05-09-2021, 12:44 PM | #23 |
Rep 950
05-09-2021, 01:15 PM | #24 |
Rep 439
I have yet to hear a reason for idling for so long. Gas engines aren't meant to idle for prolonged periods of time, period. Stuck in traffic behind a major accident? Turn it off. Idling to keep the battery charged due to using the radio in a drive in? Lol. Way back in my first car I had 3 amps running subs and separate component speakers and I could run it for 3 hours engine off with the volume at 3/4 and it would start no problem.
05-10-2021, 09:22 AM | #25 |
Rep 1,597
Impatient. Pad a small metal trim pry-bar and leverage it off. There is very little real-estate from which to lever off but it can be done with prybar sideways rested along the circumference at 4 o'clock and comes off rather easily. You just need to play with it.
05-10-2021, 02:46 PM | #26 | |
Rep 950
05-10-2021, 03:20 PM | #27 |
Rep 1,597
05-10-2021, 03:22 PM | #28 |
Rep 950
05-12-2021, 02:36 AM | #29 | |
Rep 141
First time installing it, drove it around the block, started heavily billowing white smoke from the exhaust, smelled like oil. Good thing I was super close to my house. I took off the breather, emailed Vargas, returned it, they sent me a new one. The new one came with two metal rings on the bottom end? Instead of one. I didn’t bother installing it for a month or so. Then I installed it. Drove it around the block and same thing. I sent videos to Vargas explaining my problem. Here’s the response email I got. After that I just put the factory one back on and have the Vargas breather in a box in the garage. No problems with the factory one so far (and yea I tired their solutions, just didn’t work out for me) |
05-12-2021, 09:51 PM | #30 | ||
Rep 275
Instagram- f30_luca
Modifications: Custom E50 Tune by David Shoup, B58TU Fuel Pump, Armytrix Exhaust, VRSF downpipe, Big Boost Charge pipe/bov kit, CTS intake, H&R Springs/B8 Struts, 335is Clutch Upgrade |
05-13-2021, 09:32 AM | #31 | |
Rep 950
Here is my email response from vargas "This would have ZERO to do with that. It's nothing but a breather. When the engine is at anything other than boost its functions like an oil cap, when its under boost it vents. It does nothing else at all. We have these on 1000's of late model BMW's. Including a brand new G80 M3, and a 2017 340IX that are both shop cars with no issues. With that said parts that are installed, and used can be returned for a 50% store credit only" 50 percent store credit lol.... |
05-14-2021, 01:30 PM | #32 | |
Cheapskate
4450
Rep 4,993
Reminds me of that guy who's F250 developed a death wobble above 65mph, and the dealer claimed speed limits are 65 so they "just shouldn't go that fast in a truck." |
G.Newt810.00 |
05-14-2021, 01:40 PM | #33 | |
Rep 439
05-14-2021, 08:18 PM | #34 | |
Rep 1,454
I see it as an engineering flaw. I don't see too many people defending N55's chargepipe problems. "Just stay out of boost and your chargepipe won't break. Why are you accelerating that fast anyway?"
2022 CT4-V Blackwing 6-speed
05-17-2021, 08:41 AM | #35 | |
Cheapskate
4450
Rep 4,993
01-29-2024, 11:09 PM | #36 |
Rep 1
Drives: 2018 bmw 340i
I need help
My 2018 BMW 340I started misfiring, cutting fuel to cylinder 3 and 6, and was also smoking XTREMELY bad. I was doing a log for my turner and mid pull my car started cutting boost and fuel and also started smoking heavily. when I pulled off to check the car out, I noticed an extreme amount of oil on the PCV cap. But I checked the gasket for any tears, and it seemed to look fine. The PCV cap also sealed properly. My car threw a CEL and Drivetrain Malfunction code, the codes are 120408, 140001, 140002, 140010, 140310, 140601, 140602, and 140610. my turner said its most likely the PCV but seeing that it all looks fine I'm at a standstill. Anything helps. Thanks!
01-30-2024, 07:31 AM | #37 | |
Rep 504
1. how much boost you was running?
2. is your valve cover is OEM bmw? most likely your valve cover has failed. Quote:
01-30-2024, 08:05 AM | #38 |
Rep 3,877
Can you clarify the above? What do you mean by "on the PCV cap"? You had to open it to check I guess?
