09-14-2014, 08:38 AM | #133 | ||
Gettin It Figured Out
1823
Rep 2,669
"...you use your tongue prettier than a twenty dollar whore..." ~ Taggart Blazing Saddles |
09-14-2014, 05:16 PM | #134 | |
Rep 2,353
I would note that the 28i does not have this opening on the left lower grill. See the attached pics. Last edited by Roundown; 09-14-2014 at 11:21 PM.. |
09-14-2014, 10:11 PM | #135 | |
Rep 4,323
Now we can expect some good results then soon...here's to stacking!
09-15-2014, 12:29 AM | #136 | |
Rep 3,428
In this regard, there absolutely no difference between what happens here and with "the other" piggyback(s). Install any of the other piggybacks onto a car without MPPK and install one on a car with MPPK...both car's end results will be identical. For example, why do you think there is no difference between "the other" units sold for an F30 335i and an M235i (which effectively has MPPK). End results are the same. The information from the underlying ECU program doesn't matter...it's ultimately the same engine and turbo set to target the same parameters from the same signals being transmitted to the ECU. There is nothing stopping anyone right now with MPPK from ordering a "non MPPK" Dinan unit and installing it. It will install and work perfectly fine and the end results will be same as someone who didn't have MPPK, (except you have those super cool HP and TQ displays). The only reason you WILL NOT see it marketed to MPPK cars is that Dinan is going to have a very, very difficult time selling the value of a $2K tune which gets you 10 HP (MPPK F30s dyno around 295-300 RWHP...two M235i owners made 312-314 RWHP with Dinan Stage 1 plus an intake/MPE, as did Dinan's own M235i. Do the math). Not surprisingly, what you will see is the Dinan "Stage 2" DTronic marketed to MPPK equipped cars, providing a small bump over their Stage 1 to about 330-335 RWHP combined with their intake and axle-back perhaps. Then they can advertise some sort of gain for MPPK cars, however negating any of what the MPPK did to the engine's tuning while leaving the MPPK's ancillary benefits since a piggyback can not do anything about those. Just adding a dose of reality here, but it would be interesting if I'm proven wrong. We can of course go back to asking if a DTronic is in the works for a 2007 Z4... |
09-15-2014, 11:32 AM | #137 | |
Rep 176
Great! Yup as long as you have the oil cooler you will be fine. I am contacting Dinan now and see if I can send my 12 X3 35i in as a development car. Will keep posted!
09-16-2014, 08:45 AM | #138 |
Rep 6,991
I believe all BMWs with the N55 engine have an external oil cooler, as did the older N55 and most of the N54 cars; the F30 M-Sports have an additional engine coolant radiator on the driver side. The question is whether or not M-Sport has a larger OC than the non-M-Sport models. I haven't looked at RealOEM yet.
My previous N54-engined E92 had Dinan S3 installed, which required not only a larger oil cooler but also a more efficient FMIC. Mine were not Dinan, but were brand-name (Evolution Racewerks and Extreme Turbo Systems) equal to or better than the Dinan-labeled pieces, and since I was completely out of warranty, Dinan allowed my dealer to install the S3 software. Which raises the question of whether further tuning stages will also require an upgraded FMIC. Dinan - any thoughts on that?
09-16-2014, 08:59 AM | #139 | |
Rep 2,353
That said, I'd wager that all BMW SUVs come with oil coolers, given the added loads... |
09-16-2014, 12:34 PM | #140 |
Rep 3,130
Additional stages will most likely keep in line with how it has done in the past with the e9x line. Still speculation at this point but I would imagine a stage 3 version will require an intercooler, and a stage 4 would then need a larger turbo, etc.
09-16-2014, 01:36 PM | #141 | |
Rep 4,323
Stacking to me means= 1. Gains and software tweaks from MPPK remain 2. Driveline characteristics from MPPK remain 3. Dinan enhancements are on TOP of this.... So, if you've done the Dinan DHP mods, where they enhance your suspension parameters, you'll see that as an example of a nicely done "stacking" where existing BMW programming has been enhanced.
09-16-2014, 01:41 PM | #142 | ||
1823
Rep 2,669
Yup... +1 |
09-17-2014, 11:33 AM | #143 |
Rep 2
2011 F25 35i
Could you kindly keep us posted on the tune for F25 X3? Many of us are anxiously waiting for it and feel kind of neglected to be honest
09-17-2014, 01:24 PM | #144 |
Rep 3,130
09-17-2014, 05:45 PM | #145 | ||
6 Speed over Auto
30
Rep 192
09-18-2014, 12:32 PM | #148 |
Rep 3,130
There are plans for a stage 2 and it's associated hardware components. As to a rough date of when that may happen we have a tentative goal in mind but it is an extremely fluid time frame so anything I gave you would be pure guess.
09-23-2014, 11:12 AM | #150 |
Rep 26
Quick update - my car is currently at my dealer having this installed and they ran into some programming problems yesterday and had to keep it over night and are currently still waiting on Dinan for some answers...
This is the first install of the new EWG compatible version that my dealer is doing so yay to me for being a test dummy...will keep yall posted |
09-23-2014, 04:41 PM | #152 |
Rep 26
Not much progress made today but they finally have a Dinan tech on the phone trying to figure it out. Leaving it there for one more night...a little bit disappointed right now obviously
09-25-2014, 12:02 PM | #153 |
Rep 23
Will the dinan tune discriminate on total power gains like my mppk does, as far as automatic transmission vs. 6mt. I have the mppk and a 6mt and I feel like I got the short end of the stick.
09-25-2014, 01:00 PM | #154 | |
Rep 3,130
If you are feeling a noticeable difference between your vehicle w/ MPPK and another vehicle w/ MPPK I would go back to your dealer and verify the MPPK tune is actually flashed on your vehicle as there really shouldn't be a measurable (in terms of feel) difference. |
