02-26-2016, 12:22 PM | #24 |
Rep 3,622
I really want the yellow MP brakes on my estoril blue. It would be perfect ?
BMW CCA Member #516012
03-06-2016, 08:43 AM | #26 | |
Rep 681
The drilled and groved discs are better with "fading" after hard use and in wet conditions. |
03-09-2016, 08:51 PM | #27 | |
Rep 108
03-22-2016, 06:45 AM | #30 | ||
Rep 3,947
The M Sport Brake Option has "better pads" than the M Performance Brake Kit. https://www.turnermotorsport.com/t-b...ke-Differences Quote:
03-23-2016, 04:52 AM | #31 |
Rep 931
On 01-2016 the part numvber 34116859066 are replaced with a new one ?
BMW F82 M4 Black MHD CS Map - GTS DKG - Navi -Performance Brake RSL1 Pads - USB - DivX-DVD - Bluetooth - VoiceControl - Connect - Apps - Online - H&K - TrafficInfo - SpLimInfo - WhiteMerino- PDC - Cam - Adaptive Led - Antitheft - CP Steering- Performance ST - Adaptive CP Setup - GarageDoorOpen - Pipercross - Stock Exhaust - Mdrivers Pack - 437M Wheels
03-23-2016, 04:54 AM | #32 |
Rep 931
This is my KIT retrofitted on 03-2016
03-24-2016, 02:38 AM | #34 |
Rep 931
No vibrations . Kit and pads are very good
03-24-2016, 09:08 AM | #35 | |
Rep 681
BMW M3 G80 Isle of Man
03-24-2016, 10:46 AM | #36 | |
Rep 3,947
I would even argue that all of this is moot if you're still running original M Performance brake pads. If you aren't using M Sport Brake Option pads or the F80 M3 brake pads, then you haven't fixed the weak link yet. |
04-04-2016, 07:41 AM | #37 | |
Rep 681
For what concerning to me, I'me ready to install Goodridge Hoese kit and Motul 660 brake oil; then, after my next session on track (provided for the end of april), I will change my brake pads with (I think) Pagid RSL1... Anyway, the stock M Performance Brake Kit is good enough for 99% of driving situation
04-04-2016, 10:44 AM | #38 | |
Rep 3,947
I wouldn't bother with the Goodridge brake line kit. The OEM brake lines are sufficient and they are tested extensively as it is a critical component for vehicle safety. As for brake fluid, the hierachy is as follows: - ATE Type 200 - RBF600 - Castrol SRF RBF660 actually has a lower wet boiling point than RBF600 so you may have to bleed the system more frequently. While Castrol SRF is expensive, you'll probably never boil it at the track so it's one of those "bleed/flush" and forget type of fluids for the entire year. In fact, the wet boiling point of the Castrol SRF is higher than the dry boiling point of many other brake fluids. |
06-02-2016, 11:22 AM | #39 |
Rep 12
Remove rear break dust cover
06-02-2016, 12:11 PM | #40 |
Rep 4,516
I DIYd MPBBK with braided hoses, DOT 5.1 and m4 MP sport pads - epic.
I would agree though that lines, BF and these bona fide upgraded pads would work v well on std m sport brakes too. |
06-02-2016, 12:15 PM | #41 | |
Rep 3,947
Are these not the OE brake pads for the M3/M4? |
06-02-2016, 12:58 PM | #43 | |
Rep 3,947
Cleared up some of the confusion in this thread: http://f80.bimmerpost.com/forums/sho....php?t=1255809 Those part numbers came up on RealOEM but it seems like they're not readily available in the US. |
06-03-2016, 01:28 AM | #44 |
Rep 4,516
Polo
I read somewhere that m4 MP sport pads were Pagid RS29 rebranded as Bmw parts. BP
Current '22 X3M LCI.. |
