01-28-2024, 01:48 PM | #1 |
Rep 92
Flowmax 2.5+ build help
I’m interested in getting a flowmax 2.5+ with a catless dp and tu pump limited to 93oct. What are some good tuners to look into and would this make around 500awhp?
01-28-2024, 02:46 PM | #2 |
Rep 765
Should be able to hit 500 with the right turbo, fuel pump, and tune. I would look into e85 though, at least a mix if not full e85. The tu pump is the supra fuel pump? It might be more cost effective but your leaving more power on the table with the turbo. I would get a better flowing fuel pump to take advantage of the flowmax
MG F30 M-Sport 6mt FBO w/ MHD stage 2 plus (PWG), ST XA Coilovers, 19" VMR V804.
01-28-2024, 06:23 PM | #3 | |
Rep 92
01-28-2024, 08:15 PM | #4 |
Rep 765
I would, from what I’ve seen the supra hpfp will max out the stock turbo but an aftermarket turbo will want more. Not familiar with the flowmax, last I was around the forums it was only vargas and pure for the B58, you can also ask the tuner if you already have one picked out. Your gonna spend a little more now but not limit yourself right away.
01-28-2024, 11:02 PM | #5 | |
Rep 92
01-29-2024, 12:46 AM | #6 |
Rep 765
Not specifically, I have a Vargas GC still sitting in a box awaiting install, and when the time comes for my custom tune will be reaching out to MHD. I have had zero issues with their product, software, and support, but a lot of people like using specific tuners like shoup, f80paul, or some of the others.
01-29-2024, 08:53 AM | #7 | |
Rep 92
01-29-2024, 09:08 AM | #8 | |
Rep 92
01-29-2024, 11:04 AM | #9 |
Rep 190,807
We offer custom maps by Jordan Tuning
01-29-2024, 12:27 PM | #11 |
Rep 677
Contact David Shoup for tuning. He's a well known tuner in the community. He also tuned many Flowmax turbos, including mine.
dshoup667@gmail.com. |
01-29-2024, 12:38 PM | #12 | |
Rep 92
01-29-2024, 04:27 PM | #14 |
Rep 92
Would a lpfp be necessary for my needs? Would it help improve the power band at all? I was watching kern’s video on the tu pump limit and he was saying that the tu supports 600whp as claimed but his 570whp (something like that) wasn’t there until very high rpm. Having something like the ds2 moves the peak hp earlier.
01-29-2024, 08:59 PM | #15 | |
Rep 92
01-29-2024, 10:06 PM | #16 |
Rep 1,454
DAW/P800, TU, downpipe, and intake. Those are things you'll need to make ~500awhp on 93.
2022 CT4-V Blackwing 6-speed
01-30-2024, 11:35 AM | #18 |
Rep 22
Fully agree with newt, a lot of people don’t seem to realize that on 93, you are octane limited when you have a big hybrid and tu pump. The tu just can’t do too much e on a big turbo, and that’s where you’ll run into more limitation.
If you can only do 93, I wouldn’t waste money on a dorch. |
01-30-2024, 11:44 AM | #19 | |
Rep 92
02-02-2024, 01:59 PM | #20 |
Rep 92
Okay update- I found a station near where I’ll be going for college that has e85. What blend would be good and would I need to change my mod list (flowmax 2.5, catless dp, tu pump). Im guessing on e30 or e50 that would pump the hp to like 550ish?
02-02-2024, 02:28 PM | #21 |
Rep 1,454
Ditch the TU and get a Dorch25 if you wanna run any E mix. The TU will be limited to like E20 and the tuner will have to ramp-in boost a lot slower down low and mid-range where the DAW likes to spool.
02-02-2024, 06:47 PM | #22 |
Rep 92
Should I do charge pipe injection or would that be a waste? Fuel it has a option for it adding a single 950cc injector.
