BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Coding error. CAFD not found
      09-02-2014, 07:11 PM   #1
nyczyar
Drives: F30 335i
I got my car back from the dealer today and was trying to code FEM_BODY and REM and I got these errors:
REM [72] [FX59659]
readCPS o.k.
CAFD_000007A1_005_034_007 Fehler:
File for "cafd_000007a1-005_034_007" not found! [C012]
FEM_BODY [40] [FX59659]
readCPS o.k.
CAFD_00000794_012_034_013 Fehler:
File for "cafd_00000794-012_034_013" not found! [C012]
Does anyone know what this mean? Thanks
      09-02-2014, 08:19 PM   #2
f30GTR
f30GTR's Avatar
51
Drives: 2014 AW F30 335i M-Sport MT
You need newer version of pszdata
      09-02-2014, 09:16 PM   #3
alf233
Drives: 2013 328 xDrive
Yep, I was getting the same error as well.
You should get the latest PSdZData files
      09-02-2014, 09:48 PM   #4
nyczyar
Drives: F30 335i
Do you know where I can get the updated ver.?
      09-03-2014, 07:21 AM   #5
alf233
Yep, PM shawnsheridan
      09-03-2014, 08:46 PM   #6
shawnsheridan
shawnsheridan's Avatar
You need updated PSdZData.
PM sent.
      09-03-2014, 10:51 PM   #7
nyczyar
Drives: F30 335i
Thanks!!
      10-21-2014, 06:13 AM   #8
flykerem
hi ,
I have take the same error and I sent the PM to shawn.
Transaktions-Report: Aktion: Codierdaten lesen
FEM_BODY [40] [F892703]
readCPS o.k.
      10-21-2014, 06:16 AM   #9
shawnsheridan
Originally Posted by flykerem View Post
...I have take the same error and I sent the PM to shawn....
[C012]
I have replied to your PM.
      10-21-2014, 07:06 AM   #10
flykerem
Many Thanks Shawn..
      12-01-2014, 11:16 PM   #11
bmonson28
Drives: 2013 328
Could I get in on that too (get the latest 54 lite version)? I just got my 328 back from the dealer and cannot code FEM_BODY and some others. I downloaded 53.4 lite, but it didn't help. The only useful one left that I can write to is HU_CIC.
      12-02-2014, 12:27 AM   #12
shawnsheridan
PM sent.
      12-05-2014, 08:46 PM   #13
bmonson28
Drives: 2013 328
I think we still have to wait for newer because FEM_BODY is still not working. BMW must have a newer version. I also noticed once my car was updated by them that the car no longer allows auto-shut off of the engine if in Sport mode. I might have to look into re-coding that I am happy to get a new version of E-sys with a token. Thanks shawnsheridan.
      12-06-2014, 07:18 AM   #14
shawnsheridan
These two CAFD are not part of any PSdZData release. You can inject the following replacement CAFD's into the ECU's, VO Code them, and then you can FDL Code them:
FEM_BODY - cafd_00000794.caf.012_035_116
HU_NBT - cafd_00000ded.caf.003_013_024
Connect => Read FA (VO) => Activate FA (VO) => Read SVT (VCM) => Left-Click on desired ECU => Click on "Detect CAF for SWE" => Select the CAFD from above => Select OK => Right-Click on ECU (the ECU itself not the underlying CAFD) => Select CODE.
Afterwards you will be able to FDL Code ECU.
kern4174449.50
      12-06-2014, 07:06 PM   #15
RichardM
England
133
Drives: G21 M340i LCI
I did this today without any issues. Thank you Shawn.
2023 G21 M340i LCI
Previous - 2020 G21 330d M-Sport, F31 335d M-Sport, F31 330d M-Sport
      12-06-2014, 08:07 PM   #16
shawnsheridan
      12-06-2014, 08:48 PM   #17
KLez
Drives: 435d xDrive
Hmm... Actually i try to understand all these things, so sorry for the question: For what are these CAFDs files good for? Is this the firmware of the ECU?
If i VO code my ECU to a lower version of CAFD, is this a software-downgrade then?
      12-06-2014, 09:08 PM   #18
shawnsheridan
CAFD is a Coding Application File Data, not firmware, and it is downgrading nothing.
      02-16-2015, 09:50 AM   #19
marks17
Drives: BMW 435i GP 2015
I get the following errors when I try to VO code HU_NBT and FEM_BODY using PSdZData 54.1
File for "CAFD_00000794-012_035_117" not found! (C012)
File for "CAFD_00000ded-003_013_025" not found! (C012)
I just picked my 435i GP from the dealer about a week ago so I bet it has already a newer software installed. I am trying to activate 6NS and the Active High Bean Assistant. Any thoughts of what might be the problem? Do I have to use a newer PSdZData to FA/VO code. Thanks.
      02-16-2015, 09:51 AM   #20
shawnsheridan
See my post here:
http://www.bimmerfest.com/forums/sho...2&postcount=12
      02-16-2015, 12:18 PM   #21
marks17
Thanks a lot shawnsheridan your solution worked like a champ
      11-14-2015, 12:30 PM   #22
vortex86
Drives: F30 316d
Hi,
I installed a NBT and want to code it, but get the following error:
cafd_00000ded-003_013_033 is missing
I am using the PSdZData 57.0
Does anyone else have this problem?
Where could I get this file?
