01-31-2017, 10:50 AM | #1 |
Rep 41
S563 - Light package present, but no "Sport" option in idrive.
I only have the default "comfort" setting in idrive, although the VIN decoding says I have S563 - Light package option, which should enable me the "sport" option in idrive.
Anyone knows if the setting can be coded? Thank you |
01-31-2017, 12:21 PM | #2 |
Rep 1,659
Drives: 2022 WRX World Rally Blue
Did you look under interior lighting in your menu? That's where I changed mine.
Rick
01-31-2017, 03:24 PM | #3 | |
Rep 8,364
With 205 Automatic Transmission, you get Eco, Comfort, and Sport. With 2TB you also get Sport+ & paddles. Do you have rocker switch next to gear to change drive mode? There are two different sport menus. There is Sport Config and Power & Torque. The ladder requires 609 Professional Nav. View post on imgur.com For which menu are you looking? |
01-31-2017, 03:46 PM | #4 | |
Rep 1,659
02-01-2017, 10:23 AM | #6 |
Rep 41
My apologies, the term "sport" did confuse things. I'm talking about this:
Timestamp 2:50. I don't have the Ambiance option, giving me the "Classic" and "Sport" modes. I've just been in E-Sys, going up and down the ECU's searching for the term "farbe", and all I could find (possibly related) was PIA_DEFAULT_CS Kommentar=PIA Default Einstellung Color SwitchWerte: 0-255Default: 0 My defautl setting is Ausgelesen Farbe_1 Werte=01 It has 5 or 6 other options. I tried them, but it didn't change a thing.. P.S.: I just noticed that I ALSO mistakenly wrote COMFORT instead of CLASSIC, to add to the confusion. My apologies. Last edited by SpilltheBimms; 02-01-2017 at 10:25 AM.. Reason: I'm an idiot... |
02-01-2017, 12:20 PM | #7 | |
Rep 8,364
FEM_01 > EcuHwConfiguration 3000 > HW_OPTION_BODY_LC_WELCOME = aktiv FEM_01 > LceLciOutputChannels 3061 > LCI_1_IS_LED = aktiv FEM_01 > LciConfiguration 3071 > ILE_IGR_INNENL_H = aktiv FEM_01 > LciConfiguration 3071 > ILE_IGR_INNENL_V = aktiv FEM_01 > LciConfiguration 3071 > ILE_IGR_LESEL_H_L = aktiv FEM_01 > LciConfiguration 3071 > ILE_IGR_LESEL_H_R = aktiv FEM_01 > LciConfiguration 3071 > ILE_IGR_LESEL_V_L = aktiv FEM_01 > LciConfiguration 3071 > ILE_IGR_LESEL_V_R = aktiv FEM_01 > LciConfiguration 3071 > ILE_LIN_VAR = V6 FEM_01 > LciConfiguration 3071 > ILE_VERBAUT = aktiv FEM_01 > LciConfiguration 3071 > LESELICHT_HINTEN_VERBAUT = aktiv FEM_01 > LciConfiguration 3071 > LESELICHT_VORNE_VERBAUT = aktiv FEM_01 > LciConfiguration 3071 > MAPPING_LCI_1_FUNCTION = off FEM_01 > LciConfiguration 3071 > MAPPING_LCI_3_FUNCTION = footwell_front FEM_01 > LciConfiguration 3071 > MAPPING_LCI_4_FUNCTION = off FEM_01 > LciConfiguration 3071 > MAPPING_LCI_5_FUNCTION = ovt FEM_01 > LciConfiguration 3071 > MAPPING_LCI_6_FUNCTION = cs_1 FEM_01 > LciConfiguration 3071 > MAPPING_LCI_8_FUNCTION = off FEM_01 > LciMaster 3070 > IB_WELCOME_HELLIGKEIT_ENTRIEGELN = wert_01 FEM_01 > LciMaster 3070 > WL_IB_HELLIGKEIT_ENTRIEGELN = Lichtpaket |
02-01-2017, 01:11 PM | #8 |
Rep 41
Everything was already as you described, except MAPPING_LCI_4_FUNCTION = off, which in mine reads footwell_rear. (I have an F31...don't know if it's relevant)
I found COLOUR_SWITCH in the NBT, and set it to active. And now it shows the field in the idrive. I also had to activate COLOUR_SWITCH_LINES to "sport", in order for an option to appear in that field. (You can also choose "luxury", "modern", etc...) Unfortunately, I don't seem to have the proper hardware because no matter what I code/choose, "sport", "classic", "luxury", etc, the LED's remain orange. FYI, I also found COLOUR_SWITCH_ENSEMBLE, which enables a field just below the first one, with a set of 7 or 10 schemes, depending on the coding option. Last edited by SpilltheBimms; 02-01-2017 at 01:24 PM.. Reason: I answered to an unedited version of your post... |
02-01-2017, 02:38 PM | #9 | |
Rep 8,364
View post on imgur.com |
02-01-2017, 07:29 PM | #10 |
Rep 41
I see...
Well, is there a way that I can actually verify if I also have the white LED's? For now, I convinced myself that I don't. But I haven't given up completely yet Also, I read somewhere (in a 5 series forum?) that the "standard" line only has orange (classic) lighting. Only Sport, Urban, and Luxury lines have the other colors. And mine is a "standard" line |
02-02-2017, 12:40 AM | #11 | |
Rep 8,364
02-02-2017, 08:00 AM | #12 |
Rep 41
I don't get it.
I also have that, but I never touched it before, because I believe it only concerns the maps colour schemes graphical representations. What might that have anything to do with the LED lights? I'm still half way through my morning coffee, sorry.. |
02-02-2017, 08:46 AM | #13 |
Rep 41
We must be thinking about different things again.
I also have an option somewhere inside the NAV menus, in the idrive, to change the color schemes of, what I believe to be, the maps. I don't think it has anything to do with the LED's, though. Otherwise, why would that option be included in the NAV menus?.. The COLOUR_SWITCH and COLOUR_SWITCH_LINES that I activated in the NBT, yesterday, are for the Light menu in the idrive, and do concern the LED lighting, because if I deactivate those codes, I stop having the option in the Light menu (idrive) again. Also, every time I go to the menu, nothing is selected. I have to choose Classic or Sport again. (nothing happens, as previously stated..) I'll probably take a look at the ETK, and see if I can buy the LED modules with white "sport" color. Maybe they're not too expensive, and worth the cool look (in my opinion, of course). |
04-14-2020, 01:37 PM | #14 |
Rep 3
Bmw f30 door handles lights coding
Hello can anyone help me how to code only door handles light as i dont have ambient light option in my car. i want to install door handles light but when i connect it to fem pin 52 it wont lit up
Note:I hav bought door handles light |
03-19-2021, 08:16 AM | #15 |
Rep 1
You need to code BDC FA code 563 (lights package option) to enable output signal on pin53-54 of A258*9B BDC connector, and P4V9 code option (excitment light package) to activate pin 52 output.
03-21-2021, 05:06 PM | #16 |
Rep 12
Drives: BMW 3GT (F34)
You need to code 563 for light package and 7ac for sport line.
03-30-2021, 12:42 PM | #17 |
Rep 41
