04-16-2015, 04:33 PM | #287 | |
Rep 1,894
<SgbmId id="NAVD_000004D3_255_002_046" SWID_FscShort="002D0009" name="Road Map North America PREMIUM 2015-1" supplier="TAS" sop="01.11.2014" version="10_09" MapOrderNumberBMW="" MapOrderNumberMINI="" MapOrderNumberRR="" successorMapOrderNumberBMW="" successorMapOrderNumberMINI="" successorMapOrderNumberRR=""> <EcuVariant CompatibilityIdentifier="HU_CIC-HB" Format="CIC" /> <SwUpdate SwUpdateEntry=""/> </SgbmId> <SgbmId id="NAVD_000004D3_255_002_047" SWID_FscShort="002D0010" name="Road Map North America PREMIUM 2015-2" supplier="TAS" sop="01.02.2015" version="10_09" MapOrderNumberBMW="" MapOrderNumberMINI="" MapOrderNumberRR="" successorMapOrderNumberBMW="" successorMapOrderNumberMINI="" successorMapOrderNumberRR=""> <EcuVariant CompatibilityIdentifier="HU_CIC-HB" Format="CIC" /> <SwUpdate SwUpdateEntry=""/> </SgbmId> Please use at your own risk. If you know the package ID (should be the folder name after you have unzipped it), just substitute in the value. |
FlorinQCK-2.50 |
04-16-2015, 05:48 PM | #289 |
Rep 40,789
Road Map North America PREMIUM 2015-2 = NAVD_000004D3_255_002_047
FlorinQCK-2.50 |
04-17-2015, 08:35 AM | #291 |
Rep 40,789
"NAVD_000014BE_255_001_088" = SWID_FscShort="00AE0004"
FlorinQCK-2.50 |
04-24-2015, 12:22 AM | #294 | |
Rep 3
Hi I have downloaded North America Premium 2015-2, however, the BMW_CIC_NBT_FSC_Generator I have does not carry this map, what am I supposed to do?
FlorinQCK-2.50 |
04-24-2015, 02:36 AM | #295 | |
Rep 1,894
<SgbmId id="NAVD_000004D3_255_002_047" SWID_FscShort="002D000A" name="Road Map North America PREMIUM 2015-2" supplier="TAS" sop="01.02.2015" version="10_09" MapOrderNumberBMW="" MapOrderNumberMINI="" MapOrderNumberRR="" successorMapOrderNumberBMW="" successorMapOrderNumberMINI="" successorMapOrderNumberRR=""> <EcuVariant CompatibilityIdentifier="HU_CIC-HB" Format="CIC" /> <SwUpdate SwUpdateEntry=""/> </SgbmId> |
FlorinQCK-2.50 |
04-29-2015, 12:37 PM | #297 | |
Rep 1,892
You probably have the wrong version. |
FlorinQCK-2.50 |
04-30-2015, 06:34 PM | #298 |
Rep 183
FSC code for NA 2015-2 NBT
Hey guys, btw I am new here. I have read the this thread over and over but still don't really get how to generate the FSC code. What I have done is used Esys to generate FSC using one of the steps mentioned in a post above, which is the file with a lot of symbol and long numbers, and then rename it to a.hex and used (fsc.bat) to generate code, and what I get is this:
"MAP FSC for Europe: 2UEOZFSKXA6NCABIAACQ" while I am trying to update it to NA 2015-2 When I tried to plug in the code in the navigation on the update, it says incorrect code. Just in case it is important, my car is a 2014 F30 and I use XP mode in my Windows 7 64-bit I will also attach the file that I got from my car through esys, just delete the pdf. Any help is greatly appreciated. Thank you |
FlorinQCK-2.50 |
05-01-2015, 10:07 PM | #300 |
Rep 8
Drives: 2014 i3
FSC code for NTB North America 2105-2
I am having trouble creating a code that works for NTB North America 2015-2
When I generate the code using the values below, it will not accept. I have a 2014 BMW i3, I was able to update to 2015-1 without needing a FSC code, but is asking for one for 2015-2 fsc a.hex 0xA8 0x06 > code.txt C:\EC-Apps\code.txt MAP FSC for ???: RMD35IOLP5BE4AFIAADA fsc a.hex 0x28 0x06 > code.txt MAP FSC for Europe: M5JET52AH6XUEABIAACQ fsc a.hex 0x2D 0x06 > code.txt MAP FSC for North America: 3YJAIRRFRMCSKABNAADQ fsc a.hex 0xA8 0x07 > code.txt MAP FSC for ???: RZKG6A3RT5ALOAFIAADQ Can anybody provide help, or create a working code for me? I will attach my FCS file. Thanks |
FlorinQCK-2.50 |
05-02-2015, 03:39 AM | #301 | |
Rep 40,789
2) 0xA8 0x06 is North America NEXT 2015-1. You need to use 0xA8 0x07 for 2015-2.
FlorinQCK-2.50 |
05-02-2015, 07:51 AM | #302 |
Rep 8
Drives: 2014 i3
Not sure I under stand your comment on CIC or NTB, but I did the following using 0xDE (App ID222 for NBT)
Base variant 0x63 (For HU_CIC or HU_NBT) Click Identify Application ID 0x1B for (App ID 27 for CIC) 0xDE (App ID222 for NBT) <--- This is the App for your Nav enabler Upgrade Index 0x1 Move Store FSC from the left to the right Click Read Click Save and name the file FXXXXXX_0001B001.fsc for CIC or FXXXXXX_000DE001.fsc for NBT where FXXXXXX is your VIN. I did also try that, fsc a.hex 0xA8 0x07 > code.txt MAP FSC for ???: RZKG6A3RT5ALOAFIAADQ Is there a problem that it shows ??? instead of NORTH AMERICA Next 2015? I'm I doing something wrong? Any help would be appreciated, I have been working on this for hours without any luck. Hopefully I am missing something simple. Can someone generate a FCS code for me so I can compare it to mine? Thanks Last edited by eyoung; 05-02-2015 at 07:57 AM.. Reason: adding comments |
FlorinQCK-2.50 |
05-02-2015, 07:55 AM | #303 | |
Rep 40,789
1) You are using CIC Gen when you should be using NBT Gen. RZKG6A3RT5ALOAFIAADQ is what you will get using wrong CIC Gen. You must use NBT Gen.
FlorinQCK-2.50 |
05-02-2015, 08:05 AM | #304 | |
Rep 8
Drives: 2014 i3
Application ID 0x1B for (App ID 27 for CIC) 0xDE (App ID222 for NBT) |
FlorinQCK-2.50 |
05-02-2015, 08:09 AM | #305 | |
Rep 40,789
With NBT Gen, DE File, and 0xA8 0x07, you will get what you need.
FlorinQCK-2.50 |
05-03-2015, 04:00 PM | #306 |
Rep 1
Hey
i have a E90 and tried to get the 1B file from the car (dcan), but it don't worked. Now i read that it is not possible. Can someone help me please to get the file? Or the FSC? Is there a difference to europe/germany? ))) I live in germany... Thank you! |
FlorinQCK-2.50 |
05-06-2015, 08:10 PM | #307 | |
Rep 8
Drives: 2014 i3
Thanks |
FlorinQCK-2.50 |
05-06-2015, 08:29 PM | #308 |
Rep 40,789
There is a link posted earlier in the thread.
FlorinQCK-2.50 |
