01-22-2018, 03:50 PM | #1 |
Rep 578
Why does 340xi 6spd get weaker MPPSK?
Hi,
I’m new to the forum and recently bought a 6spd 2016 340xi with track handling package. I’ve read that the MPPSK for a 6spd manual 340xi would only be about 25lbs of torque increase whereas the 8spd auto received 40+ from an otherwise identical kit. Why does the 6spd get the watered down torque upgrade? Is it for reasons of Concern for clutch wear/failure? Is there a way to get the full strength MPPSK with a 6spd car? Thoughts? |
01-22-2018, 11:05 PM | #2 |
Rep 3,622
The transmission must have a lower torque rating
BMW CCA Member #516012
2016 340i, Estoril Blue, Manual Transmission, MPE, MPBBK, HRE FF04 Instagram: @brandons340i |
01-23-2018, 03:52 AM | #3 |
Rep 578
01-23-2018, 06:07 AM | #4 |
Rep 579
Pretty sure its just the fact that you will be more inclined to wear the clutch faster with extra torque, and since its a fully warrantied package, they water it down a bit.
Current: 2021 M340i
Previous: 2020 X3M Comp BM3 E30 & 2016 340i 8AT DME Stage 2 | FBO/Catless Meisterschaft Catback | Ohlins R&T |
01-23-2018, 11:04 AM | #5 |
Rep 3,622
Likely not a weak link but more a decision that will for sure not sacrifice the longevity of the clutch.
01-23-2018, 11:21 AM | #6 |
Rep 2,554
like above, its probably for transmission/clutch longevity and reliability, if it makes you feel any better it was the same on the MPPK for the 335, less torque in the manual
01-24-2018, 02:38 PM | #8 |
Rep 5,983
Get a JB4 tune. Or you might be able to convince someone to upload the 8AT firmware to your car and still be covered by warranty though clutch is wear and tear item, so you would just be replacing it more often unless you chose not to go all out very often and took it easy except for the occasional drag race against an MT firmware car.
01-25-2018, 10:11 AM | #9 |
Rep 1,055
Drives: 2016 340i M Sport 6MT+RWD
While I see how clutch longevity could be a reason, I don't think it'd be a big factor. I personally think it's to mitigate damage from human error (a bad/mistimed shift) which can potentially cause a ton of instantaneous stress on the transmission (i.e. applying too much breakaway torque)...
C'mon, we've all done it at least once before
2016 Estoril Blue II 340i M Sport | ///MPPSK | 6MT | RWD | Fully Loaded
BM3 Stage 2+ 93 | B58TU HPFP | VRSF v2 Catted Downpipe | 550i Clutch |
01-25-2018, 11:22 AM | #11 |
Rep 840
01-25-2018, 10:37 PM | #12 |
Rep 1,447
My understanding (could be wrong!) is that we have the same clutch/transmission since the E9x BMW's. The 550i/335is clutches are an OEM upgrade. More than likely, the M's have an upgraded or different clutch/tranny than we do.
2022 CT4-V Blackwing 6-speed
01-25-2018, 11:59 PM | #13 |
2JZ-GTE
2959
Rep 3,948
This
01-26-2018, 01:12 PM | #14 |
Cheapskate
4442
Rep 4,992
Frankly, these are all just guesses. I've also heard the opposite in other applications, the assumption being that the auto needs more power to compensate for additional weight and driveline losses.
The answer is: we don't know. |
01-27-2018, 10:22 PM | #15 | ||
Rep 1,055
All we can do is speculate.
kern4174442.00 |
01-28-2018, 01:15 PM | #16 | |
Rep 45
09-20-2018, 06:31 AM | #17 |
Rep 578
Bump
The most reasonable speculation I’ve heard lately is that the 340 manual tranny is not rated to handle as much power as the 8AT...thanks for skimping on the manual trannies BMW. Way to screw the purists! |
09-20-2018, 12:42 PM | #19 |
Rep 987
B58 manual box appears to be the same or evolution of the same GS6 45 that was in the E9x N55.
I know of several who have broken those gearboxes, lost synchros, lost gears with bigger turbos. I can't recall any failures on the GS6 53 on the older pre-2011 N54 cars and those cars often push more power. That is probably why BMW gimps the tune for the manual car.
MHD | BMS | VRSF | APEX | RECARO | TC Kline | BERK | Turner Motorsport | Eibach | BMW Performance
Tags |
clutch, mppsk |
