11-15-2018, 12:42 AM | #1 |
Rep 11
Bimmercode with Easy Entry Seat and Apple Carplay
Can i use bimmercode app to coding smart entry driver seat function and unlock apple carplay (i think my vin code have already licensed)? , thanks
11-16-2018, 01:23 AM | #3 |
Rep 14,085
Drives: G82 M4C X-Drive
What is smart entry?
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3 IG: Raging_G82 |
Penocchio0.00 |
11-16-2018, 08:38 AM | #5 |
Rep 11
jimmy8904563.00 |
11-16-2018, 08:39 AM | #6 |
Colonol Forbin
208
Rep 338
I was able to code Easy Seat Entry using Bimmercode.
I have my lower spine fused with rods and screws so it makes getting in/out so much easier. |
11-16-2018, 09:29 PM | #7 |
Rep 11
11-17-2018, 04:40 PM | #9 |
Colonol Forbin
208
Rep 338
11-18-2018, 07:17 AM | #10 |
Rep 244
11-18-2018, 08:24 AM | #11 |
Colonol Forbin
208
Rep 338
11-25-2018, 10:56 AM | #12 | |
Rep 11
000 SM_GLOBAL -> EINAUSSTIEGSHILFE = Modus_FA_SLV (Done) 3012 -> EAH_VERFAHRWEG_SLV_PHYS = Werte=00, 28 (Does not appear) 3012 -> EAH_SCHUTZFREIRAUM_HINTEN_SLV_PHYS = Werte=00, 3CMy 3012 (Does not appear) My EAH section just only show EAH_0_42_255 |
11-26-2018, 11:20 AM | #13 | |
Colonol Forbin
208
Rep 338
12-02-2018, 12:06 PM | #14 |
Rep 11
12-03-2018, 05:02 PM | #15 | |
Colonol Forbin
208
Rep 338
If you scroll down to the bottom of the Seat Module Driver list you should find the 3012 EAH tab If not I wonder if this is USA car specific. |
06-22-2019, 03:17 PM | #16 | |
Rep 351
Was there a solution to this in the end? |
06-22-2019, 04:10 PM | #17 | ||
Rep 165
BTW, I am in the USA, and have Sport Seats (integrated headrests in front). |
06-22-2019, 05:02 PM | #18 | |
Rep 321
field #1 = EAH_VERFAHRWEG_SLV_PHYS field #2 = EAH_ANFAHRHYSTERESE_SLV_PHYS field #3 = EAH_SCHUTZFREIRAUM_HINTEN_SLV_PHYS field #4 = unassigned and the desired values can be entered in fields 1 and 3. |
06-23-2019, 04:37 AM | #19 |
Rep 3,222
Easy seat coding has changed for my car, try this?
With huge thanks to my good mate @///M Houbi, I can confirm all you need to do for the M2C is change 3000 SM_GLOBAL -> EINAUSSTIEGSHILFE ->MODUS_FA_SLV to Aktiv and you are good to go. You can’t activate CarPlay with Bimmercode |
davidmcw34.50 |
06-23-2019, 05:52 PM | #20 | ||
Rep 66
https://www.bimmerpost.com/forums/sh...php?p=24946035 |
07-19-2019, 09:24 AM | #21 |
Rep 361
save for later
Present: 2014 f30 328xi MSport, 1992 VW GTi VR6 swapped
Past: 2010 335i 6 speed; 2008 VW GTi stage 2, 2004 Subie WRX FBO, 2003 20th Anny VW GTi FBO |
11-08-2020, 11:22 PM | #22 |
Rep 1
Easy Entry Seat Coding
