11-09-2014, 07:00 PM | #155 | |
Rep 11,292
<SgbmId id="NAVD_000014B9_255_002_181" SWID_FscShort="00A90006" name="Road Map EUROPE Next 2015-1" supplier="NTQ" sop="01.11.2014" version="10_09" MapOrderNumberBMW="" MapOrderNumberMINI="" MapOrderNumberRR="" successorMapOrderNumberBMW="" successorMapOrderNumberMINI="" successorMapOrderNumberRR=""> <EcuVariant CompatibilityIdentifier="NBT-HB" Format="CIC" /> <SwUpdate SwUpdateEntry=""/> </SgbmId>
Current: Golf R Mk8Previous: Golf R Mk7.5 Mercedes AMG C63 S Coupe F80 M3 Competition Pack |
FlorinQCK-2.50 |
11-15-2014, 11:28 AM | #156 | |
Rep 217
Can someone please explain how to do the following in E-Sys? I have the E-Sys - Getting Started Coding - Part 1 PDF but I am not understanding the steps below.
I also can't get the car to recognize the usb flash drive. It is FAT32 formatted and the only things in it are USB1 USB2 USB3 pkgdb (from USB1) config.nfm (from USB1) Any assistance will be greatly appreciated. Thanks. Quote:
'14 F10 CP M5 AW/Full Sakhir Orange, Gloss Black 343Ms, Black IND Cosmetic Package, M Performance CF Diffuser and Spoiler. - SOLD
FlorinQCK-2.50 |
11-15-2014, 02:01 PM | #157 |
Rep 1,894
I wrote a step by step guide for the guys on the UK channel: http://f30.bimmerpost.com/forums/sho...1&postcount=33
FlorinQCK-2.50 |
11-15-2014, 03:12 PM | #158 | |
Rep 217
FlorinQCK-2.50 |
11-16-2014, 03:38 PM | #159 | |
Rep 13
i see txt manual and view: ------------------------------------------------------- 00A80002 = Road Map NORTH AMERICA Next 2013 ------------------------------------------------------- but 2014 - 00A80003 ? and 2015 - 00A80004 ? why you write 0x06 ? |
FlorinQCK-2.50 |
11-16-2014, 03:41 PM | #160 |
Rep 40,793
2013-1 = 0x03
2014-1 = 0x04 2014-2 = 0x05 2015-1 = 0x06
FlorinQCK-2.50 |
11-17-2014, 02:14 PM | #161 | |
Rep 1,892
Where/how did you get this file? Did you retrofit your NBT? PM Sent. |
FlorinQCK-2.50 |
11-19-2014, 04:31 PM | #162 |
Rep 1,502
Drives: M4 CP SSII/SS
I've managed to update to 2015-1 using the Esys method, thanks to the good folk on this forum.
What I wondered was, could we use the theoretical code as above for, say 2017-1 (0x0A) and have a code that would allow the next few updates without having to enter a new one...?
Current: F82 CP SS/SS
FlorinQCK-2.50 |
11-20-2014, 10:24 AM | #163 | |
Rep 1,527
FlorinQCK-2.50 |
11-20-2014, 10:52 AM | #166 | |
Rep 1,892
From what I've seen, I think the comparison between the value set the the FSC code and the value in the map info file and the is done as greater than or equal to, not strictly equal. This would allow us to generate codes for future maps without having to re-enter an FSC code each time. First, I've see people able to downgrade their maps without having to enter a downgraded FSC code. That indicates that either the car remembers old FSC codes, or the test is >=. Second, when I generated my FSC for the 2015-1 Premium (CIC) map (0x09), I used sequence code 0x0A just to see what would happen. I figured that worse case that the code would be rejected. The car accepted that code when I installed the 2015-1 maps! I'm now waiting for the next release (2015-2?) to see if I can install that without entering a new code. If that works, then the question is, how far in advance is is safe to advance the map sequence code? There may be some upper limit that if we go past, something bad could happen; we just don't have any way of knowing. That's why I just tried +1 instead of, say, +50. |
FlorinQCK-2.50 |
11-20-2014, 10:58 AM | #168 | |
Rep 1,892
That may also explain some reports of people upgrading their maps on new cars without being prompted for an FSC. If the car was manufactured with FSC code 0x06 in anticipation of 2015-1 NEXT, but the car was installed with 2014-2 NEXT, installing 2015-1 wouldn't require the code. |
FlorinQCK-2.50 |
11-20-2014, 11:28 AM | #169 | |
Rep 1,502
Anyway - I have the necessary now to generate codes.
FlorinQCK-2.50 |
11-20-2014, 11:31 AM | #170 | |
Rep 1,502
FlorinQCK-2.50 |
11-21-2014, 09:15 AM | #172 |
Rep 1,573
I noticed that the instructions say to load the software on a 32gig thumb drive.
what if I do it on an external drive? Would it still work? (im going to try it anyway, but i figured id ask while i waited for the software to download)
2015i Cadillac Escalade ESV
FlorinQCK-2.50 |
11-21-2014, 12:06 PM | #174 |
Rep 1,573
crap, i just realized the software runs on 32bit software and im running 64. anyone figured out a way to step around this?
also... I noticed that the instructions say to load the software on a 32gig thumb drive. what if I do it on an external drive? Would it still work? (im going to try it anyway, but i figured id ask while i waited for the software to download)
FlorinQCK-2.50 |
11-21-2014, 12:31 PM | #175 | |
Rep 1,892
For CIC I find it easier to use 3 8GB (or larger) USB sticks. You can do it with one 32GB, but after each USB image is installed, you have to move directories around on the USB stick and put it back in the car. The instructions show you want you need to do. |
FlorinQCK-2.50 |
11-21-2014, 02:05 PM | #176 |
Rep 1,573
Ok, lets see what im doing wrong:
first, I wasnt able to use the SWID tool...so I had to use this method: Code:
FSC Extended Base variant 0x63 (For HU_CIC or HU_NBT) Click Identify Application ID 0x1B for (App ID 27 for CIC) 0xDE (App ID222 for NBT) <--- This is the App for your Nav enabler Upgrade Index 0x1 Move Store FSC from the left to the right Click Read Click Save and name the file FXXXXXX_0001B001.fsc for CIC or FXXXXXX_000DE001.fsc for NBT where FXXXXXX is your VIN. - What I do next is I open the fsc in E-sys, under Weitere Felder i see ExtensionData with a long string that looks like it could be the fsc code i need. - I copy and paste that into the decoder and save it as a.hex - I run the code generator, it says successful - I open code.txt....its an empty file What am i doing wrong?
FlorinQCK-2.50 |
