BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > Catless Downpipe Install Help - N20
      06-05-2019, 09:10 PM   #1
ruriostegui7
Drives: BMW 320i
Exclamation Catless Downpipe Install Help - N20
Hi Everyone,
I am in the process of installing a catless DP. Long story short, I got everything off, but I am having trouble connecting the new DP to the midpipe. The new DP appears to be a tiny bit larger than the midpipe, and I am now very worried that I purchased the wrong part. My vehicle is a 2015 BMW 320i base model n20 engine, and I purchased the following DP:
Ebay Downpipe Page
Two questions:
Did I buy the wrong catless DP for my vehicle, explaining fitment issues?
If so,
What is the correct one I should purchase?
Thanks in advance everyone!
      06-05-2019, 09:27 PM   #2
jovanf30
Drives: BMW 328i 2016
Originally Posted by ruriostegui7 View Post
Hi Everyone,
Ebay Downpipe Page
Two questions:
If so,
I think I got the same one, I just took it to a muffler shop and got it welded bc it didnt fit good
      06-05-2019, 09:34 PM   #3
ruriostegui7
Drives: BMW 320i
That's too bad. I will see if I can return it. I just purchased a VRSF downpipe. That's probably what I get for being cheap, lol.
      06-05-2019, 09:35 PM   #4
Lukelar1283
Drives: Bmw 328ixdrive
Hi Everyone,
Ebay Downpipe Page
Two questions:
If so,
Owns a bmw with a Honda budget. This is what buying cheaper parts will get you. Especially eBay parts. Always spend the extra money to go with a name brand like VSFR. Your drive a BMW that has quality factory parts why put in a cheap knockoff part. That’s my 2 cents. Hopefully it’s good quality.
      06-05-2019, 09:37 PM   #5
sspade
sspade's Avatar
2016 BMW 320i  [7.87]
2014 BMW 328i  [6.83]
Should be the right one for your car but the quality and fitment is shady because you did not choose a reputable brand.
As mentioned above... take it to an exhaust shop and have it welded on for $50. This is assuming the turbo side fits properly. I would also recommend a new turbo to downpipe gasket.
      06-05-2019, 09:51 PM   #6
ruriostegui7
Drives: BMW 320i
Hi Everyone,
Ebay Downpipe Page
Two questions:
If so,
Owns a bmw with a Honda budget. This is what buying cheaper parts will get you. Especially eBay parts. Always spend the extra money to go with a name brand like VSFR. Your drive a BMW that has quality factory parts why put in a cheap knockoff part. That's my 2 cents. Hopefully it's good quality.
Well said. It's a tough lesson to learn but an important one. I just bought a VRSF downpipe. I hope it's a better fit. This has been a hassle of a job.
      06-05-2019, 09:54 PM   #7
sspade
sspade's Avatar
FWIW...
VRSF also has terrible fitment issues on the N20. You must not search well.
You very well could be "oh and two."
Keep us posted.
      06-05-2019, 09:54 PM   #8
ruriostegui7
Drives: BMW 320i
Thanks for the advice! I just got a VRSF dp. I'd rather not have it welded on. I'm hoping it's a better fit! I already bought a gasket for it as well.
sspade2466.00
      06-05-2019, 09:57 PM   #9
ruriostegui7
Drives: BMW 320i
FWIW...
Keep us posted.
Wow, I am terrible at this, LOL. Apparently I have money to blow
      06-06-2019, 09:45 AM   #10
ruriostegui7
Drives: BMW 320i
FWIW...
Keep us posted.
It seems like I have a new opportunity to make things right. VRSF is out of stock until 7/5, so I have cancelled my order. I'm now taking new DP recommendations. Any ideas?
Alternatively, I can try expanding the mid pipe to try and fit the DP I purchased with fitment issues. How recommended is that?
sspade2466.00
      06-06-2019, 10:09 AM   #11
pustinek
Drives: 2014 428i
I had same situation with my ebay downpipe.
Since downpipe is just a tube that has same dimensions as stock Cat i wasnt ready to spend 300$ for 1 hour of work. So i just used angle grinder and made the downpipe smaller and pushed the 2 together. Just make sure there are no holes so you wont have any leaks.
Honestly its just a bit of work for a lot of money saved.
      06-07-2019, 11:45 AM   #12
ruriostegui7
Drives: BMW 320i
Thanks! I put on the stock downpipe for now. Having one car is super inconvenient. I'll give it another shot over the weekend if I can't return the downpipe.
      06-11-2019, 03:16 AM   #13
dfwF30bmw
Drives: 2016 328i 6MT Track Handling
My catless VRSF fit like a glove on 2016 328i normal n20 not n26, with manual transmission.
      06-11-2019, 09:05 PM   #14
Craeftig
Drives: BMW 2014 F30
Shouldn't have went cheap.. I heard VRSF DP are good fitment. If u want to spent a lil more I suggest ER DPs.
      06-11-2019, 09:06 PM   #15
mike@x-ph.com
mike@x-ph.com's Avatar
Irts an $88 downpipe, i would not expect it to be a direct bolt on
Your better off returning it and getting a proven brand instead
Nice!!
https://x-ph.com/sale/
Phone number 702-494-9435
      06-11-2019, 09:08 PM   #16
sspade
sspade's Avatar
Just to bring everyone back down to earth...
VRSF has had a ton of fitment issues.
If you search this forum, you will see for yourself.
Maybe they have improved their processes. Maybe not. Worth the risk?
      06-11-2019, 09:30 PM   #17
Craeftig
Where did you get that heat rap for ur DP?
      06-12-2019, 01:13 AM   #18
jovanf30
Yeah the charge pipe i got from them didn't fit good and i had a boost leak. Ended up with aFe
sspade2466.00
210i, bmw, catless downpipes
