure this out also. Not a fan of keeping it always open
07-06-2018, 11:45 AM | #20 |
Rep 2
Fuse for exhaust valves
I tried to disconnect my exhaust valve on my 2018 340 but the wires on very tight and I dont want to break the clips.
Does anyone know which fuses to pull to disconnect the valves? |
07-08-2018, 01:27 PM | #21 |
DisplacementReplacement
394
Rep 1,095
I can confirm the exhaust flap is open when car is cold and not started. I simply put a small screwdriver in top of connector and pulled backwards, it disconnected with a little effort and then I zip tied connector as high as I could. Seems fine and very open.
2020 X3M /// MHD Tune
Prior Bimmers 2017 240XI Hybrid / FBO / MHD E40 2015 235XI FBO / MHD E30 2009 335XI FBO / COBB / E30 |
08-10-2019, 08:30 PM | #22 |
Rep 331
Drives: M140i F20 LCI-2
Open and close exhaust flap
This is my suggestion to opening and closing the exhaust flap without losing Parking Assistant by pulling fuses 146 and 147 (the two with a red line shown below), or disengaging the plug to the actuator.
https://f30.bimmerpost.com/forums/sh...6&postcount=35
Current: Alpine White M140i F20 LCI-2, 250kW/335hp, 2018.
Sold: Melbourne Red 340i F30 LCI Luxury Line MMPK - 265kW/355hp, 2016. Sold: Alpine White 123d e82, 2010, 150kW/204hp. Last edited by DrGadget; 08-10-2019 at 08:37 PM.. |
