07-15-2019, 01:36 PM | #24 |
Old Fart
361
Rep 693
TBH if you're seeing any smoke I'd be taking it back and asking them to turn it down a bit.
If soot is getting past the DPF when you floor it then there's too much of the stuff all the time, but that is being caught. You're going to shorten the life of the DPF or at the very least be doing an awful lot of regens to clear it. If they've done it right there should be no smoke as they have set the fuel / air ratio correctly and just optimised everything, smoke indicates they've just turned up the fuel too far.....
The doctors said it's OK to listen to the voices..... just don't do what they tell me
07-16-2019, 11:36 AM | #26 | |
Rep 3,967
07-16-2019, 04:43 PM | #28 | |
Rep 637
07-17-2019, 07:16 AM | #29 |
Rep 541
No smoke on mine with an aggressive map. I remember when I was watching them set it up on the RR, checking to see if there was any smoke.
However the exhaust tips do blacken over time and need to be cleaned, so what ever there is is not visible. |
07-19-2019, 05:35 AM | #30 |
335d individual e92
Rep 14
Just an update to my power loss, seems to do it more in sport mode on a hot day, im getting these codes, used a different diagnostic,
Codes are 481b2b 244a00 258400 Havent a clue 🙈 anyone come across this issue, its usually if i hit more than 120 it does it too, we all do it even though its naughty 🙈 |
12-19-2019, 06:48 PM | #31 |
335d individual e92
Rep 14
E114BE fault code
E114be fault code, I keep getting the code up and it just says manufacturing code?
Car is 393bhp so its quick! But this is coming up more often now but car drives perfectly fine? I'm a little car ott and I keep my cars in tip top shape, I'm curious what this code means? |
12-20-2019, 07:11 AM | #32 |
Rep 1,846
Use ista and get a proper code.
Prob related to pressure or temperature as the car has been pushed too hard it'll flag up a warning. |
12-25-2019, 01:14 PM | #33 |
Rep 251
12-25-2019, 04:46 PM | #35 |
Rep 1,846
12-25-2019, 04:59 PM | #36 |
Rep 251
12-26-2019, 06:18 AM | #37 |
Rep 256
12-26-2019, 06:31 AM | #38 | |
Rep 1,846
Long and short, the map was pushed hard and stopped dpf regenerating then it clogged resulting in needing new dpf and sensor which fortunately was covered under warranty. I think their dyno is optimistic too. Wasted many trips up there and money with them looking at it, just for me to be find the issue myself in 20 mins with ista. Shame as many years ago I used them and they were good but now in my experience I would not recommended them they'll get maps in and tinkle and a dabble generally with remote sessions, I'd use morebhp in crewe he's done lots too and writes from scratch. Last edited by Ajs_435d; 12-27-2019 at 04:29 AM.. |
