12-20-2021, 07:11 AM | #1 |
Rep 29
N55 surging/pulsing while cruising
I’ve seen this topic on the E90 forums so I apologize in advance if it has a thread here.
My 2012 335I 118000Km has recently been pulsing while Accelerating, it feels like I got off the gas for a split second then goes back to accelerating to no gas etc when lightly speeding up to highway speeds it’s very noticeable from 60-80Km/h it doesn’t do this under hard acceleration. Car is FBO and Stage 2 bootmod3 but this issue has only occurred recently mods have been done for awhile. It still does it on stock map aswell. Anyone experience this or know probable causes? Last edited by MasonP95; 12-20-2021 at 06:47 PM.. |
12-20-2021, 08:04 AM | #2 |
Rep 849
Drives: BMW 435i
I have a '16 435 with the N55 and 54K miles. Just took it for a 800+ mile road trip this weekend and didn't experience anything like what you describe.
I've taken it on several trips like that of the same length recently which would have given me a chance to have felt/experienced some form of surging, but I didn't notice any. I can't offer any help with the diagnosis, but can provide a data point of my N55 not doing what you're experiencing.
01-06-2022, 12:56 AM | #3 |
Rep 61
I have a 16 340i and am experiencing exactly what you are describing. But for me it doesn't happen every time but often enough that I noticed it being an issue. Very interested to hear from people that have had the issue and found fixes. Car is stock with 62k miles.
01-06-2022, 08:15 AM | #4 |
Rep 849
Drives: BMW 435i
Just thinking out loud...
Do the RPM's fluctuate enough to see it on the tac? I'd think the needle would flutter a bit if the engine was cutting out even for a brief second. Could it be transmission rather than engine? The above poster with a B58 appears to be seeing the same conditions as the OP with an N55, so it could be something else which causes the sensation. Along those lines, are both cars automatic? Just trying to find some commonality.
01-06-2022, 09:13 AM | #5 |
Rep 71
Drives: 2016 435i xDrive Gran Coupe
My 2016 F36 does that occasionally, but only when the AC is on. I thought it may be the compressor or the compressor clutch.
The fluctuation can be heard and felt but doesn't show up on the tach. Mine is an automatic, with a MHD stage 2+ tune. |
01-06-2022, 12:18 PM | #6 | |
Rep 7,602
01-06-2022, 10:13 PM | #7 | |
Rep 61
01-06-2022, 10:15 PM | #8 |
Rep 61
How long have you had this issue? I’m genuinely hoping that a CEL pops up and gives me a code so I know what I’m looking for at this point but I don’t have any codes.
01-07-2022, 08:37 AM | #9 |
Rep 71
I first noticed the fluctuation late in the past summer, when the AC was working hard. No codes or CELs, had them checked last month. Car has 77,000 miles, original belt and compressor.
01-07-2022, 12:19 PM | #10 |
Rep 61
I’m having my Indy shop go over the car and see if they can find anything. I just had my spark plugs replaced so they think it might be one of the fuel pumps. So strange it doesn’t give any codes seeing there’s a billion sensor in these cars nowadays.
01-08-2022, 02:39 AM | #11 |
Rep 18
I have a 2013 335xi with 85k and started to notice this exact thing happen two summers ago. I've felt it only a handful of times since. Most recently last week.
It always happens while I'm cruising 65 on the freeway and feels like a quick pause, and can feel it in the pedal as well. |
01-08-2022, 05:26 PM | #12 |
Rep 4,876
My 2008 335 had that. When I had it in for the HPFP recall, they swapped a bunch of injectors, and then it was fine.
Sounds like a lean surge which usually points to a injector / fuel pump issue. |
01-09-2022, 12:48 AM | #13 | |
Rep 61
01-09-2022, 12:50 AM | #14 |
Rep 61
01-09-2022, 07:37 AM | #15 |
Rep 4,876
Mine was a n54, and yeh, it was a known technical service bulletin. Thinking about it, I got the issue right after the injector/HPFP was replaced for a short while. Could have been due to it learning fuel trim values.
01-09-2022, 02:56 PM | #16 |
Rep 61
I did also get my cats replaced. IDK if that would have anything to do with it. Maybe the cats need to broken in to flow properly? Cant' imagine that being more than 50 miles though.
01-12-2022, 08:30 PM | #18 |
Bimmer Nut + Software Dev
553
Rep 802
Drives: 2018 Audi S3 IE Stage 1
It could be your TMAP sensor located on your charge pipe. Mine got damaged when the OEM charge pipe blew up and I've experienced the same symptoms you're describing.
Current: 2018 Audi S3 IE Stage 1
Past: '08 Infiniti G37S, '87 Porsche 944 Turbo, '13 328i, '15 M235i, '15 F80 M3, '16 M235i, '15 335i, '17 X5 xDrive35i @whoismorggan |
01-12-2022, 11:52 PM | #19 |
Rep 61
Did you get a CEL for it? Also sorry for my ignorance but is the TMAP sensor the same as the MAP sensor?
01-13-2022, 07:30 AM | #20 | |
553
Rep 802
01-16-2022, 07:14 PM | #21 |
Rep 61
Gotcha. With all the sensors in these cars I am now reluctant to change anything unless a code or CEL pops up for it. The issue doesn’t bother me enough and doesn’t happen frequent enough for me to trial and error all these fixes.
12-15-2022, 03:47 PM | #22 |
Rep 2
Has anyone found a solution for this problem yet? I noticed in another forum with the same issue, the guy took it to the shop and they updated his software. He said that solved the issue.
