07-09-2020, 03:34 AM | #133 |
Rep 3,876
Fair point. That's however the only sensible alternative to stock adaptive. Any fixed stiffness dampers/coilovers are IMO a downgrade from a stock adaptive suspension. Which again IMO, at least in LCI, is not bad at all! I am pretty happy with it and I have been assured it will get even better once I get rid of the RF tires
johnung4528.00 |
07-09-2020, 09:19 AM | #134 |
Rep 52
I have been going through a bunch of different threads on this site about different springs/shocks combos and some people say you NEED to do them, others seem to have not and been just fine. This is even with the Dinan or Eibach springs which seem to have roughly the same drop as the ACS.
I'm an LCI F36 xdrive with adaptive, and the ACS springs seem like exactly what I want. I want just a mild drop while keeping roughly the same ride quality, which on Chicago roads is needed. I just didn't know if I should be getting some different bump stops as well. Just wanted some opinions from people who actually have them. |
07-12-2020, 10:42 AM | #135 |
Rep 46
Anyone here have a 320i xdrive lowered with H&R super sport that can speak to the ride quality? I'm trying to decide between the eibach prokit vs H&R supersports.
Brand new to the BMW scene... be gentle!
2015 320i xdrive bone stock... for now. |
07-13-2020, 07:51 AM | #136 |
Don't Fear the REAPER
Rep 89
I do, with Bilstein B6 all around. Overall look on the car is spot on not too lowered looking and no rubbing issues with 255 squared set up. The ride is somewhat stiffer than OE but then again I'm running Yokohama ADVAN performance tires which are a bit harder to begin. Anytime you lower the car you will feel the bumps more than the OE springs but for the look and the handling it's worth doing.
2016 320i Xdrive, H&R lowering springs with Bilstein B8, Ultra Racing Strut bar, Wagner Tuning catted DP, AWE Touring complete exhaust, Wagner Tuning Competition Evo 1 Intercooler, FTP RED charge pipe & boost pipe, INJEN EVO CAI, BMS catch can, 18X9 +31 APEX Racing EC-7 Bronze with Yokohama ADVAN V601 255/35/18 (SQUARED), BMS JB4 wi/fi.
07-22-2020, 04:15 PM | #138 | |
Rep 13
07-22-2020, 06:34 PM | #139 | |
Rep 150
07-22-2020, 07:41 PM | #140 |
GasCompressor
333
Rep 564
The ride is ever so slightly stiffer with an added bonus of quicker reacting springs combined with the lower center of gravity. These provided me with tighter turning with less body sway and I feel more confident in my driving. My vehicle has adaptive suspension and in sport mode, it rides with similar stiffness as the M4, only not the horse power or the steering feel of the M, however, half the insurance of the M! I would recommend these springs to anyone looking to close up the excessive wheel gap of xDrive without the harshness that can be expected with most aftermarket springs. These are great for a daily driver not being tracked and for locations that do not have the smoothest roads.
2022 Porsche 911 Cabriolet Agate Grey/Black PDK 2019 440i M-Sport Smoke Topaz Metallic/Opel (Sold) 2014 335i M-Sport Black/Beige MPPK/MPE (Totaled) 2013 328i Sport xDrive Imperial Blue/Grey (Sold) |
07-23-2020, 06:27 AM | #141 | |
Rep 13
07-25-2020, 10:39 AM | #142 |
Rep 89
I got Apex EC7 with 18x9 +31 all around. No spacer too and flush to the fender,
Stlblues68.50 |
07-25-2020, 12:46 PM | #143 |
Rep 150
Thanks for the response. I am looking at the ARC8 in in the same size and have been debating the 255 bs the 245 that Apex recommends. I'm lowered on Dinan springs and by all indications the 255 should work which is what I prefer given mine is xdrive. I really don't want to do crazy camber or other mods to "fit" them
07-25-2020, 08:09 PM | #144 | |
Rep 1,934
I'm at stock xdrive height. If you are low enough you will definitely rub on deep compression. However xdrive can't even function at those sorts of drops without snapping/popping axles. So camber would be the least of your issues if you are that low.
07-25-2020, 09:47 PM | #145 | ||
Rep 150
07-29-2020, 12:51 PM | #146 |
Rep 32
All,
I got my Eibach 6-22 kit paired with Koni Special Active Struts and Shocks on my 2016 435i Gran Coupe. IN LOVE. It rides so nice and looks great! Thank you for everyone's help. I did notice that the front drivers side sits 1/4 inch higher than the front passenger side. Its quite noticeable to me. I checked to make sure the spring was in the pocket, the strut int he knuckle etc and everything looks great. Any ideas? Thanks! Dereck |
07-29-2020, 02:56 PM | #147 | |
Not stock
474
Rep 614
Even my F30 2WD on H&R super sports seems to sit about 1/16 - 1/8" higher on drivers side. Spring fully seated, nub sticking through the trailing arm, no issues at all.
2015 BSM 328i Sport Line - BSM
2015 BSM X1 M Sport - BSM 1992 525i 1987 325e |
07-29-2020, 03:52 PM | #148 |
Rep 1,934
Likely accounting for the driver so it evens out?
08-02-2020, 03:12 PM | #149 |
Rep 270
Drives: 2015 X5d M Sport Metallic Whit
I have installed H&R Sports on my 2017 F31 diesel xdrive...very nice drop (looks miles better) and noticeably stiffer ride. It is awesome on the highway and through corners but sharp bumps can be nasty if they're more than average size (I have 19" 403Ms and Bridgestone RFTs). I expect that losing the RFTs would help as the sidewalls are so hard but it might also lead to a greater chance of wheel damage. I can't imagine Super Sports on anything but very smooth roads and the impacts on them would be spine crushing based on my experience with the Sports. I have not replaced the stock shocks which may also provide some better insurance against the nastiest of the bumps. Overall I'm quite pleased and it feels more like a BMW should feel IMO. It would be hard to go back to the somewhat sloppy OEM springs.
08-03-2020, 08:06 PM | #150 | |
NewFinishColumbia/detailer
604
Rep 2,096
328 F31 xDrive/OSM/Venetian Luxury Line/Cold Weather/Premium/Driving Assist/Nav/Tech "Golden Goose"
78' Honda CB400A project http://www.instagram.com/steve_inf31 |
08-04-2020, 08:12 PM | #151 |
Rep 54
Hey folks, I just had the Dinan Sport Springs, bump stops, and a Megan Racing front strut tower bar installed on my 2016 328i X-Drive (base model). Overall, I'm happy with it. I don't think there was any drastic change in handling performance, but I wan't looking for race-car handling anyway. I wanted to reduce the wheel gap and get rid of some body roll and I accomplished that. Turn-in is noticeably improved and stability at high speeds in curves and turns gives me more confidence in the car.
(NOTE: I have 17" BMW rims with 225/50R-17 Continental ContiProContact run-flat tires. Lame, I know, but I'll upgrade next year to a 225/45 or 235/40-18 setup. That might improve handling a little bit more.) The first 4 pics are stock height, the rest are after the parts were installed.
2016 328i XDrive N26 8AT: K&N Drop-In Filter * GPlus FMIC * ER Chargepipe * DinanTronics Sport Tuner (Race +4psi) * AWE Midpipe (2nd Cat Delete) * Dinan Axleback Exhaust * Dinan Sport Springs * Megan Racing Front Strut Tower Bar * Cross-Drilled Rotors * Hawk HPS 5.0 Brake Pads * StopTech SS Brake Lines
Stlblues68.50 |
08-04-2020, 08:40 PM | #152 |
Rep 1,288
Does anybody know about ST-X coilovers? looking to go that route.. or might get this BMW B14 PSS Coilover Kit - Bilstein 47-264632 ... Bilstein has a lifetime warranty compared to 5 years ST-X
08-08-2020, 04:02 PM | #153 | |
Rep 175
I have the opportunity to buy some H&R Sports for my F31 at a good price, but I'm concerned by the reports of slamming and rough ride and may shell out for the Eibach's. |
08-09-2020, 08:32 AM | #154 | ||
Rep 205
Drives: 14 F30 335i xDrive
I ran shorter rear bump stops and trimmed the B8 internal bump stops on the front shocks. Before trimming the fronts, I was practically driving around on them all the time. The ride was a little harsh on bumps of any kind. When I got in there, the front bump stops had started to fall apart. After trimming the ride improved greatly over small and large bumps. From reports I read, if you lower less than an inch, you can probably be ok with stock bump stops. But any shorter and it's recommended to have shorter ones to not be in them too much. There's a thread with the exact bump stops and part numbers if you search. If you're sticking with stock shocks, than perhaps keep the lowering less than an inch. If you want more lowering, you'll need shocks too or it won't ride well. The factory shocks will not be able to control the springs well and the lowering will be out of the factory shock range. But that's a general recommendation. |
