01-16-2024, 06:32 AM | #23 | |
Rep 8,501
Today I made a return journey of around 50 miles each way, mostly motorway, and the battery SoC increased by 3% each way (finished at 43%). That seems to indicate there's a significant problem somewhere - alternator, IBS, terminals, or the battery itself.
01-17-2024, 05:47 AM | #24 |
Rep 8,501
Update...
Strange goings-on with the battery and the data. After my 100 mile round trip journey yesterday BimmerLink showed the SoC at 43%, which is obviously extremely low. Today I did various checks : Battery voltage at 'rest' (i.e. engine not running) was 13.6V. Started the engine. Alternator output was 17.6V. Voltage at the primary connections to the battery, engine running, was 17.5V (therefore the alternator output is reaching the battery). Switched the engine off. Disconnected the IBS, waited ~30 seconds, then reconnected. Checked the SoC using BimmerLink. 52%. Registered the battery again, using BimmerLink. SoC then displayed as 72%. Went for a 6 mile round trip drive, using manual mode to keep the revs between 1500-2000rpm so the alternator could work effectively. SoC now shows as 79%. Obviously I'll keep an eye on it but even though BimmerLink shows that I definitely registered the battery when it was first installed, perhaps the IBS didn't update correctly for some unknown reason.
01-17-2024, 06:04 AM | #25 |
Rep 811
Ive never seen a 12V lead acid battery exceed 12.9V resting. My MayPole charger can only get them that high. 12.85V+ should equal 100% SOC.(https://sunonbattery.com/agm-battery-voltage-capacity/).
Im also surprised the alternator is pushing 17.6V! Most cars charge around 14.5V and thats what i typically see on the Onboard Display (you can see it when you unlock the service functions). If you're seeing 17+ with both the multimeter and car, something doesnt seem to be right. Do you have any high voltage errors when doing an error scan? You could potentially have a defective voltage regulator on the Alternator that is killing the battery. |
01-17-2024, 07:00 AM | #26 | |
Rep 8,501
No error codes when interrogating the ECUs with BimmerLink. Looks like more investigation is needed.
01-17-2024, 07:11 AM | #27 |
Rep 1,013
Strange voltages indeed. Especially 13.6V with the engine off.
Did you try it across the battery terminals with the positive cable removed? I know that will reset some adaptations.....but it should at least give a true reading of the battery itself. I'm suspecting an iffy alternator as well. You could put your meter across it's output wire and the casing as the engine is grounded, which is a bit easier and quicker. You could also try it on the bodyshell ground point as well just to make sure there's no strange voltage drops through the engine's ground strap. |
01-17-2024, 10:26 AM | #28 |
Rep 811
Just popped out to my car to have a look at the voltages for a comparison. Resting was 12.2V at the battery (ECU, Dashboard and Boot light will have been on).
Car Running - they were within 0.1v between low and highish drain (lights, fans, bum warmers) Measured at the Jump start terminal and earth: 15.31V Measured at the Battery: 15.22V Still higher than i expected. Last week the OBC definitely was showing 14.5V |
Watsey6421.50 |
01-17-2024, 11:48 AM | #29 |
Rep 542
Definitley something wrong there...
I don't think you should ever see 17+ volts anywhere. 14.7V is a normal max charging voltage. Around 12.6V not charging is really good but more likely to be 12.3V or thereabouts. Maybe check the meter you are using. Is it reliable?
335d xDrive
01-17-2024, 12:06 PM | #30 |
1897
Rep 2,090
Always thought that battery voltages should be c14.4v with engine running and c12.4v with engine off/car asleep
Either way, lower than those ball park figures, there's an issue somewhere unfortunately
Watsey6421.50 |
01-17-2024, 05:00 PM | #31 |
Rep 8,501
I had an interesting conversation with a respected BMW Indy this afternoon. They’ve worked on the car a few times in the past, are very knowledgeable, and did a good job.
I described the symptoms and what I’d found, i.e. multimeter readings and diagnostics. In their experience :
Next steps are to get the car in to the Indy for a full investigation, using ISTA step-by-step diagnosis sequences.
01-19-2024, 12:07 PM | #32 |
Rep 8,501
I did a couple more checks with my digital multimeter.
Our KIA Sorento, engine off, battery voltage was displayed as 13.4V My F31, engine running, attaching to the alternator + terminal and the alternator body = 16.9V. If 12V AGM batteries are meant to be around 12.4V then maybe the multimeter was over-reading by around 1V. I tested some small appliance chargers : 18V output charger, multimeter reading was 20.8V (15% over-reading) 5V output charger, multimeter reading was 5.7V (14% over-reading) Although it's not obvious that there's an internal battery I opened the multimeter case (just a couple of retaining screws) and, behold, there's a 9V battery. I expect it's at least 10 years old. Replaced it with a super long life commercial grade 9V Duracell ProCell battery which is still giving 9.28V after 10 years (I use these batteries as the internal backup units for our interconnected mains-powered smoke alarms at home). The old internal 9V battery was giving 7.2V. Now the penny has dropped I expect these digital multimeters use an internal battery as a reference voltage and then calculate from there. Every day's a school day. Checked the voltages again. 18V output charger, multimeter reading was 18.1V 5V output charger, multimeter reading was 5.1V Sorento battery, engine off = 12.35V BMW alternator = 15.3V BMW battery (engine off) measured at the jump start terminals = 11.95V (not worried about that - there could easily be a 0.5V drop through the wiring). It still doesn't solve the low SoC. Currently I'm suspecting an incompatibility between the Bosch battery and the IBS, or a problem with the IBS itself. Either way, I'm going to replace the battery with a genuine OEM unit. They are, surprisingly, no more than I recently paid for a new battery for the Sorento.
Stainy265.00 |
01-19-2024, 02:38 PM | #33 | |
1897
Rep 2,090
But how can moving from a non OEM battery to an OEM battery sort this; surely this would point more towards the IBS going duff? My previous F01 had IBS issues; kept getting the 'battery draining whilst stationary' warning even after fitting a brand new Exide AGM battery, properly registered to the car etc and on trickle... Replaced the IBS - never came back
01-19-2024, 02:47 PM | #34 | |
Rep 8,501
Good point about the IBS though. Maybe I'll replace that first.
danb19791897.00 |
01-19-2024, 04:10 PM | #35 |
Rep 542
So the multimeter is no longer telling porkies.
That's good. Another possibility concerning the battery. Can you be sure it was fully charged when it was originally fitted? You have checked it was registered so should still be pretty good for its age. The car charging system never fully charges it and gradually reduces the charge over time, creating a falling soc. I would suggest using your Ctek charger again once, to fully charge it over night, but connect it directly to the battery. Not the other side of the IBS where it tells you to. See how it measures up over the next few days / weeks. Might save the cost of a new battery so soon.
335d xDrive
Watsey6421.50 |
01-20-2024, 05:03 PM | #36 |
Rep 8,501
Almost certain I fully charged the battery before installing it.
It’s being charged now, direct connection. Once it’s done is it advisable to disconnect/reconnect the IBS to reset it, or just leave it altogether be but take a SoC reading using BimmerLink to see what SoC value the car is reporting ?
01-20-2024, 06:21 PM | #37 |
Rep 542
As far as I can make out, the IBS measures battery voltage, current and temperature, makes some calculations and then passes the data to the DME when the car is on.
It also measures battery volts, temperature and discharge current, every 14s when the car is off. I don't know for sure, but I doubt disconnection / reconnection would achieve much other than possibly generate fault codes, particularly if it happened to be talking to the DME at the time.. It compares it's values of SoH and SoC with the DME. It's a sensitive little fellow, looking at the list of Do Nots though..... I would just monitor the values for a while.
335d xDrive
Watsey6421.50 |
01-21-2024, 05:09 AM | #39 |
Rep 8,501
After a full charge overnight (which took several hours) BimmerLink still only shows a SoC of 47%
Looks to me like the IBS is the #1 culprit. AFAIK the IBS is only in the negative cable/connector at the battery. Correct ? The part number is easy to find in realoem and AutoDoc (just an example) has several options showing, only one of which states that it needs to be coded. https://www.autodoc.co.uk/spares-sea...rd=61219117877
01-21-2024, 10:35 AM | #40 |
Rep 542
Was the car driven before using Bimmerlink?
It needs some time to monitor the starting current, normal load, battery volts etc. It won't know anything about what has been put into the battery overnight. Does it start ok or does it struggle? Battery on my car measured 50% SoH / SoC two years ago. With the occasional overnight use of Ctek in the cold months, it still works fine. (I hope I haven't jinxed in now).
335d xDrive
01-21-2024, 03:27 PM | #41 | |
Rep 8,501
03-09-2024, 11:00 AM | #42 |
Rep 8,501
Update :
There have been more instances where the engine wouldn’t start and I’ve had to use my jump-start pack. BimmerLink showed the battery SoC as low as 40%, and only 50% after a full charge using my CTEK. I finally got round to ordering and replacing the IBS cable (£120 Autodoc) today. The SoC was displayed as 59% and with the new cable BimmerLink instantly shows the SoC as 99%. This,of course, is too high. Presumably the data from the faulty IBS has interrupted the engine start cycle (as the car believes the battery doesn’t have sufficient charge, but also that the battery was being over-charged because the IBS has been reporting a low SoC. Hooefully the battery life hasn’t been degraded. Replacing the cable was pretty easy as the chassis mounting point is located at the top/rear of the battery compartment - no need to remove the battery.
03-09-2024, 02:17 PM | #43 | |
Rep 385
1995 E34 525td auto • 2016 F30 320ed auto
03-09-2024, 02:34 PM | #44 | |
Rep 1,099
Luckily the above is a cheap repair at a measly £1200 for the battery , fitting / coding and VAT take the replacement cost to just over £2k. Never saw that coming when i bought the Cayenne. The selling point for the Li-Ion battery is that it is a "lightweight" battery , saving a whopping 5kg over a AGM battery , may make a difference in a GT3 RS on the "Ring" but not in a 2T SUV going to Morrisons for a pint of milk. K |
