BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > F series adaptive - Bilstein damptronic PnP dampers
Studio RSR
      05-29-2020, 08:08 AM   #397
GSband
GSband's Avatar
Drives: BMW F30 335i (05/2013)
Hi,
OEM variable dampers had a huge spread between pos 1 (comfort) and pos 2 (sport). Perhaps for marketing reasons ("I can really feel the difference"). In pos 2 the car would just bounce up and down. Pretty useless if the road isn't completely flat.
On B4 DT the difference between pos 1 and 2 isn't that big.
Pos 1 is more sporty than OEM pos 1, while still comfortable enough.
Pos 2 is less sporty than OEM pos 2, so the car doesn't bounce, I'd call B4 DT in pos 2 sporty-efficient.
Sorry, I can't comment on MSS products. It took me some time already to describe the suspensions I've tried out. I'm not gonna venture into comments on products I don't know.
Cheers,
GSband
Solid67187.00
      06-05-2020, 01:34 PM   #398
Matthewricha
Drives: M235i
Very interesting reading the experiences of someone who has gone through OEM, B6 and B4. I have experienced OEM adaptive (which maybe tauter than non Mlite cars? Certainly different PN's) and now have B4 Damptronic dampers. No experience of B6'. After all the reviews of harsh ride with B6, decided to go B4, but I can see how a B6 would yield a very sporty handling. For me I too wanted a compromise for comfort and the B4's for me address the shortfalls of the OEM shocks. It seems reviews of the B6 DT's are rather subjective as on a UK forum some have said they are more compliant and comfortable, but sporty and handle really well. Perhaps they are used to a fast road setup. I sometimes wonder if I should have spent a little extra and gone with the B16 damptronic kit for height adjustablility. I guess one can add MSS springs to get a similar effect with B4 DT, albeit without being matched springs.
I went to visit MSS in March and test drove their M140i. The springs where remarkably compliant considering how low the car was on passive OEM shocks.
      06-05-2020, 03:21 PM   #399
M140_BCS
M140_BCS's Avatar
238
Drives: 440i Gran Coupe
Recently replaced the OEM adaptive dampers and springs on F36 440i RWD.
Went for the B6 Damptronics with Eibach pro springs and F8X bumpstops.
In comfort setting the B6 are definitely stiffer but more compliant, before it felt like a boat, too soft and bouncy.
In sport setting it's quite harsh on the UK roads but still manageable.
I only use the 440i as a weekend car so it works for me but I could see it being hard work as a daily driver when in sport.
Standard OEM dampers and springs.
2017 440i F36 - Drexler LSD - B58TU HPFP - MHD Stage 2 - xHP - 200 Cell DP - MPE
      06-05-2020, 03:22 PM   #400
M140_BCS
M140_BCS's Avatar
238
B6 Damptronics, Eibach Pros (E10-20-031-02-22) and F8X bumpstops.
      06-05-2020, 03:41 PM   #401
cfm56d7b
M140_BCS, thanks for sharing. Great car, by the way!
To what extent do you think Eibach Pro springs contribute to a harsher ride in Sport setting?
      06-05-2020, 04:06 PM   #402
M140_BCS
M140_BCS's Avatar
238
Thanks.
Not too sure on the Eibach pro springs making the ride any harsher in sport, possibly a touch.
Current B6 sport setting feels similar to the Bilstein B14 coilover passive setup I had on a previous F20 M135i.
Think I would have gone for the B4 Damptronic if buying new after reading the reviews but I got the B6 used for half price with a few hundred miles covered.
cfm56d7b5886.00
      06-06-2020, 04:12 AM   #403
Matthewricha
Drives: M235i
Agreed, your 440i looks lovely! The rear end is so much better than the 2 series! Miss my old E92 335i for the shape. Your Eibach springs seem to give just the right amount of lowering and a level stance. I had Eibach Pros on my e92 335i and there was more of a raked stance.
Here is my car with B4 DT and BMW M Performance Springs:
OEM vs B4 DT:
M140_BCS237.50
      06-06-2020, 08:34 AM   #404
M140_BCS
M140_BCS's Avatar
238
Thought it might end up with a raked stance but sits well, big improvement over the standard 4x4 look.
Last on the list of mods is some decent aftermarket 19s. One of the rear 442M has started with white worm under the clear coat from round the centre cap...
Possibly looking at BBS CI-R or CH-R?
I agree with you on the E92 335i, had a few of them over the years.
Great looking cars.
      06-06-2020, 02:10 PM   #405
Hali_Mark
Drives: 2014 F31 M Sport
Are the oe bump stops needed when replacing with B4s? I've seen conflicting info on whether they have internal stops as the B6s do. Any harm in keeping the oe even if they do?
Edit: They are needed with B4s, confirmed with Farkle.
      06-26-2020, 03:38 PM   #406
thatBimmerBloke
thatBimmerBloke's Avatar
Drives: None
Did you have to get an EDC cancellation kit? Also, did you consider trying just the springs first, I've read many posts stating that the Eibach springs work pretty well with adaptive dampers and you also retain the adaptive suspension. Some of them also supplemented it with Dinan shockware.
      06-26-2020, 04:03 PM   #407
Lancelot
France
568
Drives: 2017 m550i
Used to have ST lowering springs and not too happy with stock EDC dampers, perhaps Eibach are better suited but i doubt they differ much.
Now on Koni sport non EDC dampers and damping force is well matched with springs, much better
2017 M550i | Sophistograu
Previous cars: 2014 F30 ActiveHybrid 3 | 2012 f20 M135i
      06-26-2020, 04:21 PM   #408
thatBimmerBloke
Drives: None
Looks like people have had good results with Eibachs and Dinans paired with adaptive dampers, I think Eibachs mostly. I was looking for Koni and Bilstein for my car but Bilsteins were back-ordered and Koni does not make dampers for 4 series xDrive. Ended up with KW V1. I did not have adaptive dampers though.
      06-26-2020, 04:37 PM   #409
M140_BCS
M140_BCS's Avatar
238
No cancellation kit needed. Replaced the OEM adaptive dampers and springs with B6 Damptronic (Adaptive) and Eibach pro springs.
Considered the Eibach springs on OEM adaptive dampers but found a set of B6 adaptive dampers used so went for that setup. Impressed so far!
      09-16-2020, 03:07 PM   #410
Matthewricha
Drives: M235i
GSband how you finding the B4's?
I've done about 1500 miles on mine and i have to say I'm a little disappointed in the compliancy over small sharp bumps, I get quite a bit of rebound thud through my strut mounts. Perhaps this is due to the M Performance springs not matching with the B4 shocks gas pressure. Never had this with OEM adaptive with M P Springs. Things do tent to soften up a little bit after driving for a while, but not much. Perhaps my lighter 2 series plays on this too. There is no doubt the B4's make the car handle better and there's less lean, I guess that's at the compromise of a little comfort.
      12-30-2020, 10:53 AM   #411
Matthewricha
Drives: M235i
I've come across the following:
Eibach B12 Damptronic Suspension Kit E90-20-030-07-22
Lowering Front (mm): 20
Lowering Rear (mm): 10
https://www.eibachshop.co.uk/eibach-..._p32474683.htm
Anyone know what this is? I assume it is a packaged B6 damptronic shocks with Eibach lowering springs. Seems a silly price though at ~£2800, as would be cheaper to buy parts separately and also more expensive than the B16 Damptronic kit sold by Bilstein.
      01-01-2021, 12:15 PM   #412
M140_BCS
M140_BCS's Avatar
238
If you buy them separately it works out around £1470 for the dampers, eibach pro springs - £150 autodoc.
Shouldn't be much more than £1600 all in.
I got lucky, bought a used set of B6 damptronic dampers for £800 which had only covered a few hundred miles.
Got a set of Eibach pro springs on Autodoc - £135
      01-01-2021, 01:51 PM   #413
Matthewricha
Drives: M235i
totally agree, seems a mad price
M140_BCS237.50
      03-04-2021, 07:56 PM   #414
Acuavit
Drives: 340ix
Greets,
Had B6 DT and Eibach Pro Kits just installed on my 2018 340xi at 41k. Took a short ride home through some twisties and lots of frost heaves.
The good:
Comfort mode: really really nice. Steering and chassis are tighter and the car is far more responsive. I do agree with some folks comments that the ride is actually more compliant. My initial reaction is I will likely live in Comfort mode and simple change the Sport chassis setting to Comfort to get the Sport throttle response
Sport mode: I didn't spend too much time in it as I was hitting monster frost heaves (NH). The car firmed up even more and I liked it. I think Sport will be reserved for better pavement. More testing needed
Sport+ Did not try... yet
To anyone who is worried that the B6DTs will be too stiff I don't think so and I'm old (50+)
The not so good:
Car is definitely raked. The rears have dropped and the front has raised pretty dramatically. Maybe the front will settle. Not crazy about the look but the car drives really well. Any thoughts appreciated.
2 odd notifications:
- My right LED front light assembly went dark after install at my indy: Notification: "Lighting system: Front right malfunction" Weird!
- Second notification: "Headlamp vertical aim control malfunction" Maybe because of the rear drop rake? Once the car settles will need to realign
I will drive more tomorrow and report back. Any input appreciated!
      03-05-2021, 12:13 AM   #415
FaRKle!
Check that your headlight levelling sensor are properly attached. It's easy to forget to reconnect them or set them in the right orientation.
-My YouTube Channel for some of the best DIYs and in depth information
Please don't PM me for suspension recommendations unless interested in paid private consultations.
      03-05-2021, 06:49 AM   #416
Acuavit
Drives: 340ix
Thanks @farkle! Will check
Took the 340 out on the highway and again comfort mode was really great... tight and compliant.
Sport setting was tighter yet but seemed to lose the ability to absorb road imperfections. Got quite a bit more vertical jostling.
Still only 25ish miles on em so still evaluating. I’m running r18 blizzaks currently.
      04-06-2021, 04:09 AM   #417
Matthewricha
Drives: M235i
Come across a "new" set of Adaptive Damper from Bilstein, but appear to be for the Gxx cars (I know this thread is for Fxx, but useful info)
BILSTEIN EVO SE coilover kit (DAMPTRONIC)
https://www.bilstein.com/int/en/blog...e-driving-fun/
Looks cool in metallic grey coating with better anticorrosion apparently. Would be Interesting to understand if they differ from the 49-255935 Fxx B16 kit.
49-303391:
https://www.schmiedmann.com/en/bmw-g...duct=49-303391
https://www.autodoc.co.uk/bilstein/15483621
https://shop.bilstein.com/de/evo-se/...nic-_49-303391
https://www.turnermotorsport.com/p-640612-evo-se/
Also passive version (S and R) (47-300118):
https://www.demon-tweeks.com/bilstei...-bls47-300118/
I've bought some Eibach Pro springs for my car, so will see how they work with the B4 DT's over the MP Springs, when I get a chance to fit them.
      04-06-2021, 08:25 AM   #418
435gc
435gc's Avatar
174
Drives: 2015 435i Gran Coupe xdrive
Those that installed the b4s, did you notice the vehicles's ride height change at all?
Ride higher?
Ride lower?
