BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Possible to code LDW and HBA with these options?
Studio RSR
      10-17-2015, 11:02 AM   #1
sprockie
Drives: 320D
Hi Guys,
If a new F30 has these options:
active cruise control
surround view
PDC front/rear
rearview camera
speed limit info
lane change warning
HUD
Is their anyway I can code LDW and HBA? In my opinion I have all the desired hardware and sensors for it. Correct me if I wrong. And park assistant the automatic parking is that possible or do I need the servos for the steering wheel?
Thank you.
      10-17-2015, 09:16 PM   #2
dmnc02
dmnc02's Avatar
Drives: 2015 M4
You need the SZL stalk with the HBA button in order to code HBA. Most likely, you also need FSC codes in order to enable the LDW and HBA functionality of the camera.
2015 Mineral Grey ///M4 6MT
      10-17-2015, 09:58 PM   #3
Tim@codemybimmer
Tim@codemybimmer's Avatar
Drives: 2022 X4 M Competition F98 LCI
RE: LDW, it doesn't not require FSC Code. However FCW and Pedestrian Detection need it. Someone has asked the question in the past and this is what I got from Bimmerfest:
http://www.bimmerfest.com/forums/sho...23&postcount=4
Seems that if you do that FDL coding, it should activate LDW given you have SLI and LCW already in your F30.
      10-18-2015, 10:16 AM   #4
sprockie
Drives: 320D
Thank you for the info. I thought that HBA would also be available with out the stalk. That it would be always on.
Thank you very much for your info. When I have time later on this week I will try. I have already SLI and LCW in the car. I thought that HBA would also be available with out the stalk. That it would be always on.
      10-18-2015, 10:25 AM   #5
dmnc02
dmnc02's Avatar
Drives: 2015 M4
Unfortunately, it is not possible to code HBA to be on by default on the F3x/F8x.
      10-18-2015, 10:47 AM   #6
sprockie
Drives: 320D
      10-18-2015, 11:10 AM   #7
dmnc02
dmnc02's Avatar
Drives: 2015 M4
The stalk is abut $500. There is some info on the retrofit in this thread if you decide to go that way.
