06-02-2019, 04:08 PM | #1 |
Rep 533
Fan sounds different after FMIC install
I installed a VRSF charge pipe and 5" fmic. After the install when I took the car for a test drive it seemed ok but a few miles into the ride I got a drive train malfunction warning. So it looks like I didn't have the silicon coupler positioned correctly or clamped tight to to the 2 charge pipe halves. I re-adjusted everything and got it aligned correctly. Car runs great and I have no codes. I do have a different fan sound than before with the stock intercooler. I'm thinking the bigger fmic makes the fans sound different. Had anyone had this experience?
435i GC
06-03-2019, 11:32 PM | #3 |
Rep 2,357
I experienced the same. Forgot about it quickly again though
(A Dane in China) |
06-03-2019, 11:57 PM | #4 |
Rep 101
Mine sounds a bit different too.
2015 335i ///M-Sport 8AT | M Performance Exhaust/Brakes/Suspension | BMS CP | BM3 Stage 2 | VRSF FMIC | AR Design DP | AFE Filter | RES Delete | BavAuto Coils | P3 Gauge | xHP Stage 3 |
Krash170.00 |
06-04-2019, 08:17 AM | #5 |
Yoda of mods
1672
Rep 3,004
Drives: X5 RWD
Normal.
F87 AW (retired) F30 SBM 316rwhp/440rwtq (retired) Follow me on Twitter: https://twitter.com/EdwyerCLT YT: https://www.youtube.com/@DWYERGARAGE/videos |
06-04-2019, 09:38 AM | #6 |
A family of bimmers
2745
Rep 7,741
more air can move through the FMIC thus changing the sound of the fan
07-15-2019, 02:08 PM | #7 |
Rep 165
I just installed a fmic and my fan sounds different also. No codes everything is running fine. The fan is just louder now. I'm guessing it's normal because the intercooler is bigger and the fan is just echoing off of it. At least I hope that's what it is...
07-18-2019, 09:35 AM | #8 |
Rep 533
This is my hope too!!!
435i GC
07-18-2019, 09:51 AM | #9 |
Rep 3,946
When you install a larger intercooler (heat exchanger) in front of the radiator (another heat exchanger), you're altering the air flow through both heat exchangers. The fan make sound different because it's working harder due to air flow being more restrictive.
07-18-2019, 10:37 AM | #10 |
A family of bimmers
2745
Rep 7,741
my fan was loud as well but it turns out mine was shot and not running as it should. I just got the new replacement installed and its noticeably quieter than the old one. I also finally bent the wrong tabs on my VRSF FMIC to lock in the fan correctly.
07-18-2019, 12:28 PM | #11 |
Rep 5,369
^This.
07-18-2019, 12:35 PM | #12 | |
Rep 3,946
