BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > Need help with my m sport
Studio RSR
      01-15-2024, 08:46 PM   #1
GraveChair
Drives: 2016 435xi f36
So I have an f36 and I want to do an m sport conversion for my front bumper, and I saw an oem front bumper for sale. my question is if I buy just an oem bumper will I be able to do the conversion or are there other supporting parts that id need to make it work? I know if you do an aftermarket conversion there is but I didnt know if its the same way with an oem fitting bumper.
      01-16-2024, 10:14 AM   #2
Oksamit78
Oksamit78's Avatar
Drives: E39, F30 & F34
This is the front bumper cover on your car and all relevant parts:
https://www.realoem.com/bmw/enUS/sho...diagId=51_9252
This is what is required for M Sport front bumper cover:
https://www.realoem.com/bmw/enUS/sho...diagId=51_9255
Compare these two part lists and identify what other than cover itself requires changes.
Additionally review these for differences:
Trim decor:
https://www.realoem.com/bmw/enUS/sho...diagId=51_9254
Air ducts:
https://www.realoem.com/bmw/enUS/sho...diagId=51_9256
Good luck
2003 E39 530i 5-Speed w/ M Spec, Saphire/Black, M54B30, Active Autowerke Performance Tune
2010 Lancer GTS 5-Speed, Black Pearl/Black, 4B12
2015 F30 335i XDrive w/ M Sport Pack, Alpine White/Black, N55B30M0
2017 F34 340i XDrive w/ M Sport Pack, Azure II /Black, B58B30M0, Dinan Stage 1
      01-16-2024, 02:17 PM   #3
GraveChair
Trim decor:
Air ducts:
Good luck
thank you!
      01-16-2024, 04:35 PM   #4
YASBBYM3
YASBBYM3's Avatar
Drives: BMW M4 Cs Lamborghini Huracan
Trim decor:
Air ducts:
Good luck
There’s more than that single page
      03-10-2024, 10:57 PM   #5
Crystal330i
Crystal330ii
Drives: 2017 BMW 330i
If you have PDC sensors, the bracket that holds them will either be plastic welded on or 3M taped on. You can reuse them if taped, but if they are welded on you need new PDC mounting brackets as well. (PDC sensors in different location on M-sport bumpers)
