BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > Brake light--pads need to be changed at 21K
      06-08-2016, 10:48 AM   #1
jgoens
jgoens's Avatar
3788
Drives: 2013 335i msport
Got a brake system warning yesterday saying pads need to be changed, drive moderately. Have an Appt. at the dealer tomorrow. I asked my SA about the pads needing changing at 21K and he said it could be the software needs an adjustment. Has anyone else had pads needing changing that early? I hoping they don't have to re-flash my ecu because then I will have to do my coding over again.
Last car: 2011 335i Msport. JB4. Vrsf CP
      06-08-2016, 11:15 AM   #2
E30toF30
Drives: 2016 528i Executive Edition
If might be a broken sensor? Those things I hear are really really sensitive and break easily. Apparantly you can't even do a simple brake pad change without accidentally breaking it, hence the need for a new sensor each time you change that particular brake pad. At least that's what I've read.
My brake system warning has been on for the last 2500 miles because of a broken sensor I'm not replacing till fall.
      06-08-2016, 11:57 AM   #3
CalCarNut
CalCarNut's Avatar
Drives: 2015 F36 Jet Black Sport Line
Wife's Benz requires new sensor(s) at each brake pad replacement service. On her car, there is one on the front right and one in the right rear. Not sure how our cars are (BMW). If it's warranteed, why not have BMW fix it? That light would drive me crazy being on all the time...........
2015 BMW F36 428i JetBlack. Sport Line Edition
25% 3M Tint|
      06-08-2016, 11:58 AM   #4
CalCarNut
CalCarNut's Avatar
What does iDrive say about your pad wear? Does it say to replace them?
25% 3M Tint|
      06-08-2016, 01:08 PM   #5
graphite
graphite's Avatar
Drives: '15 528xi
It's common for the system to miscalculate break wear or for sensors to go bad. Unless you've got a lead foot, I doubt the brakes need replacement that soon.
2015 BMW 528i xDrive (F10) | Glacier Silver Metallic w/ Black Dakota + Tech Package (ZTP), Premium Package (ZPP), Driver Assist Package (ZDA), Heated Front Seats, Side and Top View Cameras
      06-08-2016, 01:22 PM   #6
jgoens
jgoens's Avatar
3788
How can that light and warning on idrive every time starting the car not drive you crazy?
It says replace rear pads. I looked at the pads where I can see on the rear and they look to be at least 4 mm. Unless the other side is worn, probably a sensor.
      06-08-2016, 01:22 PM   #7
keylime503
Drives: M2C 6MT, Audi A4 Avant
I just got my rear pads and sensors replaced at just over 18,000 miles. I do drive very aggressively and have done one track day and one autocross on these brakes as well.
      06-08-2016, 01:26 PM   #8
jgoens
jgoens's Avatar
3788
That would seem normal then. I'm pretty light on the brakes and don't do much hill driving. I was just wondering if anyone else had pads worn with normal driving at low mileage. A friend of mine said his Lexus needed front pads changed in the 20k's.
      06-09-2016, 07:45 AM   #9
jwilly
Drives: They're all white now.
Random thought... How do the brake pads look?
That's a lot of white
      06-09-2016, 08:16 AM   #10
KGB_123_99
Drives: '17 330ix M-Sport, '09 528ix
I changed my rears at 17k miles and fronts at 28k miles. I don't beat up my car...
      06-09-2016, 02:06 PM   #11
jgoens
jgoens's Avatar
3788
Like I said, they looked to be at least 4mm and that was on the part I can see through the wheel.
Well, we'll see if they change mine.
      06-09-2016, 03:03 PM   #12
jgoens
jgoens's Avatar
3788
Just got the car back--rear pads, rotors and sensor replaced. The pads were 4mm but the rotor was under spec so a change was in order. Also got an oil change 1500 mi early.
      06-09-2016, 04:18 PM   #13
Michael Schott
Drives: 2017 VW GTI Sport
Did you change them or the dealer under warranty? I'm surprised they wore out that fast. Mine are at 58,000 miles and they have 20,000 miles left. I do however drive a lot on the freeway and it's very flat here.
      06-09-2016, 06:53 PM   #14
KGB_123_99
I do a lot of city driving so that is why perhaps.
In Canada brakes are not covered under maintenance so I changed them.
      06-10-2016, 09:18 AM   #15
Gijutsusha
Drives: 2012 328i Sport Line
I had a similar notification......turned out is was just software needing update.
      06-10-2016, 10:08 AM   #16
Michael Schott
That makes sense. Thank you.
      06-10-2016, 10:47 AM   #17
jgoens
jgoens's Avatar
3788
I'm happy I didn't need that--then I probably would have to do my coding all over again.
      06-10-2016, 12:53 PM   #18
CalCarNut
CalCarNut's Avatar
So sensors were right on...
My car says I have about 40K miles left on the pads...(car only has 7800)...lol.
25% 3M Tint|
      06-10-2016, 01:38 PM   #19
jgoens
jgoens's Avatar
3788
I asked the SA about that and he says the sensors should always be changed when changing pads due to the high heat causing the sensors to become brittle.
      06-10-2016, 02:19 PM   #20
CalCarNut
CalCarNut's Avatar
Absolutely. They're pretty much a one and done part.......
For the benz, the sensors are like $6-8.00 ..not an expensive part at all...not sure for the BMW..but probably not a lot more.
25% 3M Tint|
      06-10-2016, 02:52 PM   #21
insanecoder
Drives: 340isDrive
Curious is there any way to simply disable those sensors?
I'm old school.. I can just visually inspect the pads .. dont need no circuitry to tell me when to change brake pads
      06-10-2016, 03:02 PM   #22
Michael Schott
That's too old school. I'm sure they can be unplugged but I'm also sure that will void a warranty or at the least throw a code.
